Ok I need to replace these shocks/struts
Discussion in 'Suspension' started by TexasGuyTX, Mar 24, 2024.
  1. Mar 24, 2024 at 6:55 PM
    TexasGuyTX
    TexasGuyTX [OP] New Member
    Ryan
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    Trying to keep it around $300-$500 for all corners pefer loaded but I got 2 spring compressors.. has to be stock ride or better no aftermarket lift/raise
    the truck is rolling to much and dipping on brakes and I havnt even pulled either trailer I own with it
    (inherited this truck @129k last year) has 130.3k on it now
  2. Mar 24, 2024 at 7:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d say Bilstein 4600’s unless you can still find someone selling OEM TRD take-offs from a new truck. That would be getting harder these days since the new generation Tundra has been out for a couple years now.
    KNABORES likes this.
  3. Mar 24, 2024 at 9:10 PM
    TexasGuyTX
    Ryan
    found some for $352 shipping (bilsteins) dont think it includes any mounts or bushings
  4. Mar 24, 2024 at 9:51 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    2000 Tundra 4wd AC, 2004 Tundra AC 2wd to 4wd conversion no ABS
    lots of dents
    What about just plain jane Monroe struts and shocks?
  5. Mar 25, 2024 at 7:31 AM
    TexasGuyTX
    Ryan
  6. Mar 25, 2024 at 1:15 PM
    TexasGuyTX
    Ryan
    to the top?
  7. Mar 25, 2024 at 3:02 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I used those same Gabriel ones with my Bilstein 5100’s. They will work with 4600’s as well, regardless of whether or not you have the off-road package.
  8. Mar 25, 2024 at 3:09 PM
    JohnWhicker
    JohnWhicker New Member
  9. May 7, 2024 at 6:15 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Im also looking at these same struts and shocks. What did you do about springs?
    Did you buy new somewhere or reused the spring ?
    Also - did the rears come with the top bushing hardware?
    Looks like a bushing kit is available if needed.
    B4-KT1-Z103A00
  10. May 7, 2024 at 7:17 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    4600s utilize your factory spring.
    purplenova likes this.
  11. May 7, 2024 at 8:49 AM
    JohnWhicker
    Factory springs and the rears come with the top bushing hardware.
    purplenova[QUOTED] likes this.
  12. May 7, 2024 at 9:06 AM
    TexasGuyTX
    Ryan
    if your switching from stock tokico's or have kyb/monroe's on the vehicle you will have to get rear bushing kit, my set of bilstiens only came with the nuts for the top no bushing/washers
  13. May 7, 2024 at 9:45 AM
    purplenova
    Tom
    Ohio
    I have monroe on the back now. They are 3 years old and have about 50k miles on them.
    Fronts have never been replaced and truck has almost 112K miles on it.
    Thinks its time to replace all 4.
  14. May 7, 2024 at 10:19 AM
    TexasGuyTX
    Ryan
    you running tokico's I imagine on the front? make sure you tighten the front end on the ground I tightened some of mine in the air not thinking.. mainly the sway bar since its not a ball joint style but def the Control arm mounts if you have to loosen them I dont think you have to I didnt
  15. May 7, 2024 at 10:31 AM
    purplenova
    Tom
    Ohio
    Interesting - i wasnt thinking of doing the fronts myself. I dont have the tools.
    May to to find some youtube's on this.
    Definately will do the backs myself though.
  16. May 7, 2024 at 10:33 AM
    TexasGuyTX
    Ryan
    can rent the spring compressor @ autozone or orielly's if you need too free deposite, make sure its this style not the thin arm style (I have both) and they are alittle sketchy TBH
  17. May 9, 2024 at 8:41 AM
    purplenova
    Tom
    Ohio
    Does the rear end need to be on the ground before torqing them down?
  18. May 9, 2024 at 8:45 AM
    TexasGuyTX
    Ryan
    probably no difference on rear but if anything just the bottom bolt final tightening on the ground
  19. May 9, 2024 at 8:59 AM
    purplenova
    Tom
    Ohio
    Thank You !
  20. May 11, 2024 at 2:19 PM
    purplenova
    Tom
    Ohio
    How long should it take a shop to remove front shocks, move coil over to new shock and re-install?
    Will be installing Bilstein 4600's on front with current springs.
    One local big box tire store said it would be around 4 hours at $160 an hour, plus $130 for front alignment.
    Seems high to me.
  21. May 11, 2024 at 2:55 PM
    TexasGuyTX
    Ryan
    thats nuts, so around $800-1000 for the whole swap without parts :monocle: I imagine 1-2 hours a side if they arnt stubborn
  22. May 11, 2024 at 3:52 PM
    purplenova
    Tom
    Ohio
    I will supply the the new shocks. All they will do is move the spring over and install with alignment
  23. May 11, 2024 at 3:57 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I paid $350 to install my 6112/5160s and align, but that was in 2015..:rolleyes::cool:
  24. May 12, 2024 at 8:20 AM
    purplenova
    Tom
    Ohio
    Gonna order the front shocks today or tomorrow. Other than the spring from old shock is there anything else I need or should order?
    The upper shock mount as seen in pic.
    This item states KYB not Bilstein. I assume the mount is vehicle specific not shock brand specific?
  25. May 12, 2024 at 9:37 AM
    TexasGuyTX
    Ryan
    yep, look @ rockauto should be alittle cheaper I think it was $54 out the door
    KYB mounts on the front, gabrial bushings on rear
  26. May 12, 2024 at 5:50 PM
    purplenova
    Tom
    Ohio
    Cool - thank you
