Oil for 2018 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, Jul 20, 2023.
  1. Jul 21, 2023 at 5:15 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    usually cheap recycled oil.....
    2mchfun, NWPirate and Leo's first like this.
  2. Jul 21, 2023 at 5:20 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Good thing Redline offers a direct replacement for that stuff
  3. Jul 21, 2023 at 5:24 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    NWPirate likes this.
  4. Jul 21, 2023 at 5:37 AM
    NWPirate
    Zach
    WA
    I don't have any data that says otherwise but you would think Mobil 1 would be plastered all over the service center if they use it.
    A safe bet would be a cheap bulk full synthetic that meets specs, it would save Toyota millions every year.
    Thanks for the laugh! :fistbump:
    nobodyintexas and 2mchfun like this.
  5. Jul 21, 2023 at 6:11 AM
    2mchfun
    Mobil 1 5w-30 synthetic every 5k or so. About every 30-40k dump a quart of ATF in the crankcase and drive it for 30 minutes before the oil change. The added ATF detergents will keep varnish build up to a minimum without any risks. As for neglect, many have mentioned the transmission, but unfortunately many people neglect cooling system maintenance and that's a big mistake which can be catastrophic. Long story short, don't prioritize engine oil over any other maintenance.
  6. Jul 21, 2023 at 6:19 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    My father taught me the ATF in crankcase thing way back before synthetics
    2mchfun[QUOTED] likes this.
  7. Jul 21, 2023 at 6:23 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed.
    however, today's oil detergent additives accomplish this more safely.
    using M1, i always had a clean dipstick.
    Kirkland's does the same.
    As in life, keep your dipstick as clean as possible....if it has tarnish on it, you are using the wrong lube.
    Life is good.
  8. Jul 21, 2023 at 8:02 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    must... resist... epic... opportunity...
  9. Jul 21, 2023 at 8:32 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    The signature is 11.20/qt
    Xl boosted is 9.35/qt
    Oe is 7.00/qt
  10. Jul 21, 2023 at 9:58 AM
    CTundraForMe
    CTundraForMe New Member
    There are numerous threads on this.
    The only consensus is use synthetic, and 5W30 if you're not in a cold climate.
    I'm an Amsoil fan, and change around 5,000 miles.
    I have a family member who's a Toyota Master Mechanic. He says that Amsoil is the best oil out there, and I have no reason to doubt him.
    I was on the road yesterday here in southern AZ and the ambient temperature ranged anywhere from 99F to 108F. I'm happy to use what appears to be the best oil out there in this harsh environment!
  11. Jul 21, 2023 at 11:04 AM
    AZBoatHauler
    So.Arizona
    We saw intake temps of 160 driving up Mt Lemmon last weekend. :eek2:
  12. Jul 21, 2023 at 11:53 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    You do you, but. Still overpriced for a benefit you will never see. Sorry but there has never been a long term study that I know of that shows that a more expensive oil will make an engine last longer. The million mile tundras have had dealer oil in it, so. Stick to what ever is on sale boys and girls.
    Mike59 and Hoff like this.
  13. Jul 21, 2023 at 1:24 PM
    CTundraForMe
    If you want to go down a very hard to read rabbit hole...
    https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
    prevent likes this.
  14. Jul 21, 2023 at 2:00 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Valvoline Advanced 3k intervals.
  15. Jul 21, 2023 at 2:04 PM
    pursuit2550
    Holy Fack. No way can I read all that. I read some parts and saw Quaker state mentioned. Along with Mobil and Castrol. I stick to what’s on sale and move on. ALL oils nowadays are good and not 1 single oil out there will prevent a manufacturing defect of a bearing, pin, oil pump, etc.
    jtwags, Leo's first and Hoff like this.
  16. Jul 21, 2023 at 2:46 PM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    Buy the cheapest oil and change it regularly. I’ve said it before the best oil is clean oil.
    Mike59, Lemuel1 and Leo's first like this.
  17. Jul 21, 2023 at 3:43 PM
    CTundraForMe
    I know. There's good info there, but in a terrible format.
  18. Jul 21, 2023 at 3:53 PM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    There are your Autoparts store oils, and then there is NEO SYNTHETICS . The most advanced and highest quality oil available for your Tundra. Buy 5w30 and you’ll ever go back. It’s a 5.7 Liter V8 5/20 isn’t cutting it especially if you are charging your tires and gears. Running the engine at higher RPM range to get the most power out of the Transmission range. If you get 35” tire go 5.13 or 5.29 gears and you’ll get the most out of your motor. Neo synthetic is hands down the best.
  19. Jul 21, 2023 at 4:02 PM
    #49
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I use race car oil. It has lots of technology in it. Now my truck is a race car.
    PermaFrostTRD, hagrid, Hbjeff and 3 others like this.
  20. Jul 21, 2023 at 4:21 PM
    #50
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    Neo Synthetic is Race Car & Truck oil. Used in Formula one to Baja.
  21. Jul 21, 2023 at 4:31 PM
    #51
    pursuit2550
    Does it come with a blue and red pill? This way we can choose what our trucks can do, Baja or Formula 1
    hagrid and OHwendTrd like this.
  22. Jul 21, 2023 at 4:57 PM
    #52
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
  23. Jul 21, 2023 at 5:17 PM
    #53
    Leo's first
    Groton ma
  24. Jul 21, 2023 at 7:23 PM
    #54
    EmergencyMaximum
    EmergencyMaximum New Member
    Gang,
    Y'know what worries me? Engine might last a million miles, but it's all the other stuff around it that costs thousands that will start falling off regardless of oil used.
  25. Jul 21, 2023 at 7:56 PM
    #55
    CTundraForMe
    Maybe you need better suspension? :)
    Transmission and engine are the two most costly items...
    ATV25 likes this.
  26. Jul 21, 2023 at 8:40 PM
    #56
    EmergencyMaximum
    Gang, I just had engine electrical harness replaced. The harness cost 5000 and labor was 2000.
    Your engine and transmission won't get you anywhere if you can't start it.
  27. Jul 21, 2023 at 8:48 PM
    #57
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I run 5-30 mobile one when it’s warm. 0-20 when it’s cold. I keep it in the crankcase for 5k miles in the tundra and 3750 in the turbo subaru.
    WILLINH, Leo's first and ATV25 like this.
  28. Jul 21, 2023 at 8:54 PM
    #58
    NWPirate
    Zach
    WA
    Rodent damage?
  29. Jul 21, 2023 at 10:42 PM
    #59
    Fishhead
    Fishhead New Member
    The forum should just put one “what oil” thread as a sticky at the top of the page.
    Do allow folks to say what oil they use and/or post used oil analysis. Mods should delete meaningless posts where someone comes in and says “canola oil” or something like that.
    As for me I currently have TGMO 0w20 in my sump. I usually alternate between Mobil 1, Amsoil signature, or Valvoline and my used oil analysis show basically zero differences between the 3.
    CallsignKodiak likes this.
  30. Jul 22, 2023 at 3:13 AM
    #60
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Rape seed oil.
