OFFICIAL: Oil Analysis Report Thread ONLY
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Jun 13, 2024.
  1. Jul 29, 2024 at 1:12 PM
    #151
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Many here never heard of Blackstone or oil analysis before this engine debacle. I’m sure their business has boomed on the auto side. (aircraft is their #1 and gets first priority)
    Tunrod and TundraMoe like this.
  2. Jul 29, 2024 at 4:13 PM
    #152
    mattvarnell
    mattvarnell New Member
    First report for me, 23 Hybrid with 20k miles. I have the Toyota K&N style air filters and aftermarket muffler. Everything else looks good?
  3. Jul 29, 2024 at 11:18 PM
    #153
    brutalitybob
    brutalitybob New Member
    Feel like this is good data to compare
  4. Jul 30, 2024 at 11:55 AM
    #154
    AZBoatHauler
    So.Arizona
    One from FB - not so bueno.
    TRDFerguson likes this.
  5. Jul 30, 2024 at 11:57 AM
    #155
    ac3boyz
    ac3boyz New Member
    2023 White Tundra Platinum
    I know I'm not out of the woods yet but this makes me much more at ease. Btw, turn around was 4 weeks.
    23 Platinum
  6. Jul 30, 2024 at 12:01 PM
    #156
    AZBoatHauler
    So.Arizona
    To be fair - Speed didn’t say there wasn’t silver in the bearings - just that they didn’t test for it because the use of silver in that application wouldn’t be compatible with the oil being used.
    sorry, @eddiefromcali ONLY OIL REPORTS
    :anonymous:
  7. Jul 30, 2024 at 12:26 PM
    #157
    mattvarnell
    I am aware of silver electroplated bearings for use in aftermarket racing applications from King Bearing. They are marketed as extreme high-load racing bearings, and it's interesting to note that they are rated fairly poorly for seizure-resistance for what its worth. That being said, I have no idea if any OEM or Toyota has adopted or is using similar technology. But given the design parameters that we know about this engine that it is plausible. https://www.kingbearings.com/material-type/copper-based/
  8. Aug 3, 2024 at 3:16 PM
    #158
    AZBoatHauler
    So.Arizona
    :puke:
    Kap1 likes this.
  9. Aug 3, 2024 at 3:34 PM
    #159
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    What in tarnation?
    AZBoatHauler[QUOTED] likes this.
  10. Aug 7, 2024 at 4:20 AM
    #160
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
  11. Aug 7, 2024 at 4:25 PM
    #161
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    I just received my sample back from Blackstone. At 43K it looks really good. next oil change which will be in the next couple of weeks I will check a comparison.
    For the guys that have had high readings after let’s say 20K , and had oil samples, and experienced a failure afterwards. Just wondering what the tell tale signs are . It has to be in the sample , would you not agree?
    BoulderGT3 likes this.
  12. Aug 15, 2024 at 3:18 PM
    #162
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    First Blackstone report for me and the truck. 2nd oil change.
    I did break-in oil change at roughly 1K, this one was a bit over 5K miles.
    All looks/sounds good.
  13. Aug 15, 2024 at 11:11 PM
    #163
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Virtually identical to my oil report at 5K on my 2nd oil change...
    BlackNBlu[QUOTED] likes this.
  14. Aug 16, 2024 at 8:45 PM
    #164
    PNW Tundra Mike
    Southern Cal
    Thx for sharing. Out of curiosity, how long (time) did you drive your truck just before you drained this oil?
  15. Aug 17, 2024 at 6:35 AM
    #165
    BlackNBlu
    Rich
    MN
    IIRC this was a Saturday morning, I had made a coffee and errand run, maybe 7 miles total. Engine was fully up to temp.
    Came home, got ramps and tools out. Oil was still warm/hot-ish when it went into the sample jar from a mid-stream collection.
  16. Aug 17, 2024 at 8:16 AM
    #166
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Forgive me if I missed it, but has there been a single Blackstone report that even hinted at an imminent bearing failure?
    I know a few reports have had higher than normal silver content, and Blackstone suggested that *might* be from bearings. But to my knowledge no one has confirmed that the Tundra bearings actually have a silver electroplated surface, like some aftermarket bearings have.
    daverxa likes this.
  17. Aug 17, 2024 at 8:58 AM
    #167
    This is the original post. Please keep discussions to reports posted and the results of those reports.
  18. Aug 17, 2024 at 9:04 AM
    #168
    Matt2015Tundra
    2023 1794 CrewMax
    I'll ask again, has there been a single Blackstone report that said something to the effect of:
    "We have serious concerns about the health of your engine. The wear metal content in your oil is extremely high, and it suggests a major problem and possible failure is imminent."
    Also, it seems like it would be fairly simple to confirm if the Tundra bearings have silver in them with the proper testing equipment. If so, I'm surprised no one has done this. But I'm no expert in this area.
    Anyone?
    Edit: Forgive me if my questions fall outside the intended purpose of this thread.
    daverxa likes this.
  19. Aug 17, 2024 at 9:08 AM
    #169
    AZBoatHauler
    So.Arizona
    All the way down to post 15.
  20. Aug 17, 2024 at 9:13 AM
    #170
    Matt2015Tundra
    2023 1794 CrewMax
    I acknowledged some reports have higher than normal silver content. But even that report doesn't exactly warn of imminent failure.
    But thanks for trying to be helpful at least, unlike your first response to me.
    daverxa likes this.
  21. Aug 17, 2024 at 9:23 AM
    #171
    TundraTT
    TundraTT Full Send
    23 Taco Trail 97 FZJ80 68 Goat
    That won’t necessarily be in a report. You have to analyze the data and make an educated guess on if it’s healthy or not healthy enough for you to be worried
    AZBoatHauler likes this.
  22. Aug 17, 2024 at 9:48 AM
    #172
    Matt2015Tundra
    2023 1794 CrewMax
    Hmmm...I thought that was the purpose of sending your oil to Blackstone...so they can "analyze the data and make an educated guess" on the health of your engine.
    Maybe I'm expecting too much from these oil analysis reports, but I haven't seen one that would convince me to park my truck until it gets a new engine. Most of their comments are rather benign and non-conclusive to me.
    Aku77 and daverxa like this.
  23. Aug 17, 2024 at 12:08 PM
    #173
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    They will tell you in black and white terms if there is a problem with the analysis. I've had a bad one and there is no doubt.
  24. Aug 17, 2024 at 1:27 PM
    #174
    TundraTT
    TundraTT Full Send
    If there is a glaring problem, yes of course. It’s not all black and white, that is what people are getting hung up on.
    Keeping the op’s wishes of keeping this analysis only, I’m out
  25. Aug 17, 2024 at 5:37 PM
    #175
    PNW Tundra Mike
    Southern Cal
    Thank you
  26. Aug 22, 2024 at 2:59 PM
    #176
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Mobil 1 0W/20 4500 mi interval at 44321 mi.
    Ausfahrt and Kap1 like this.
  27. Aug 26, 2024 at 2:15 PM
    #177
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Had to take my sample from oil filter but test came back good.
  28. Aug 26, 2024 at 11:39 PM
    #178
    PNW Tundra Mike
    Southern Cal
    Thanks for coming back with this filter test. As expected some trapped metal counts went up slightly.
  29. Aug 28, 2024 at 7:58 PM
    #179
    eddiefromcali
    eddiefromcali [OP] New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Consistent results
  30. Aug 28, 2024 at 9:44 PM
    #180
    AZBoatHauler
    So.Arizona
