Oil Dipstick Readings
Discussion in '3rd Gen Tundras (2022+)' started by forzamrit, Mar 27, 2023.
  1. Apr 1, 2023 at 11:59 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Shiver mi timbers!
  2. Jun 17, 2023 at 6:54 PM
    AND
    AND New Member
    Washington, PNW
    So has anybody sanded their dipstick yet?
    4genRunner likes this.
  3. Jun 17, 2023 at 7:40 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Sounds painful.
  4. Jun 17, 2023 at 7:50 PM
    AND
    AND New Member
    Washington, PNW
    Hahahaha
  5. Jun 18, 2023 at 7:04 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    ^^^ this. You need to remove the slick surface on the dip stick to see the oil on it. The oem surface is so slick and reflective it makes seeing the oil film on it nearly impossible. Emmery cloth, sandpaper or equal to remove the oem surface - then you will be able to see the oil level even with fresh 0W20. Had the same issue with my Gen3 Taco and this fixed it.
  6. Jul 1, 2023 at 8:33 PM
    Eagleye
    Eagleye New Member
    22 SR5 4x4
    Rear seat cover, bed mat
    Appreciate your observation. The 3rd Gen Tundra gets a solid D- for the oil dipstick, sure hope the guy that signed off on that design moved on to another line of work.
    4genRunner[QUOTED] and KClav like this.
  7. Jul 1, 2023 at 11:02 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Could someone post before and after photos after the dipstick was sanded and how it looks?
    Or at least an after sanding photo?
    Mattedfred likes this.
  8. Jul 2, 2023 at 3:25 AM
    Tom
    Tom New Member
    Has anyone use royal purple to make reading easier?
  9. Jul 2, 2023 at 8:00 AM
    raylo
    raylo not so new member
    Frederick, MD
    Indeed, the other thing I hate about this dipstick of a dipstick is that it is almost impossible to avoid it flinging a couple of drops onto the plastic cover when you extract it.
  10. Jul 2, 2023 at 3:43 PM
    Swanie80
    Swanie80 New Member
    B
    2023 Tundra 1794 TRD OR
    3" Lift, 35" Tires, Fuel Rims
    I don't have pics but I sanded the dipstick with 400 grit. Went up about 1cm past the top dot. I sanded perpendicular to stick so it would hold the oil. Makes it easier to read but still a crappy dip stick and in a horrible location!
  11. Jul 2, 2023 at 6:07 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Scuffing the dipstick is a solution I’ve never considered. The dipstick on the 5.7 is also tough to get a reading on with brand new oil especially if it’s a lighter hue. Recent batches of Mobil 1 that I’ve bought are darker and than they used to be so it’s easier.
    As far as getting a perfect reading that is meaningful every time you check, that’s not something I worry about too much anymore. If there’s oil on the dipstick between the low mark and full mark, it’s good to go. I check oil every time I put in fuel.
  12. Jul 2, 2023 at 6:20 PM
    PNW Tundra Mike
    Southern OC, CA
    MX4 Tonneau, Talon's Trans/Cat Shield
    Tacoma does the same
  13. Apr 30, 2024 at 12:47 PM
    Tundra Morgan
    Tundra Morgan New Member
    Hot Springs Arkansas
    24 1794 TRD
    Just did my 1st oil change. The dip stick is ridiculously hard to read. Filled with correct amount of oil according to the manual looks ok but I'm not 100 percent sure. I would buy a good aftermarket product if it's out there.
  14. Apr 30, 2024 at 12:51 PM
    They are getting you used to not being able to check it. It will be eliminated in the next model, just like the transmission dipstick, and any gauges that help discern the engines health by reasoning.
    kirkb and Nm6300'asl like this.
  15. May 1, 2024 at 5:56 AM
    303Gen3
    Golden Colorado
    the next Gen's readings will be taken from the Tail Pipe - same as the engineer that designed the Gen3's!
    KNABORES[QUOTED] likes this.
  16. May 5, 2024 at 5:40 PM
    tacobronco
    tacobronco New Member
    Scott
    2024 Blueprint Crewmax Limited
    I've noticed that a lot of new cars have dipsticks that are difficult to read. What I do is just pull the dipstick out, wipe it off, and leave it out for a few minutes while you do something else (like change the oil, fill the washer fluid, etc.). Put it across the front of the grill if you're worried about forgetting to put it back in before you close the hood. After a few minutes, re-insert the dipstick and you'll get a clear reading. I guess the residual oil inside the tube that messes up the readings drips down into the pan, so it can't smear the reading.
    GarytheTundraGuy and Soupbean77 like this.
  17. May 6, 2024 at 5:06 AM
    aj350925
    aj350925 New Member
    I'm glad to hear I am not the only person seeing this. I have only checked oil 2-3 times, but each time I could not get a good reading and was just left with a "string of oil half way up the dipstick".
  18. Jul 11, 2024 at 8:17 AM
    24TundraTRD
    24TundraTRD New Member
    '24 CrewMax Limited TRD
    Anyone tried drilling a few small holes between the high and low marks? Same issue here, new oil is next to impossible to read. I know how much I put in, but I like to double check & keep an eye on it too.
  19. Jul 11, 2024 at 10:41 AM
    #49
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Wipe the dip stick with brake cleaner after an oil change helps with reading, also the paper towel trick, and finally is check it first thing in the morning before startup for the best reading.
    Tundrastruck91 likes this.
  20. Jul 11, 2024 at 10:49 AM
    #50
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    No, but on our First gen Tacoma I scuffed up the area with a file and it seemed to work pretty good.
    Raven67 likes this.
  21. Jul 11, 2024 at 11:24 AM
    #51
    rideandfly
    rideandfly New Member
    Get the best reading by checking dipstick in the morning before starting. Takes about 7.5 qts with oil & filter change.
  22. Oct 25, 2024 at 6:00 PM
    #52
    rcsbguy
    rcsbguy New Member
    I just figured it out. Horizontal sanding marks and continue it a quarter inch past the full.
    The trick is insert and remove fast. Don’t wait at the bottom.
    PNW Tundra Mike and FrenchToasty like this.
  23. Oct 26, 2024 at 12:14 AM
    #53
    Curtywerty
    Curtywerty New Member
    2024 Tundra Platinum
    I've always had good luck checking it first thing in the day before starting engine. Don't wipe the dip stick and put it back to check the level, that messes up the reading. also owners manual says insert dipstick with the two bumps on the dipstick facing the engine. No need to sand the dipstick i haven't had any issue with it
  24. Oct 26, 2024 at 3:37 AM
    #54
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Drain oil, remove and replace filter with Toyota specific replacement. Refill with 7.7qts. Marvel Mystery oil. (the red stuff)… Resolves bearing failure insecurity, able to read dipstick oil level..
    YOU’RE WELCOME !!!
  25. Oct 26, 2024 at 9:29 AM
    #55
    PNW Tundra Mike
    Southern OC, CA
    I’ve used Marvel for over 40 yrs in air tools and other uses and have heard about adding it to the crankcase. How much are you adding?
    Soupbean77[QUOTED] likes this.
  26. Oct 26, 2024 at 11:58 AM
    #56
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
  27. Oct 28, 2024 at 3:01 AM
    #57
    Soupbean77
    Just a joke actually…. But when I raced two strokes, my engine builder had me running a blend of castor and synthetic two stroke blend and a couple ounces of Mavel for about an 18:1 ratio. Marvel especially for engine or new piston break in…..
  28. Oct 28, 2024 at 5:40 PM
    #58
    ARB1977
    ARB1977 New Member
    Anthony
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I guess you like to thin out that oil.
  29. Oct 28, 2024 at 7:33 PM
    #59
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    This thread actually got me to start checking mine more often. Checked last fill up. Thanks!
    Soupbean77 likes this.
  30. Oct 30, 2024 at 4:48 AM
    #60
    kwiki1
    kwiki1 New Member
    Ditto everything in this thread about the dipstick and oil level readings for our 2024 Tundra. Had recently took it into dealer for its first Toyota Care maintenance and had the oil changed. Since then when checking the oil its always reading above the high mark. Likely due to the oil change team not paying close attention to detail. Trying to get a consistent reading from the dipstick is a challenge. Toyota needs to do something about this one for sure. The tube is so small along with the small dipstick it will always pull oil up into the tube obscuring the next read after reinserting the dipstick. We have a 2020 Sienna and an older 2013 Sienna that have much the same dipsticks. Only after the oil had darkened made it easier to read. Additionally as many mention, the oil capacity specifications per the manual are for Reference only and to follow the marks on the dipstick. Well, if you can't read the dipstick because of its poor design then how are we to get a true reading. My old diesel tractor made in Japan has the same type of dipstick which we are to simply keep the oil level between its two marks. So with the Tundra maybe its best to do the same and never fill it up to the High mark and consider anywhere between the two marks a Safe level? Another thing and I think it was mentioned in a prior post, How much oil does it take to raise the oil from the Lower mark up to the High mark? Hopefully Toyota is reading these post. Update of this message. I have read pages 472 and 473 of the FULL manual. Very detailed info of the steps to check the oil level along with how much oil is needed to raise the level from the LOW mark to the HIGH mark (1.6 qt). The oil check procedure says to have the protruding areas on the dipstick (HI and LO marks) pointing towards the engine when inserting it into the engine. WOW. That's interesting. So what happens with the stick as you push it in and it follows the windy / curvy tube on its path to the engine pan. The dipstick will naturally rotate itself to make it through all that like a snake.
    22whatwedo and Tundrastruck91 like this.
