Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jul 22, 2018 at 6:41 PM
    #1261
    Finch74
    Finch74 New Member
    18 Silver Platinum
    20" XD's with 275/60 wild peaks
    parker44 likes this.
  2. Jul 24, 2018 at 4:49 PM
    #1262
    mopar
    mopar New Member
    ME
    '10 White Tundra
    Bilstein 5100's on highest setting on front, 2" blocks on rear, info center mod, NFab nerf bars, TPMS override
    Thanks. Never been a fan of white out, but with a white truck and black rims I think it breaks it up a little and improves the look a lot.
  3. Jul 24, 2018 at 4:50 PM
    #1263
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Oem fender flares?
  4. Aug 2, 2018 at 12:00 AM
    #1264
    srad750c
    srad750c just passing through
    NC
    2015 Limited DC 4x4
    TRD Pro exhaust, TRD Pro suspension, G-Tek Fab door sill protectors, Stealth running boards, 20" Gunner wheels, BFG K02
    Got my K02 285/55R20 at Toyota dealership also. They were buy 3 get one free. $1100 out the door for everything.
    SgtNewundies[QUOTED] likes this.
  5. Aug 2, 2018 at 12:08 AM
    #1265
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Toyo Open Country A/T II 285/75/18 on Method Grid Titanium +18 offset. Rubbed front liner so I pushed it forward. Definitely need a CMC asap.
  6. Aug 3, 2018 at 6:11 PM
    #1266
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    EDIT: Scratch that, I figured it out. Looks like mine is about 1.5" positive or so.
    @Relentless do you, or anyone else, happen to know the scrub radius for the Tundra? I've got the 2017 CrewMax w/the 5.7FFV & TSS package sitting on 285/55R20 around a 20x9 rim with a +50 offset. I went to try to measure it a couple of times and it was really high - over 100mm. Does that sound right? The calculator doesn't even go over 100.
  7. Aug 6, 2018 at 7:11 AM
    #1267
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    That certainly doesnt sound right, from the factory they're likely very close to 0 scrub radius as increasing it increases ball joint loads on the A arms which leads to more wear. That calculator linked seems to have a pre-set and fixed angle for SAI/KPI which is going to make it hard for you to measure scrub on your truck. Seems to be very much designed for calculating fit for a strut front suspension on a car, not really for double A arm suspension of a truck. Also you'd be better off using the true factory wheel/tire specs on the standard Tundra package in the left column for the 'stock' comparison to whatever you want to plug in in the right column. It wont be exact, but it'll give you an idea on how things change with different wheel/tire combos compared to stock.
    A vid on KPI that may be somewhat interesting
    https://youtu.be/mh_BUOguZQk\
    Also this article is written in terms of UTV wheels, but it does have some useful info and will give you a 3d perspective of some wheel/tire size changes http://shocktherapyst.com/wheel-offset-and-suspension-performance/
    equin likes this.
  8. Aug 6, 2018 at 8:59 AM
    #1268
    Sas
    OKC, OK
    Yeah, I'm looking for a calculator that better represents the independent double wishbone suspension. If you have one I'd definitely appreciate it. The 1.5" was a rough measurement as it's really hard to actually get under the truck and measure it with any degree of accuracy. I did get under there again today though and took a bunch of measurements and it actually is very close to 0, if not 0. I still had to guess a bit for the angle. What I have now is stock and is what I was using on the left side of that calculator.
  9. Aug 6, 2018 at 11:27 AM
    #1269
    trooper669
    trooper669 New Member
    2018 1794 MGM
    TRD front and rear sway bars/ CAI. Recon smoked tail lights. LED Bed Lights. LED grill lights Bilstein 6112 front and 5100 rear. RC 1” rear block. RC lower grill LED bar. Nitto Ridge Grapplers 295x60x20 on Fuel D-251 couplers. SDHQ ABS covers. Rear under seat storage. Body mount rebuild. Color matched mirrors, handles. Raptor step bars.
    295x60x20 Nitto Ridge grapplers, Feul couplers +1 offset with bilstein level
  10. Aug 6, 2018 at 12:19 PM
    #1270
    Any rubbing or cutting ?
    Sas likes this.
  11. Aug 6, 2018 at 12:42 PM
    #1271
    trooper669
    2018 1794 MGM
    front mud flaps gone. At full lock in reverse there is some rubbing because of the way Toyota put the body mount in the wheel well. I will likely have a small rebuild/ reinforcement done to address it and eliminate full lock reverse rubbing.
  12. Aug 6, 2018 at 12:47 PM
    #1272
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    that looks bad ass. i just got the same bronze rims and waiting to get the tires. could you take a pic of the wheel to show how much it sticks out from the fender when you have time. thanks in advance brother.
  13. Aug 6, 2018 at 12:51 PM
    #1273
    Thanks
  14. Aug 6, 2018 at 12:57 PM
    #1274
    trooper669
    2018 1794 MGM
    you bet.
  15. Aug 8, 2018 at 3:33 PM
    #1275
    3rdGen
    3rdGen New Member
    2014 Tundra Limited TRD Silver
    3/1.25 Rough Country Front spacers and hand built shackles.
    Just got my 295/70/18 Nitto Trail Grapplers and 1.5” bora spacers installed on my truck.
    Lots of sweat cleaning this beast up.
    Thanks to porkitt for selling me the spacers and chphilo for recommending the 295/70. Just had to melt and mold the plastic on the drivers side front fender.
    That’s it.
    EEA4DFEC-326F-404E-95E2-A82D0B53A7E6.jpg D5BDF271-657B-4826-81AE-2C12BC51187B.jpg 1DEB4454-856C-4EDC-9662-F657A374098B.jpg
  16. Aug 8, 2018 at 3:44 PM
    #1276
    Sas
    OKC, OK
    Much better stance!
    3rdGen[QUOTED] likes this.
  17. Aug 9, 2018 at 11:19 AM
    #1277
    kenali
    kenali New Member
    Good day gentleman,
    just received my bilstein 5100 adjustable struts yesterday for my 2011 tundra CM. Advise needed from you guys, I am on budget here so try to keep current factory 20" but would like to get beefy looking tires to fit on these wheels, not looking for mud tire here, any advise would much appreciated.
  18. Aug 9, 2018 at 3:47 PM
    #1278
    trooper669
    2018 1794 MGM
    I’m running 295x60x20 ridge grapplers Adjusted to top setting but +1 offset
  19. Aug 13, 2018 at 3:09 PM
    #1279
    hockeyjake94
    hockeyjake94 New Member
    2017 Black Toyota Tundra TRD
    Just got BFG KO2s 305 65 18 installed with Fuel Vectors +20 offset.
    Currently on second setting of Bilstein 5100s in the front. Took mudflaps off. Rubs pretty bad only in reverse. Most likely going to heat and push front liner forward. Hopefully it helps.
  20. Aug 13, 2018 at 5:11 PM
    #1280
    Wisconsin Tundra
    Wisconsin Tundra New Member
    Patrick
    Wisconsin
    2013 Tundra crewmax
    2013 Tundra TSS20180813_185609.jpg 20180813_185537.jpg 20180813_185550.jpg with lift and level 3 in front 2 in back. 20 inch XD Monster 2 rims with factory +60 offset. Wrapped with 305×55×20 Nitto Terra Grappled G2. Backs stick out a little further than fronts. Had to trim about a 1/4 inch off passenger skid plate. Other than that there is plenty of room
  21. Aug 15, 2018 at 2:41 PM
    #1281
    kenali
    kenali New Member
    I like 305/65/18 KO2 wrap around 18x9 wheels, they look awesome
    hockeyjake94[QUOTED] likes this.
  22. Aug 17, 2018 at 12:41 AM
    #1282
    Strokelessone
    Strokelessone New Member
    Beaver PA
  23. Aug 21, 2018 at 6:39 PM
    #1283
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Did you get an answer for this? I'm putting Bilstein 5100's on middle setting to level out the truck and was hoping to get the same specs of wheels and tires as you. Anybody? Haha!
  24. Aug 25, 2018 at 6:59 AM
    #1284
    krazyTundra
    krazyTundra New Member
    Vinny
    Houston
    2021 Cement 4x4 - 5.7L CM
    TRD Front and Rear Sway Sides and back AMP steps BAM Exhaust Tailgate LED Remote Starter Cat shields (all four) Retrax MX Pro - sold TRD Pro Headlight Planned - Deck drawer system, RCI Bed Rack
    Anyone with the stock TSS 20" 6 spoke + stock tires (BF) that have added the 1.25 spacers for a wider look? Side pics if you have any. I just want to keep everything stock to save some money for now but wanted the wider look but not too aggressive.
    DalTee likes this.
  25. Aug 25, 2018 at 6:40 PM
    #1285
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    What setting are the 6112’s on?
    Sharp!
  26. Aug 25, 2018 at 7:07 PM
    #1286
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Here are some pictures of my 2013 TRD SR5 crewmax.wheels are 20" BMF wheels with 305/55/20 nitto ridge grapplers. 2 1/2 in long red lug nuts and red painted brake calipers.
    equin likes this.
  27. Sep 1, 2018 at 12:17 PM
    #1287
    Orion77
    Orion77 New Member
    Level front lift, duel exhaust, front and rear bumpers, front and rear lights, Fuel 20" Avenger wheels, Nitto G2's 285/65/20's.
    IMG_1510.jpg IMG_1514.jpg New to this site and thought I'd post a picture of my ride. 2016 Double cab, leveled w/20" Fuel Avengers @ +20 offset, Nitto G2's 285/65/20's. Also changed out front and rear bumpers as well as front and rear running lights and added duel exhaust.
  28. Sep 1, 2018 at 12:46 PM
    #1288
    tenntundra
    Walter
    Tennessee
    I love the bumper and grill! I wonder if that grill would work in my 2013?
  29. Sep 1, 2018 at 5:15 PM
    #1289
    kenali
    kenali New Member
    Nice... do you need to cut anything with your setup?
  30. Sep 4, 2018 at 7:23 AM
    #1290
    zackbremer
    zackbremer New Member
    Da Z
    2.5in lift...37in TOYO RT, 17in KMC Machete wheels +18mm offset, no rubbing full lock drive or reverset1.jpg t2.jpg t4.jpg t5.jpg
