One thing after another
Discussion in '1st Gen Tundras (2000-2006)' started by Moonminer, Dec 30, 2024.
  1. Jan 14, 2025 at 9:51 AM
    #91
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Bubba is correct. Here is the hose routing on my 2000. @Moonminer - what you have is the vacuum hose bypassing the PS valve which is normally closed creating a vacuum leak which cause an unstable idle.
    shifty`, BroHon and BubbaW like this.
  2. Jan 14, 2025 at 9:53 AM
    #92
    BroHon
    BroHon Everything's clock is ticking
    Bro
    2000 SR5 AC 4x4 4.7
    Weight reduction, mostly rust.
    shifty` and BubbaW like this.
  3. Jan 14, 2025 at 10:00 AM
    #93
    bfunke
    South Carolina
    @Shifty -I don’t believe there is any directionality to the ports on the PS valve and either way image is correct. I encountered that when replacing PS hose recently.
    BubbaW likes this.
  4. Jan 14, 2025 at 10:26 AM
    #94
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    For now my thoughts also but will say that the end of hose at the intake manifold has engine vacuum and with the other end wrongly hooked to the air box, what would pulling a vacuum inside air box cause....hmmm.
    BroHon and bfunke[QUOTED] like this.
  5. Jan 14, 2025 at 10:28 AM
    #95
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  6. Jan 14, 2025 at 12:52 PM
    #96
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Mine is the same as #2 example. Port with the round nub by it goes to the top of the manifold.
  7. Jan 14, 2025 at 1:01 PM
    #97
    Moonminer
    Moonminer [OP] New Member
    Illinois
    2000 tundra, SR5, access cab, V8 4.7 2wd
    I’ll take a look and see what comes of it. Thank you guys very much
  8. Jan 14, 2025 at 2:33 PM
    #98
    bfunke
    South Carolina
    I just checked mine and it’s same as yours @BroHon.
    BroHon[QUOTED] likes this.
  9. Jan 14, 2025 at 3:52 PM
    #99
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    G_unit3000 and The Black Mamba like this.
  10. Jan 14, 2025 at 6:28 PM
    #100
    Moonminer
    Illinois
    Okay on that one side of that power steering valve one side you can feel suction and the other side you don’t feel anything. So I hooked them up and even if I switched the sides the idle didn’t change. Also I did the brake cleaner thing and the truck never changed according to my son. It neither bogged, coughed, almost died, or died so I know I don’t have a leak there. I also checked the voltage and I’m getting 4.8
    The Black Mamba likes this.
  11. Jan 14, 2025 at 6:51 PM
    #101
    bfunke
    South Carolina
    You should not feel any suction across the PS valve if the steering wheel is not being turned. Replace the valve. Might try also just for a test plug the vacuum line at the top of the manifold to see if that stabilizes your idle.
    The Black Mamba and BroHon like this.
  12. Jan 14, 2025 at 7:12 PM
    #102
    shifty` No Water in the Water Fountain
    This. Cap off both the bibs, the one on top of the manifold and the one on the air box. There are vacuum caps for this exact purpose. Does the idle change?
  13. Jan 15, 2025 at 8:06 AM
    #103
    Moonminer
    Illinois
    Not at all. I’ve capped off the lines in question. My friends truck doesn’t have them hooked up at all and he says they never have been? Did some tundras not have these hooked up from the factory?
  14. Jan 15, 2025 at 9:35 AM
    #104
    They should be hooked up to that valve. When you turn the wheel, the added hydraulic pressure inside the lines is supposed to engage (open, or close) the little bunny-head looking valve, and the (added, or removed) vacuum when that valve switches will kick up the idle a couple hundred RPM. This ultimately prevents the truck from bogging down when you turn the wheel and engage the power steering.
    Sometimes people disconnect the valve, either out of ignorance (can't remember where the hoses go) or because the valve has failed, and is letting power steering fluid seep up into the valve, which gets sucked into the manifold. It happens, and typically when it does, you'll see a smoke puff out the exhaust at startup. We've seen plenty of people come here assuming they've blown a head gasket, and wanting advice on replacing the motor. Fortunately, that valve is only ~$50 for Dorman brand, or just shy of $100 for OEM, last I checked.
    G_unit3000, KNABORES and BroHon like this.
  15. Jan 15, 2025 at 9:37 AM
    #105
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I'm going to clamp mine off and see if I can scrub some rpm off my 900 idle
  16. Jan 15, 2025 at 9:40 AM
    #106
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Mine seems like it barely idles above 500, maybe 550. Exhaust gets a little lumpy and growly down that low. Sounds kewl.
    G_unit3000, bmf4069 and Mustanley like this.
  17. Jan 15, 2025 at 10:52 AM
    #107
    Moonminer
    Illinois
    Okay thanks I’ll let him know and how do you know if you have it connected with the right hoses in the right spot? Now what is the standard idle rpm’s? And when warmed up?
    I know it can’t be 1600 or 2000. If I remember my idle was like somewhere in the 600 to 800 range?
    BroHon likes this.
  18. Jan 15, 2025 at 12:10 PM
    #108
    Test is in the FSM, which you can download here on the forum. Save you a search, see here.
    Basically, if I'm reading this right, when the engine is running and wheel is at full lock, that valve should open. Pinching the hose (i.e. closing the valve) with wheels at full lock should make the idle drop. Releasing the hose while in that same state should restore to increased idle.
    G_unit3000 likes this.
  19. Jan 15, 2025 at 3:06 PM
    #109
    Moonminer
    Illinois
    Well I hooked up the hoses to the valve and when I put the engine in drive it dies. If I swap the hoses and put it in drive it dies. If I put the hose that is connected to the top plenum and then to the air box it drives? I mean I’m still in aka limp mode and in the same boat but this just adds to the oh brother! Also no change in idle. I’ve also tried to turn the TPS left or right no change. I don’t know if clockwise lowers the idle or increases it. Or does counterclockwise decrease the idle?
  20. Jan 15, 2025 at 3:08 PM
    #110
    Uh, I think the computer controls the idle. There is no adjustment at the throttle body that adjusts it to my knowledge.
  21. Jan 15, 2025 at 3:24 PM
    #111
    It's because the engine is running with the wrong values, it taught itself how to run with the vacuum hoses improperly routed. You probbly need to force a re-learn with the correct vacuum config.
    Reattach to the valve. Unhook the negative battery cable for 10-15 minutes. Then re-attach battery and start the truck.
    The Black Mamba, BroHon and PNW15 like this.
  22. Jan 15, 2025 at 3:24 PM
    #112
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    The TPS is sensing where throttle plate is and tells the ECU which then regulates the air intake and fuel mixture. It's not for adjusting idle. A relearn will need to be performed once TPS is adjusted properly.
    from page 1....
    The Black Mamba and KNABORES like this.
  23. Jan 15, 2025 at 5:07 PM
    #113
    Moonminer
    Illinois
    I’ll try that tomorrow! If I didn’t shave my head I’d be bald, I’m at my wits end with this truck.
  24. Jan 16, 2025 at 1:53 AM
    #114
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    The Black Mamba and bmf4069 like this.
  25. Jan 16, 2025 at 3:39 PM
    #115
    Moonminer
    Illinois
    Okay hooking the power steering valve to the plenum and air box did absolutely nothing for the high idle. I disconnected the negative battery cable and that seemed to fix the stalling in drive. But it seemed to almost increase the idle a tad. I’m at 1600 to 1800 at idle and about 1300 to 1400 in drive.
  26. Jan 16, 2025 at 3:43 PM
    #116
    Did you drive it around after this? The relearn takes a few to occur
  27. Jan 16, 2025 at 5:37 PM
    #117
    Moonminer
    Illinois
    Yes I drove it around town about 38 miles each way. Now I think my alternator is dead. I have a new xs d3100 battery and at idle I went from 14.3v down to 6.66v. I have done the relearn process several times but truck just doesn’t want to let that high idle calm down. But tomorrow is a new day with a ton more shit!
  28. Jan 16, 2025 at 7:55 PM
    #118
    If you can’t source new Denso alternator, Bosch will work in a pinch. You should be able to get away with the 90A or 100A unit. I forget what the larger was in 2000-2002
  29. Jan 16, 2025 at 8:08 PM
    #119
    Moonminer
    Illinois
    A Denso is what I have. See attached. What about those HO alternators? I have 4 pod lights, 2 30” light bars, and two amps, and two subwoofers in the truck along with accessories we use when we go hunting, fishing. Along with a wench in front and a wench in rear. My son is planning on moving up to Pennsylvania when I get done installing all of his toys in it.
  30. Jan 17, 2025 at 4:09 AM
    #120
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    With all that extra load(watts), would definitely consider not getting the 100A that you have(27060-0F020....Denso 210-0403). Either step up to 130A(27060-0F040-84) or the Sequoia 150A(27060-0F050). The connector and bracket would have to be modified but the 130A and 150A use the same mounting bracket and connector. As an aside for later MY Tundra owners... 03-06 can bolt on the 150A Sequoia alternator plug and play if I remember correctly.
    04 Sequoia’s 150 amp Alternator Swap on a 00 Tundra + The 3 Big upgrades | Toyota Tundra Forum
    G_unit3000 and shifty` like this.
