Oil Catch Can
Discussion in 'General Tundra Discussion' started by nk1794, Mar 15, 2018.
  1. Jun 20, 2018 at 1:24 PM
    #121
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
    Can you post picture of the can?
  2. Jun 22, 2018 at 11:32 AM
    #122
    2010ISFU
    2010ISFU New Member
    Picture of the can.
    Flyinryank, 15whtrd and nk1794[OP] like this.
  3. Jun 22, 2018 at 11:37 AM
    #123
    nk1794
    San Jose, CA
    Very nice!
  4. Feb 10, 2019 at 9:45 AM
    #124
    JK47
    JK47 New Member
    2009 double cab, 4x4 w/ tow package
    Leer cap Blisteen shocks Oil catch can
    Been following / reviewing this thread for a while and considering options on my 5.7 2009.
    Looking up some info on line it seems the 5.7 for 2009 is NOT a Direct fuel injection. Can someone confirm this?
    Also, I found a catch can from Amazon (of course Chinese) has baffles and air deflection and installed it. Here are the results. a lot of clear liquid and a bit of oil. I didn't expect that at all..I smelled collection and it seemed to smell like fuel rather than oil.
    nk1794[OP] and 15whtrd like this.
  5. Feb 10, 2019 at 10:25 AM
    #125
    :popcorn:
    Something else to think about adding to the list.
  6. Feb 10, 2019 at 10:32 AM
    #126
    gs1197tx
    gs1197tx New Member
    TX
    Catch cans and hyper grounding.....internet BS.
    If you're determined to throw $$ away.....just send them $$ to me and I'll tell you how much faster your truck is.
    Cavalrysr5 likes this.
  7. Feb 10, 2019 at 12:03 PM
    #127
    15whtrd
    15whtrd Mr. Blonde
    Me too...
    Darkness and NewImprovedRon like this.
  8. Feb 10, 2019 at 2:48 PM
    #128
    JK47
    JK47 New Member
    Well there's no question the catch can caught oil. It caught other things as well.
    I fail to see the relevance of your post. However you can send me ur bank account information and I'll be sure to make the appropriate withdrawal for this education tidbit.
    :spending:
    It appears that the old adage of "if you don't have anything good to say then don't say it, applies.
  9. Feb 10, 2019 at 3:16 PM
    #129
    Me three.:(
  10. Feb 10, 2019 at 3:16 PM
    #130
    15whtrd
    15whtrd Mr. Blonde
    1UPPER, nk1794[OP] and NewImprovedRon like this.
  11. Feb 10, 2019 at 5:07 PM
    #131
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I asked Magnuson about the CC and they stated aren’t needed. Returned mine.
  12. Feb 10, 2019 at 6:19 PM
    #132
    JK47
    JK47 New Member
  13. Feb 10, 2019 at 6:37 PM
    #133
    gs1197tx
    gs1197tx New Member
    TX
    If a catch can is "catching other things", then clearly there are bigger problems to be concerned about.
    What are these "other things" and how are they managing to find their way into the oiling system?
    A catch can isn't going to solve that problem.
    All the hype about catch cans is just that....hype.
    Trying to sell people something they don't need.
    Show me some quantifiable proof a catch can actually accomplishes anything performancewise or does anything to improve economy for a bone stock engine.
    I'll wait.
  14. Feb 10, 2019 at 7:01 PM
    #134
    JK47
    JK47 New Member
    So the point is, it did catch something and oil is what it caught. Yes other things as well. You seem to be the "expert" or at least desire to charge for your "services" so please let me know what those other things are or could be.
    I'll wait...
    Points
    it interesting that a catch can system has been added to other motors as installed equipment. Not a standard for many vehicles today.
    I understand that gasoline fuel is intended to be burned in these motors, not oil. So perhaps a combo of increase fuel economy or EPA involvement... nonetheless oil is burned in a chamber intended for gasoline. I'm no chemist but fairly certain the fluids have different intensions...likely there are unintended consequences to that...what are those? Fouled internals. I think thats possible given these conditions. Perhaps you have proof otherwise....
    1UPPER, nk1794[OP] and 15whtrd like this.
  15. Feb 10, 2019 at 8:54 PM
    #135
    gs1197tx
    gs1197tx New Member
    TX
    I have no idea what these "other things" are.....that was one of MY question in case you didn't see it.
    If there is such a great advantage to adding a catch can:
    Let's see the data supporting that fact. Should be plenty since apparently so many people jumped on the bandwagon...right?
    Why aren't all the auto manufacturers installing them as original equipment?
    A bunch of you tube videos proves nothing.
    Catch cans have their place....in high performance/high compression/forced induction applications.
    Unless it's designed for a turbo or supercharger, an OEM PCV system would be overwhelmed because it wasn't designed to handle the increased blowby.
    The catch can craze got started when the 4 cylinder turbo cars became popular. Didn't take long before everyone was trying to run
    more boost/add larger turbo(s)/build bigger motors and one of the problems created by that....the PCV system was inadequate.
    Hence the catch cans.
    Lo and behold everyone else sees that Joe Fast has a catch can on his little turbo car...so they decide they need 1 to.
    And then it's all over the internet that you gots to have this.
    If you just want the extra bling under the hood, then more power to you.
  16. Feb 10, 2019 at 9:11 PM
    #136
    JK47
    JK47 New Member
    The "other things" was my original question which i why I posted. If the catch can caught only oil then why would I post? Nice try.
    I do appreciate the history lesson.
    If you could find a way to tone done that big head/mouth then I'm sure more folks would appreciate your input. That's your manners lesson because apparently my offer to resolve this "drama fest" through PMs was rejected and you wanted to "resolve" it in front of everyone. Well u got what u wanted.
    Good day.
  17. Feb 25, 2019 at 8:23 PM
    #137
    JK47
    JK47 New Member
    Following up.
    So I installed the oil catch can (occ) and found that the substance I collected in the occ was mostly a clear liquid. Got me thinking that maybe my truck wasn't burning fuel completely which made me think, spark plugs. Turns out that's what it was. I changed out the plugs and gasket and wow, truck runs like a dream again. Thanks to everyone on here who helped! I took off the occ for the time being and I'll check my mpg with the tune up. I might put it back on just to see what I get afterwards. I'll update here if I do.
  18. Feb 25, 2019 at 8:27 PM
    #138
    15whtrd
    15whtrd Mr. Blonde
    So if anything it helps keep an eye on how it’s running. So in turn helped you diagnose it. Right on!
    nk1794[OP] and Rex Kramer like this.
  19. Feb 25, 2019 at 8:51 PM
    #139
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    The crap in the video is typical of a VW motor. I didn't bother watching but the turbo motors in particular tend to spew that sort of gunk, the early 1.8T motors especially. The fear is that that rootbeer float looking crap will coat the turbo as it passes through the intake and later can, and does, settle in the intercooler as the lowest point of the intake run. I ran a can in my MK4 for about a year but grew tired of vacuum problems and took it off to pass smog, never did put it back on.
    I have inspected the tubes from the valve covers back to the intake tube on my Tundra and my Element but saw no scary amount of buildup there. Without a turbo/intercooler I think the condensed vapors would just make their way to the combustion chamber as intended. There isn't really a place along the way for those vapors to accumulate and cause trouble.
  20. Feb 25, 2019 at 10:55 PM
    #140
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    So...my 2c, or 5, 6, 7...whatever.
    Catch cans (CC's) are not so much about performance...at least not in 95% our trucks, which are likely not tuned and will not see more than 550ish hps (from the likes of a SC).
    Just consider the inlet lines for the CC's...they feed from the PCV and Valve covers. High pressure areas that feed to....anyone, anyone, anyone??? The intake tube and manifold. Those lines are all about pressure regulation.
    Like ole man Jenkins used to say, "An engine ain't nothing but an air pump". Two of the biggest things that matter with an air pump is volume (in and out) and pressure (same thing...in and out).
    The side-effect problem of said regulation is that the pressure is being caused by gases coming from a hot and oily engine [aka...air pump], and is being routed back to regulate/balance the intake pressure, in the tube and manifold via short pcs of tubing. Albeit synthetic, remember....our truck's oil weight and temp rating??? 0W-20?!?! Much thinner and slicker than the 10W-30 that was in the ole '83 SR5 for sure, but it will also atomize quicker.
    With said tubing being so short, the pressurized gases carry said atomized oil that gets pumped right thru the TB, manifold and cylinders.
    Ever wondered how the outer side of the TB plate and interior of the manifold get sooo nasty and covered with what looks like burnt oil???
    Simply put...CC's are ultimately about keeping oil out of the air intake system and cylinders, to allow for a more efficient/true fuel burn, and longevity of parts. Not to mention...the interior 'cleanliness' of your engine.
    The lines for CC's are long enough to allow the atomized gas to cool and dump the 'condensed' oil. This then allows for the returning and regulating air to be 'clean'. There is also some data that suggests CC's may provide a bit of a temperature decrease in the returning air...also a really good thing! Cooler air anyone???*
    Consider the CC's like the CAI's of your choice.... Necessary??? No.
    Along with other mods like SC's and other high-performance mods (CAI, LT headers, DD's X-pipe duals, etc.) and tunes (where your adjusting the mapping of valve timing and fuel load for specific applications)...In these cases, can CC's lend a supporting role and perhaps help realize a few more respective ponies??? Yes!
    *Side note to consider ....What good is a CAI if the air coming in (pass the filter and MAF) is sprayed with hot oily air in the tube, ran through a TB (that has hot coolant running through it) and then sprayed again with hot oily air (at the inlet) of the manifold??? Damn near pointless.
    If you have a CAI...Search for the TB bypass...Do it.
  21. May 26, 2022 at 6:27 AM
    #141
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I installed this guy and was surprised it is noisy, (I assume it's the air being forced through the can "breathing" through the filter) is that normal?
    Screen Shot 2022-05-25 at 6.41.29 PM.jpg Screen Shot 2022-05-25 at 6.40.19 PM.jpg
  22. May 26, 2022 at 11:30 AM
    #142
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    That incoming air disrupts the vacuum of the PCV. You've essentially created a secondary air intake. Is there a way to remove the filter and plug the hole?
  23. May 26, 2022 at 12:07 PM
    #143
    e30cabrio
    Thanks, I have this without the filter:
    So I dragged this out of my drawer of parts:
    Installed the filter over it & cranked down the clamp, no noise!
    Thanks.
    WVI and Tundradrenalin[QUOTED] like this.
