Painting your truck
Discussion in 'Detailing' started by Garvin74, Jun 18, 2019.
  1. Jun 18, 2019 at 7:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Pudge likes this.
  2. Jun 18, 2019 at 9:48 PM
    Booradly
    Booradly New Member
    Brad
    Regina, Saskatchewan
    2018 Tundra Platinun
    Body shop safe means no silicone. Silicone causes fisheyes in paint jobs.
    JohnLakeman and Pudge[QUOTED] like this.
  3. Jun 19, 2019 at 4:17 AM
    War Machine
    War Machine SSEM # 5 3MW
    Looks like some good advice has already been given. I’ll contribute by tagging @Omohundro . He’s in the paint and body business, so will have much better insight than I would.
  4. Jun 19, 2019 at 6:19 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    1 Remove damaged part, ie clear pealing. Plas
    2 Feather out the pealing clear (sand the clear until you do not feel the edge anymore)
    3 Find a 2k spray bomb primer, prime and block at least 2 times. Try 600g and water This will fix your substrate for your paint.
    4 get your color and spray light coats until coverage is achieved. If you are not happy with the results wet sand with 800-1000g and apply a few more coats.
    5 clear in light coats also, this will keep you from getting any runs and cut down on trash. I recommend 2-3 coats let it cure good water sand 1000g and clear again. Sounds like a lot but this is the best way with the spry bomb clears.
    I do not have a lot of experience with spray bomb paint jobs, but I do know it can be done and look pretty darn good.
    Also get some tack clothes from the parts store, you don’t want the one that is super sticky. If you have a paint supply store I would visit it, the one I buy all of my stuff from is able to mix the correct color variant for your truck in a spray can.
    Keep in mind plastic adhesion is not as important because your part is already painted. Adhesion is already done unless you just cut all of base paint off.
    Focus on the black part when feathering the clear, stay off the red. 074B3550-C385-41AD-8328-20A6778C5EEA.jpg
    Just let me know, I will help any way I can. I’m all for someone learning how to do this.
  5. Jun 19, 2019 at 9:02 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Nice. I'll have to bookmark this post. :thumbsup:
  6. Jun 19, 2019 at 1:38 PM
    Garvin74
    Garvin74 [OP] New Member
    2017 Tundra CM SR5
    Jody,
    Thanks for the detailed response. For the most part this is kinda how I thought it would go.... in my head except for the 2nd go round with the clear. But I will follow this to the T. I have seen rattle can projects turn out well before on vehicles which is why im going to attempt this. I know it wont remotely come close to show car but I figured I could get it close to factory and make it look like it belongs. Thanks again.
    Omohundro likes this.
  7. Jun 19, 2019 at 3:44 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    If you get the rattle can from a paint supply house that's a different ball game altogether and highly recommended over anything you'll find in the parts store. Hell even the toyota touch up pen is better than the parts store spray bomb as it won't scratch off with a finger nail.
    Garvin74[OP] likes this.
  8. Jun 19, 2019 at 4:27 PM
    Omohundro
    Jody
    McMinnville TN
    Fiestee23 likes this.
  9. Jun 19, 2019 at 5:03 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    At one point I knew a guy that owned a body shop and he was able to mix me some paint and put it in a spray can.
