Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Oct 10, 2017 at 7:24 AM
    #961
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Alrighty! 18x9 fuel octanes +20 in matte black being ordered!
    Thanks!
    4x4_Angel and joonbug[QUOTED] like this.
  2. Oct 11, 2017 at 8:06 AM
    #962
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    The tire and wheel dimensions are already in the post you quoted.
  3. Oct 15, 2017 at 3:27 PM
    #963
    Fishermanz520c
    Fishermanz520c New Member
    Dorsey
    2013 Gray Tundra
    In gonna go with Monster 20's 285/60/20 and a level kit cause I wanna keep my mud flaps and do not want to trim. Is there a certain offset I need to go with?
  4. Oct 21, 2017 at 7:23 PM
    #964
    doughboysigep
    doughboysigep New Member
    Delhi, NY
    '20 SR5 CM 4x4
    image.jpg Finally got my winter tire set up. Ultra Hunters with General Grabber AT2. Definitely makes the truck look a little more "rugged". I was surprised how much the tires sit outside the fender wells. Bit concerned about rocks being thrown. Also had a front tire rub but only full cranked in one direction and in reverse (?).
    DalTee and 4x4_Angel like this.
  5. Oct 21, 2017 at 7:24 PM
    #965
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Jason (@Grubblife18) what’s your lift?
    I want to buy same size of tires as yours and don’t want to have any rubbing or cutting anything.
    I think you have the best set up!
    Thanks for the help.
    4x4_Angel likes this.
  6. Oct 23, 2017 at 8:07 AM
    #966
    xupkid2
    xupkid2 New Member
    Hi guys, new to the forum. Just purchased a 2016 Tundra Limited and been reading this thread and forum. Still having trouble finding details on tire size and wheel offset. I have a Pro Comp 3/1 leveling kit and looking at 20x9 Method wheels. Id love to go to a 35 x 12.5 General X3 but am not sure if they would fit with a +18 offset with no rub or minimal trimming. I don't mind trimming some plastic but don't want to trim metal at all. My other goal is that I don't want my wheels sticking out too far which a +18 seems to do. Are 35's possible or do I need to go to 33's or something equivalent? Definitely like the 35" look better. Any assistance is appreciated.
  7. Oct 23, 2017 at 5:19 PM
    #967
    Playininthedirt
    Playininthedirt New Member
    Did you ever get a reply or can you share some pics of your completed ride? I am considering the same setup on 2017 DC 4x4 with Fuel Maverick 18" and +20 BS with 305/65/18 Nitto G2's. Undecided on the 3/1 ready lift spacer lift/level or the billstein 5100 set to 3/1.
    Anyone else with a POV would be appreciated. I want to keep the flaps on the front even if I have to bend them a bit. Could part with the lower flap. Next size down is 285/70/18 BFG but I really prefer the Nitto
  8. Oct 23, 2017 at 5:24 PM
    #968
    Playininthedirt
    Very nice looking. How much trimming did you have to do? Just plastic? Skid plate at all? Assuming at 11.77 width and +25BS they sit directly under the well and don't come out at all?
  9. Oct 24, 2017 at 5:29 PM
    #969
    Playininthedirt
    Guys looking for some help. Second Tundra, now a 17 DC TRD non-Pro. I have 2 decisions:
    1. Bilstein 5100's set at 3/1 or ready lift 3/1 spacer setup. Obviously big cost difference but I would like the better shocks I think
    2. With that lift, looking for tires that will sit under or just a touch outside the wells to avoid rock throws. Want to keep flaps if possible as I spend a lot of time on gravel roads. Liking the nitro G2's and like Fuel Maverick +25 BS. Looking at 295/70/18, but they look tight on a truck and show 34.29 on Nitto chart. I don't want to lose so much size by going to 285/65/18 but only other options are go to a BFG in that size of go to a 305/65/18 in Nitto which has right diameter but is 12.25" wide. Can I get those under the wells with +25 BS, will they stick out a little, or stick out a lot (enough for flares)? Concerns about rubbing the UCR?
    I have it narrowed down but could use some help. thanks
  10. Oct 26, 2017 at 1:38 PM
    #970
    Grubblife18
    Grubblife18 New Member
    2014 tundra limited
    6" readylift, rock star wheels on 33's and much more.
    @xupkid2 you can go up to 35s but you will have to do minimal trimming with a 9 wide wheel. I have 10 wide and they rubbed a bit when wheel was turned all the way but I trimmed a small amount and heated the plastic to reshape if. Works great.
    Biby and 4x4_Angel like this.
  11. Oct 27, 2017 at 4:43 PM
    #971
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    285 70 18 on stock trd rims on 16 trd pro stock suspension. No rubbing or trimming at all.
  12. Oct 29, 2017 at 7:51 AM
    #972
    kEnwEisEr
    kEnwEisEr New Member
    North Georgia
    2022 SR5 Crewmax XP
    TRD Skid Plate TRD Pro Grille TRD Pro Grille Marker Lights Painted "Tundra" Mustache TRD 20" Wheels Raptor style step bars Truxedo LoPro tonneau cover Fold out bed step (manual) TRD Off-road shocks (red) TRD Off-road axels (red) Cornfed 2/1 lift Nitto Ridge Grappler 285/60R20 TRD dual tip exhaust (black)
    Looking at getting a set of wheels/tires. 2017 Crewmax SR5 White. Not going to lift...at least right now, eventually might do a level. Trying to decide on 18's or 20's. Leaning more towards the 18's since I like the look of a little more rubber. I like the XD827 RS3 all black (XD82789086700) with Nitto Terra Grappler G2's. The wheels have a 0 offset. Thanks to this thread, I know the max tire/wheel sizes. Just wanted y'alls input. Will the wheels be flush with the body line? Are 18's the way to go? What tire sizes would you suggest? 285/65 R18? Any other input or thoughts are welcome. Thanks!
  13. Oct 29, 2017 at 8:19 AM
    #973
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Tire size? Wheel size and offset? Any suspension changes?
  14. Nov 2, 2017 at 9:08 AM
    #974
    SC_HANK
    SC_HANK New Member
    2016 Tundra TRD Off-road
    • 2016 TRD Off-road CM
    • 18″ TRD (non-Pro) rims
    Bilstein 5100's on middle setting install on front next week.
    What is the max size tire on factory 18" wheel with the 5100's at middle setting?
    Just looking for A/T with more side wall. Most likely KO2.
    Who has experience with that exact set-up? My local shops are struggling to give me direction...
  15. Nov 2, 2017 at 9:25 AM
    #975
    delta6b
    delta6b New Member
    2016 limited TRD 4x4
    Backflip Tonneau Cover Bilstein 5160/6112 Fuel Maverick 20x9 +20 Offset Toyo Open Country RT 305x55 R20 Pop & Lock Tailgate Lock Husky X-Act Contour Mats TRD 4x4 Off Road replacement Husky Logo Center Console Safe AJT Design Key Fob ESP Rear Seat Storage FRAC V2 Oh Shit Handle
    Fuel Maverick 20x9 +20 offset, Toyo Open Country RT 33x12.5, Bilstein 5160/6112. Front shocks on highest setting gave it an even stance.7BAD262C-A9E4-4998-8755-BBD3987DD1AE.jpgCE29B80B-297D-4BB2-9AF0-CE56C895A065.jpg3AE293F5-B09C-4B6B-9DE8-754243FC3403.jpg
  16. Nov 2, 2017 at 9:27 AM
    #976
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    0 offset is way too aggressive without a lift, your wheels will poke out atleast 2" and rub all over the place. Even with a 3" lift, you want to stay around a +18 to +25 offset. If you want flush with your fenders, you want +50 to +60 like the stock wheels.
    kEnwEisEr[QUOTED] likes this.
  17. Nov 6, 2017 at 8:55 PM
    #977
    MbTundy
    MbTundy New Member
    Zach
    2014 metallic gray trd off road
    Just figured I'd post a couple pics of how everything turned out, thanks again to everyone for the advice on my wheels! The tires do rub quite badly in reverse on the back of the front wheel wells. Any advice on how to fix this that doesn't involve a sledgehammer?
    silverstreak16 and joonbug like this.
  18. Nov 8, 2017 at 1:58 PM
    #978
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Depending how badly they rub, you can remove the bolt on the liner under the bumper, pull it forward and drill a new hole into the bumper. That'll give you about 1/2". If you grind some of the bumper, you can get even more. If it still rubs try getting a heat gun and manipulating the plastic liner to give you a little more. I cut a section off my liner where it was rubbing. A few people have added washers to move the entire front bumper forward. If all else fails... big fricking sledgehammer!
    Sunnier likes this.
  19. Nov 9, 2017 at 8:19 PM
    #979
    775tundra
    775tundra New Member
    2015 superchargered CM
    Magnuson supercharger, 22x9.5 black rhino traverse, black widow muffler, URD pulley, katskins, pioneer 4600NEX , Toyo ST2, SOS racing 2/4 drop
    I was leveled on 35x12.50 . 20x9 wheels 0 offset. But I clipped the bumper, skid and did the body mount frame chop. Never rubbed. Tires sure did kill my mileage tho. Lol
  20. Nov 10, 2017 at 9:59 PM
    #980
    EduardMusatov
    EduardMusatov New Member
    Eduard Musatov
    Lynden, WA.
    2017 toyota tundra crewmax
    Trd exhaust, Trd intake, sway bar, amp running boards, tunnel cover, paint match handles and mirror caps, aftermarket remote start, 2018 head light,
    Hi Guys
    So I need advice on tiers and size, I bought black rhino wheels 20x9 +12 offset. Now I have hard time deciding what tiers I want
    So I will be installing 2.5" leveling kit and rear 1"
    I don't do any crazy off roading, I don't want street tiers need something that look good and won't compromice the ride and will have a good handling on the road any input would be greatly appreciated
  21. Nov 11, 2017 at 11:26 PM
    #981
    775tundra
    With that setup I'd go 305/50/20 nitto ridge grappler or 285/55/20 with BFG KO2. As stated about there will be some trimming to get no rubbing. I clipped the bumper and did the body mount chop 1st thing
  22. Nov 11, 2017 at 11:33 PM
    #982
    EduardMusatov
    Eduard Musatov
    Lynden, WA.
    Ok thanks a lot now i get some idea what to get
  23. Nov 12, 2017 at 2:20 PM
    #983
    srad750c
    srad750c just passing through
    NC
    2015 Limited DC 4x4
    TRD Pro exhaust, TRD Pro suspension, G-Tek Fab door sill protectors, Stealth running boards, 20" Gunner wheels, BFG K02
    I just added TRD Pro shocks on my 2015 Limited DC, I want to use 295/55R20 tires, what what offset and backspacing do I need for wheels, I want to stay as close to stock wheels as possible.
    Newm likes this.
  24. Nov 21, 2017 at 10:57 PM
    #984
    Tony v
    Tony v Member
    2017 SR5 CrewMax
    275/60/20 with no lift. Unfortunately I do not know the offset. But plenty of room with no rubbing
  25. Nov 23, 2017 at 8:53 PM
    #985
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    2016 Magnetic Gunmetal Metallic Platinum
    Tinted Windows, Baja Designs LED Fog Lights, EGR Matte Black Bug Guard, SCS SR8 Gunmetal wheels, 295/70/18 Nitto Ridge Grapplers, 3/1" Readylift Kit, Morimoto XB Headlights, Viper Smartstart Remote Start, Kobalt Low-Profile Toolbox, Husky X-Act Contour Floor Mats
    Quick question for all of you talented and more experienced folks. I have a 2016 Platinum Crewmax and I'm getting the 3/1 readylift kit installed in the next few weeks. After that I'll be in the market for new tires. I'm wondering if a 285/65/20 will fit without rubbing or trimming, and if so what offset I'd need with a 9 inch rim to accomplish that. I'd like them to stick out about an inch past the fenders so when I put flares on it doesn't look tucked, so whatever offset I need to accomplish that would be appreciated. If those won't fit I'm assuming 285/60/20 shouldn't have any issues, but would still be wondering on the offset to get them out to that stance where they sit about flush with flares. Thanks for any info.
  26. Nov 23, 2017 at 9:10 PM
    #986
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Most flares need over an inch to not look tucked. With a +25 offset, you should be at right about an inch and will still be slightly tucked. Even at that offset, 285/65/20 will rub and you will have to do some trimming. Possibly a CMC too. You’ll be really close.
  27. Nov 23, 2017 at 9:13 PM
    #987
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    Thanks for the quick reply. What do you think the biggest size I could go without rubbing would be with that offset? I definitely don't want to do a CMC, but I'm perfectly fine doing the removal of the mudflaps and heat gun modding the fender liners.
  28. Nov 23, 2017 at 9:30 PM
    #988
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Sorry, I meant the 285/65/20. The 285/60/20 should be fine. If you go with the 285/60, I would go with a +18 offset if you plan to get flares. But that is only a 33.4” tire. I personally would go with bigger without flares and deal with the rubbing. There’s a chance you won’t need a CMC and even if you do, they really aren’t that bad.
    Sunnier likes this.
  29. Nov 23, 2017 at 9:36 PM
    #989
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    You're good haha. This all confuses me haha. On that thread explaining largest tire for both stock and with different size lifts it says with a 3" a 285/65/20 fits and doesn't mention any rubbing like it does with larger sizes. So why is it that you think it'll rub with the 3"? Not trying to question your knowledge just curious due to all of the information I've been trying to comb through.
    Sunnier likes this.
  30. Nov 23, 2017 at 9:37 PM
    #990
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    295/60 I'd also be perfectly fine with if you think I could go that offset without rubbing.
