P&S Beadmaker Review
Discussion in 'Detailing' started by War Machine, Sep 17, 2018.
  1. Oct 3, 2019 at 12:40 PM
    #391
    nowayout
    nowayout New Member
    NY
    17 CM
    Thanks again @Pudge in that case I will stick with the Meguiars Hybrid spray wax, it sounds similar.
    War Machine[OP] likes this.
  2. Oct 3, 2019 at 1:14 PM
    #392
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The megs even lasts a little longer. I love beadmaker but it is what it is. You can't go wrong with the megs
  3. Oct 3, 2019 at 4:23 PM
    #393
    War Machine
    War Machine [OP] SSEM # 5 3MW
    That’s a great product!
    Pudge likes this.
  4. Oct 31, 2019 at 7:14 AM
    #394
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    Newbie here....just signed up to this forum and it's loaded with info. I've always just been a wash and dry kinda guy but just purchased a 2020 MGM SR5 in Sept. I wanted to try some entry level detailing...after reading a ton of posts, I wanted to try using Jescar Powerlock with Beadmaker over it.....but I read somewhere on here (maybe from War Machine) that the Beadmaker doesn't stick to Jescar Powerlock to well but Powerlock was recommended because it looks better than the Hydro2 on MGM vehicles....so am I wasting my time putting Beadmaker over Powerlock since it doesn't stick well and use the Hydro2 with Beadmaker over it? Also which microfiber towels should i use for each application? Thanks guys for all the helpful info
  5. Oct 31, 2019 at 9:02 AM
    #395
    Pudge
    CT
    @swampshark
    I would use either powerlock or hydro2 as a base. Both are excellent, if you already have the powerlock then use that, hydro2 is awesome stuff, but I wouldnt say it's better or worse than hydro2, just different.
    If you want to top powerlock with something, I hear most people have good luck with waxes. Specifically collinite 845, but I bet any wax will work well.
    Hydro2 base with beadmaker topper is a great combo, they just seem to work well together. Hydro2 is expensive but is worth it IMO. When I use it I wash, rinses, hydro2, rinse, spray beadmaker as a drying aide and dry well.
    I really like powerlock alot, it's easy to apply and looks really good, especially on grey and green paint.
    What do you already have as far as these products? You can't go wrong with either of these, I would use what you have on hand.
    Hydro2 and beadmaker are both spray and buff and dry products. Jescar powerlock is a liquid, applied to a dry clean car and buffed and buffed. Same with collinite waxes.
    Which one do you want to use? It comes down to that I guess. If I had to choose between the 2 combos I would probably do hydro2 and beadmaker, but it's a very close call.
    Shooter8571 likes this.
  6. Oct 31, 2019 at 10:05 AM
    #396
    swampshark
    south la
    2020 MGM SR5
    I have not bought anything yet....just concerned about the comment that Beadmaker doesn't adhere well to Powerlock (so I didn't want to waste my time putting Beadmaker over Powerlock if it doesn't adhere well) but Powerlock seems to get the nod for MGM paint? So what difference will I see (if any) in using hydro2 with beadmaker over it compared to hydrolock with beadmaker over it?? Any suggestions for microfiber towel for each product? Thanks...
  7. Oct 31, 2019 at 11:40 AM
    #397
    Pudge
    CT
    The fact it works worse with powerlock than hydro2 is likely due to their chemical make ups. Certain products just don't mesh well and this is a good example.
    Power lock is indeed awesome on MGM, but so is hydro2. It sounds like you really wanna use beadmaker, in that case go ahead and buy thatand hydro2. Hydro2 is quick and easy.
    As far as towels go, I like griots PFM towels for drying, which you'll have to go after hydro2 is applied.
    For the beadmaker, the eagle edgeless 500 gsm towels from the rag company are preferred by most it seems. I don't have any of those, but I have a few dozen quality MF towels or varioustypes, they all work fine. Anything but a waffle weave should work. Make sure you get some MF detergent, I like griots brand, or Wolfgang, but 3D kleen towel is the most economical
    Shooter8571 and War Machine[OP] like this.
  8. Oct 31, 2019 at 12:36 PM
    #398
    War Machine
    For whatever reason, Beadmaker does not work very well with Powerlock. It doesn’t produce the same slickness, doesn’t enhance the gloss as much, and wears off much faster than it does when used with Hydro2. I’m guessing it has to do with the chemistry of each product.
    Now, this part is subjective, so I can only give you my opinion. My wife had a MGM Sequoia, and my daughter has a Honda in a similar color. To my eyes, nothing I’ve ever used on either looks as good as Powerlock, and I’ve tried a ton of stuff. It produces a thick, wet look to the paint which is gorgeous. Beadmaker looks good on MGM, but not nearly as good as Powerlock does.
    On the flip side, Powerlock doesn’t look as good on black as Beadmaker does. Once again, this is just how it looks to me. There’s plenty of people who claim that no product looks better on one color than it does on others. I disagree. I really do think it makes a difference. I always use Powerlock on grey now.
    It may have to do with the depth or reflectivity of the color. Obviously black has a deeper reflection to it than grey or white. Perhaps the thicker product adds depth to the lighter colors. Or, it’s possible it’s just my imagination.
    So, besides the look, there’s several differences:
    Application:
    Hydro2 and Beadmaker are much easier to apply. Both are sprays, so they go on faster with less labor involved. Hydro2 is spray on, rinse off. Beadmaker is spray on, buff off.
    Powerlock is a thick liquid. It has the consistency of toothpaste. You take a foam or microfiber applicator, spread it on, wait for it to haze up, then buff off with a microfiber towel. It takes longer and requires more effort to buff off.
    Durability:
    Powerlock wins this pretty easily. Unless you are in a pretty harsh environment, there’s no reason to apply it more than twice a year. This is the one product I’ve absolutely left alone and not touched up for the longest.
    Hydro2 / Beadmaker is two products with different lifespans:
    Beadmaker starts to degrade after about a month. It will last longer than that, but the effects start to fall off drastically at around a month.
    Hydro2 will last 3-6 months before it wears off. While that sounds like it’s nearly as good as Powerlock, Hydro2 produces pretty much no gloss or visual enhancements whatsoever. The paint is still protected, but the “shine“ won’t be there. That’s why we top it with Beadmaker. It adds the pop that the Hydro2 doesn’t. Powerlock keeps the visual appeal much longer.
    The Hydro2/Beadmaker combo works best if you use Beadmaker as a drying aid in subsequent washes. It keeps the protection and look fresh on the paint.
    Cost:
    Powerlock is around 30 bucks for a 16 ounce bottle or 45 bucks for a 32 ounce bottle. It goes a long way, so the small bottle of Powerlock should last you at least a couple of years I’d say. (I haven’t emptied a bottle yet, so I can’t say for sure.
    Beadmaker is cheap. Usually around 30 bucks a gallon. You will have to use a good bit of it though.
    Hydro2 is one of the most expensive sealants on the market. It’s $60.00 for 16 ounces. It is a concentrate though, which you dilute anywhere from 6:1 to 10:1. That bottle will last a couple of years or more pretty easily.
    Note: Gyeon Wetcoat can be used in place of Hydro2. It’s $19.00 for 16 ounces. It’s not a concentrate, so the bottle won’t go nearly as far. It’s much cheaper up front though. Hydro2 is a better value in the long run.
    Overall, both have pros and cons. Powerlock requires much less maintenance, so if you’re looking for something you won’t have to mess with again for a long time, that’s the best route in my opinion, regardless of paint color. If you enjoy washing your vehicles and don’t mind having to reapply more often, Hydro2 and Beadmaker will keep you happy. You’re going to pleased either way.
    Towels:
    You can’t go wrong with The Rag Company Eagle Edgeless 500. It’s probably the best all around towel, and the price is very reasonable.
    https://www.theragcompany.com/eagle-edgeless-500-ultra-plush-microfiber-towel/
    It’s good for washing, applying sealants, buffing off wax, etc. There are others that excel in different areas, but these will do pretty much any job very well. The Rag Company also sells Beadmaker, so you can lump them together in one order. (Note: Their “Monster” towel is better for applying Beadmaker, but it can be done with the Edgeless no problem.)
  9. Oct 31, 2019 at 12:37 PM
    #399
    swampshark
    south la
    2020 MGM SR5
    thanks so much....Hydro2; Beadmaker and MF towels...Santa gonna come early...thanks again =:^)
    Pudge likes this.
  10. Oct 31, 2019 at 12:46 PM
    #400
    swampshark
    south la
    2020 MGM SR5
    OOps....replied before seeing War Machine's post...so if I went with Powerlock instead, do you still use Beadmaker over that or just the Powerlock for MGM....sorry for multiple posts it's just this is all new to me and I want to do it right....thanks to all
  11. Oct 31, 2019 at 11:01 PM
    #401
    Bust
    Bust New Member
    Shean
    2013 Black Toyota Tundra Rock Warrior
    I was in the same boat @swampshark, just a wash and maybe wax kind of guy. Found this wallet crushing devil forum and am on it every day. I've not tried powerlock, but I have a black RW and go the hydro/beadmaker route. There is something about beadmaker that can't be explained. When applied to a freshly detailed vehicle, you just want to rub your whole body all over it... If you ever get a chance to try it, you should, just for kicks...
    As for MF towels, everyone recommended Griot's PFM for drying and it's remarkable. For wax, glass, and other stuff, I found some I really like on Amazon that I would definitely buy more of, but I also want to try the rag company eagle edgeless sometime. Can never have enough MF towels. Good luck, can't wait to see some pics!
    https://www.amazon.com/Premium-Micr...ber&qid=1572588039&sprefix=buff+detail&sr=8-4
  12. Nov 1, 2019 at 3:48 AM
    #402
    War Machine
    Beadmaker doesn’t work well with Powerlock. I just go with Powerlock only. Some people apply wax over it, but I don’t feel it’s necessary.
  13. Nov 1, 2019 at 7:22 AM
    #403
    Pudge
    CT
    I have a few "buff" brand MF towels and I really like them a lot. They don't have the silk edging like the ones you linked but they are great all around towels.
  14. Nov 27, 2021 at 6:56 PM
    #404
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Well if it ships from autogeek ain’t no way in hell I’m ordering
  15. Nov 28, 2021 at 1:39 AM
    #405
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    Whats wrong with autogeek?
  16. Nov 28, 2021 at 5:43 AM
    #406
    ToyoMafia
    Magic carpet.
    They are fine for most they just burnt me and I’m still hanging on to my anger.
  17. Nov 28, 2021 at 6:02 AM
    #407
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  18. Nov 28, 2021 at 6:14 AM
    #408
    SteyrM40A1
    Gregg
    I can feel your anger, it makes you stronger!
  19. Nov 28, 2021 at 6:23 AM
    #409
    ToyoMafia
    Magic carpet.
    As long as you can feel it.
  20. Nov 28, 2021 at 6:25 AM
    #410
    SteyrM40A1
    Gregg
    Its a quote from a star wars movie. Im kind of a dork.
  21. Nov 28, 2021 at 6:27 AM
    #411
    ToyoMafia
    Magic carpet.
    Lol all good.
    I just try and order products from the manufacture now if possible. That way when I have a issue they take care of it. Autogeek left me hanging on some CarPro product and now I just by from them direct.
  22. Nov 30, 2021 at 11:57 AM
    #412
    War Machine
    What a nerd.
    ToyoMafia likes this.
  23. Nov 30, 2021 at 2:49 PM
    #413
    SteyrM40A1
    Gregg
    No argument there! Lol
  24. Nov 30, 2021 at 3:01 PM
    #414
    ToyoMafia
    Magic carpet.
    I think he was talking about me lmao
    SteyrM40A1[QUOTED] likes this.
  25. Nov 30, 2021 at 3:10 PM
    #415
    SteyrM40A1
    Gregg
    Lmao. Even more proof im a dork!
    WILLINH and ToyoMafia[QUOTED] like this.
  26. Nov 30, 2021 at 4:25 PM
    #416
    ToyoMafia
    Magic carpet.
    And I sir am a nerd
    WILLINH and SteyrM40A1[QUOTED] like this.
  27. Nov 30, 2021 at 4:31 PM
    #417
    SteyrM40A1
    Gregg
    Prove it. Do you own the extended versions of The Lord of the Rings trilogy on DVD?
    ToyoMafia[QUOTED] likes this.
  28. Nov 30, 2021 at 4:37 PM
    #418
    ToyoMafia
    Magic carpet.
    No but I have the books
  29. Nov 30, 2021 at 5:15 PM
    #419
    SteyrM40A1
    Gregg
    I see you have one upped me in the nerd department.
    WILLINH likes this.
  30. Dec 1, 2021 at 3:55 AM
    #420
    War Machine
