OEM Tow Mirrors on a 2017 (issues?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNW-Tundra, Jun 27, 2017.
  1. Jun 28, 2017 at 5:58 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I am the same way with usually springing for OEM parts but I'm with you hard time to justify $200 extra. Let me know how you like the 1A mirrors.
  2. Jun 28, 2017 at 6:13 PM
    PNW-Tundra
    PNW-Tundra [OP] New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    Got them installed tonight, and my 2017 SR5, which only had power adjust and heat, now has power adjust, heat, blinker and side marker light. :DIMG_5491.jpgIMG_5494.jpg
  3. Jun 28, 2017 at 9:43 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I want it all, BSM, power fold, heated, puddle lights, all I tell ya, I want it all!
    Ely010606, Stevenboise and Jsena like this.
  4. Jun 29, 2017 at 12:39 PM
    chphilo
    chphilo Tundra addict
    Western PA
    Sorry, I missed your post. Was your 2011 an SR5?
  5. Jun 29, 2017 at 1:25 PM
    KOZ
    KOZ New Member
    Indiana
    2008 Toyota Tundra SR5 Regular Cab
    TRD Supercharger TRD Lowering Springs TRD Front Sway Bar TRD Rear Sway Bar URD Pulley 2.345" TRD 22" Wheels SOS 2.5"/4.5" Lowering Kit StopTech Big Brakes Front & Rear JBA Headers JBA Cat Delete w/O2 Sims Dirty Deeds Budget Dump
    The OEM tow mirrors that I had installed on my 2015 TRD Pro work great.
    fours, Jsena, chphilo and 1 other person like this.
  6. Jun 29, 2017 at 1:28 PM
    chphilo
    Western PA
    Man, I love this color!
  7. Jun 29, 2017 at 1:32 PM
    KOZ
    KOZ New Member
    Indiana
    Thank you! I do as well but I'd have to say Cement is my all time favorite.
    Tundra805 likes this.
  8. Jul 5, 2017 at 3:09 PM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Will do. I got them a couple days ago, going to install them here in a little bit. Can tell you they're solid and look identical to my brother's OEM tow mirrors. I'm pretty OCD so I think I compared as much as I could.
    I'll put up some pictures and how they did on the road tonight or tomorrow.
  9. Jul 5, 2017 at 9:07 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That would be great! Can't wait to see what you think once installed.
  10. Jul 6, 2017 at 6:55 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    https://youtu.be/RRob8c--ITU
    Here's a couple pictures and a video, thought it was pretty cool that they stay lit when I remote start.
    Everything works (blinkers, running lights, motors up/down and side/side, etc.). Worth noting that I have a Tundra grade, bottom of the line and everything still works. I slowly put on parts to have it look more upgraded so I don't think anyone would have any issues?
    Driving, I don't notice any extra noise at highway speeds and the only vibration I notice is when I hit a pot hole, but I didn't pay attention to my stock mirrors to see if it happened to those - doesn't bother me. Doesn't rattle by any means, glass just vibrates a little.
    Install, only delay I had was mine had a black clip in the center that connects the stock mirror to the door that doesn't go back in for these. I had to use a small pair of needle nose pliers to pull it out of the door. Even with that, it took maybe 15 minutes to put them on. The clips that hold the panel to the door would be dang hard to break, the ones that came off the panel I just pulled off the door and put them back on the panel. Mentioning this because other posts said to have extra clips available bc you'll break them.
    All in all, they match up just like my brother's, can't tell a difference between 1A Auto's and OEM. All the connectors are brass like their video says and the rubber gasket that comes to seal them holds tight. Glass is quality, plastic is perfect, couldn't be happier.
    Two thumbs up from me.
    Stevenboise, KrazieZ and SOB like this.
  11. Jul 7, 2017 at 6:02 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Looks great, thanks for the review. I will be ordering a set of these for my truck this weekend.
  12. Aug 7, 2017 at 4:43 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Hi..could you guys provide your 1aauto.com part# please as they told me they don't have towing mirrors for the 2017 sr dc?
  13. Aug 7, 2017 at 5:44 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    You have to punch in 2016 for the mirrors as they don't have 2017 model year available.
    I purchased a set of the 1a and had to return them, the glass shook so badly on them I couldn't stand it. Every road imperfection made the glass shake and some roads it was constant which then distorted the image in the mirror. Loved the blind-spot mirror in them though so I will be getting the oem mirrors in the future.
  14. Aug 7, 2017 at 5:50 PM
    xj2202009
    x
    Lutz, Fl
    Thank you. Did you have the power folding?
  15. Aug 7, 2017 at 5:58 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Nope, non power fold for me.
  16. Sep 2, 2017 at 12:23 PM
    xj2202009
    x
    Lutz, Fl
    After a lot of research and feedback this were my findings: about half of those that reply went with. Toyota oem and the other half went with a1auto. Half of the folks that went with a1auto experience some vibration and switched to toyota oem, the other half had very little to none. Everyone who went with a different brand reported vibrations 100% of the time. I went with Toyota oem and @Roman had the most competitive prices.
  17. Sep 2, 2017 at 12:26 PM
    xj2202009
    x
    Lutz, Fl
    Toyota oem mirror..by the way these are gloss black not the flat black llastic0fde904548d437322e09b9c8ee880495_61a85493e92a9353c8ce92db8eb96217cb187982.jpgeb61daf44b05e3707441f33482481795_74112a9125b52bba7f97d319ba12c9ac02fb8b56.jpg
    Tundra805, fours and be77solo like this.
  18. Sep 28, 2017 at 8:50 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    @Roman or any others with a TRD Pro - or BSM equipped Tundra.
    I realize I will lose the signal that illuminates for the BSM, which I don't care about, does the beeping when reversing if someone is approaching still sound, or do you lose complete BSM functions upon switching to tow mirrors?
    Thank you.
  19. Sep 28, 2017 at 8:57 PM
    #49
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Just took the OEM mirrors off my 2017 and installed (myself) the tow mirrors..I'm not a mechanic by any means but this was a piece of cake, watched YouTube video and was done in about 30 minutes.. plug and play 100%. My tow mirrors are heated and power adjustable (not folding) with turn signals on the mirrors as well.. zero problems
  20. Sep 28, 2017 at 9:02 PM
    #50
    Ur tow mirrors oem or off 1Aauto?
  21. Sep 28, 2017 at 9:14 PM
    #51
    SullyMoto19
    Tyler
    Houston, Texas
    I believe OEM, but got them on offer up.. but plug and play so I imagine OEM
    Jsena likes this.
  22. Sep 28, 2017 at 9:22 PM
    #52
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You got some nice lookin ones Loc dawg!!!! Pretty bad ass
    GNTundra likes this.
  23. Sep 28, 2017 at 9:30 PM
    #53
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Sweetttt
  24. Sep 29, 2017 at 12:01 PM
    #54
    moviepro314
    moviepro314 New Member
    Iowa
    2017 Tundra Platinum
    Line-x Premium Spay-on bed liner, Truxedo Lo Pro Roll-up Tonneau Cover, Dual Swing Cases from Undercover, Pop & Lock Power Tailgate Lock, BottlePro 2
    I'm also interested in this. One could easily add an LED somewhere in place of the light on the mirror to show someone is in your blind spot, although the blind spot mirror should solve that anyway. I would assume that the BSM is part of the sensors on the bumper and not directly attached to the mirror, so the beeping should still work and the wire for the LED should still work for attaching my own LED. Can anyone confirm?
  25. Sep 29, 2017 at 3:19 PM
    #55
    xj2202009
    x
    Lutz, Fl
    After upgrading to towing mirrors none bsm I'm getting a big blind spot on the right hand side..from the mirror to about back tire is a blind spot..have played with the mirror but no luck..
  26. Jan 23, 2018 at 11:44 AM
    #56
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Can anyone on here comment about the BSM feature? Does the system still beep even though the tow mirrors don't have the lights? Seems if some guys are adding a small led light somewhere that the BSM and rear cross traffic will still be active...............
    moviepro314 likes this.
  27. Jan 23, 2018 at 6:23 PM
    #57
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I love mine on my SR5 but when i pay 46k for a truck I think they should be power folding. Its embarassing always walking around the truck folding them in.
  28. Jan 23, 2018 at 6:33 PM
    #58
    showtime240
    showtime240 New Member
    Did you have power folding OEM mirrors?
  29. Apr 24, 2018 at 12:44 PM
    #59
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I am in the process of doing this right now. I replaced my '18 mirrors with a set from a '12 Limited so I could get power-fold. I had to run 6 wires into each door and replace the mirror switch. I added 3mm LEDs in the sail panels. I got this idea from a post on TundraTalk.
    The only issue I am running into is the tiny 3mm LEDs need resistors, otherwise they will burn out. The resistors end up causing an issue with the BSM system. Both LEDs light up when I first start the truck, but an alert comes on the dash when the sensors are triggered. You can get around this by using larger 12v LEDs that don't need a resistor, but since I like the look of the 3mm LEDs, I am going to put a jumper wire between the positive and negative wires on the LED to "close" the BSM system loop. This should allow the BSM system to operate like it did stock, and the 3mm LED will just branch off of the 12v circuit with it's resistor. I am going to try this tonight and I'll let you know.
    To confirm, you will lose BSM and RCTA (beeping when someone crosses behind you) if the replacement mirrors don't have the BSM LED. If you don't care about the LEDs in the mirrors, you can potentially place a jumper wire on the BSM+ and BSM- wires at the mirror and this should close the loop for the BSM system.
  30. Apr 25, 2018 at 4:18 AM
    #60
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    joejob, if you could post a pic of the jumper wire when you do it that would be great............
