Parts absurdities
Discussion in '1st Gen Tundras (2000-2006)' started by bing5, Nov 2, 2024.
  1. Nov 5, 2024 at 7:32 AM
    I think it's the latch, but other members (most notably for me is @The Black Mamba) have found that simply wrapping electrical tape a couple layers deep on the top loop fixed his access cab door squeaks. Sounds like a similar solution to yours.
    The Black Mamba likes this.
  2. Nov 5, 2024 at 10:37 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    I wonder if giving them a good soak in silicon spray would help as well. Maybe hit them with brake cleaner first. It's possible they are just gummed up. Probably should have tried that first, but they were driving me nuts.
  3. Nov 5, 2024 at 11:20 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Definitely try cleaning/degreasing first before buying new ones. Before I did a deep clean/lube on mine I sprayed them with grease and it worked for a couple days but it gummed them up and it made the issue even worse. I can't remember what lube I used but it was super light, like WD40 or something.
  4. Nov 5, 2024 at 11:23 AM
    If clearing out old grease is what you need to do, PB Blaster or Kroil will liquiefy old crusty grease fast as hell. Admittedly, PB blaster smells like absolute shit for days/weeks/months after. Not saying Kroil is any better, but ...
  5. Nov 5, 2024 at 1:45 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    And the bad part is, they seem to be having problems with the adhesive lately. I'm about To make another attempt to install new ones on mine. 1st 2 tries by the paint and body I used failed
  6. Nov 5, 2024 at 4:49 PM
    Weagle
    Prattville, AL
    are you guys talking about this one where the OEM version has a interior colored flap to cover up the joints of the door interior?
    I got aftermarket for cheap that snapped right in. It said it was for my truck, but it was too long however I cut a piece out and it snaps perfectly in place
    I'm wondering if I could use the 3M black super weatherstrip and gasket adhesive to attach the colored portion to the new strip. I saw a YouTube of an older guy swearing by this stuff. He was restoring an old car interior IIRC and just used a half piece of trim and the 3M black held. It was an outer piece that had torn away from the part that was still installed on the car. The only thing holding it was the adhesive I wish I could find that video but here's another video on it
    https://youtu.be/xuKogFaQbNE?si=ObyRJv8bnCKbrA0s
    G_unit3000 and Jack McCarthy like this.
  7. Nov 5, 2024 at 5:19 PM
    In AC it's this one, it's huge and wraps around the whole cab opening. This is just the forward half, and there is no colored trim like you DC guys have.
    G_unit3000 likes this.
  8. Nov 5, 2024 at 5:26 PM
    Weagle
    Prattville, AL
    Mine wraps all the way around too
    then there's another one on the door that is U-shaped and on the lower portion of the door
    I guess my point is my inexpensive aftermarket seemed to be good quality. Granted it is not formed or molded for my door like OEM but it still snapped in place even in the sharpest turn/corner I could probably put some heat on it as well to help it out a little
    shifty`[QUOTED] likes this.
  9. Nov 5, 2024 at 5:33 PM
    I have no doubt someone out there makes one that'll fit. I may need to get a profile shot of mine with some measurements and pass it around to a few places, see if any seal makers recognize it. I know @Tundra2 makes some seals at his workplace, just dunno if any would be compatible. And I'm sure that door seal is probably a good 12ft long for the AC trucks.
    Hell, it's possible something like this would even work: https://www.autozone.com/sealants-g...-10ft-dual-durometer-weatherstrip/1219181_0_0
    Supposedly this will work also, and only a buck a foot: https://www.ebay.com/itm/186635274205
    This is supposedly an exact replacement, and for AC trucks, it is for both sides, I may order for shits and giggles. Summit and RA both sell it: https://www.summitracing.com/parts/fcd-kt3018
    Both of those first two options (but not the Summit/RA option) appear to lack a little extra squeeguee-style extension on the bulb that's on the OEM seal, it seals the outer edge of the seal like so, so it's not exactly identical:
    Upshot Knothole and G_unit3000 like this.
  10. Nov 5, 2024 at 7:21 PM
    mthoodbill
    Mt Hood, Oregon
    The Fairchild one seems to work ok. It’s better than a torn one. Ya gotta give yourself some time and go slow installing it to get a good fit. Press that sleeve all the way down.
  11. Nov 5, 2024 at 7:26 PM
    I just want to see the profile of the thing. One 5-star review on Summit Racing's website is all I have to go on, and that person says the gasket is "4 inches to long, had to return it". Aside from the homophonic grammatical error, not super helpful. 5 stars but you had to return b/c too long? Don't you cut it to length?!
    BroHon likes this.
  12. Nov 5, 2024 at 9:12 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Some people are as bright as a blown light bulb.
    Fobroader, shifty`[QUOTED] and BroHon like this.
  13. Nov 6, 2024 at 2:12 AM
    mthoodbill
    Mt Hood, Oregon
    @shifty` it fits fine, no cutting, it’s one big piece. The trick is to fully seat it in the channel. If you don’t do that, then it appears too long. Same outcome would happen with the factory one as well if installed incorrectly.
  14. Nov 6, 2024 at 3:53 AM
    Wait, you’ve used it? If yes, the mould is identical?
  15. Nov 6, 2024 at 7:13 AM
    Weagle
    Prattville, AL
    Yeah, mine was a complete circle. I had to cut maybe 4 feet off. It snapped in so snug it's irrelevant. I just put the same inside the driver's door jam near the door brake
    and you can use that 3M black adhesive if you really wanted to make it one piece again. that stuff is strong
  16. Nov 6, 2024 at 7:16 AM
    Ok yeah, I think I see the little squeegee flap here eh? And this is the Fairchild seal?
  17. Nov 6, 2024 at 7:20 AM
    Weagle
    Prattville, AL
    yes, it was a little more than I remembered. It ended up being about $61 with shipping and tax from Summit racing.
    it's not molded for the doors. But it went in very easily. And most of the turns were not sharp this is the only one by the driver head on pillar B and it still snapped easily in place
  18. Nov 6, 2024 at 7:22 AM
    Looks like it's running around $80 for driver and passenger right now, part number is KT3018 instead of T3018.
    I'm adding it to the list. I've been wanting to replace seals for a minute now. Got bigger fish to fry right now though.
  19. Nov 6, 2024 at 7:24 AM
    #49
    Weagle
    Prattville, AL
    It's amazing how easy this was. I probably took my old one out and put the new one in and about five minutes. Plus whatever time it took to make sure I cut it the right length I tried to make it a little long.
  20. Nov 6, 2024 at 7:35 AM
    #50
    It's more about the $$ than the time. Still haven't found a new gig. I'm still not hurting on cash yet, but probably will be getting thin by Feb/Mar.
    Granted, $71 for both sides at RA before 5% discount, but also before tax/shipping. If I've got it in my PayPal account, maybe I'll drop the cash on it.
  21. Nov 6, 2024 at 7:41 AM
    #51
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    It sounds like you used the AC weather strip on the DC front doors (hence the 4 feet too long). Since the color molded flap is removed with the original weather strip, how does it look on the inside along the A and B pillars and along the top? Did you use this same weatherstrip for the rear doors as well?
    Weagle[QUOTED] likes this.
  22. Nov 6, 2024 at 9:33 AM
    #52
    mthoodbill
    Mt Hood, Oregon
    @shifty` you can see how it fits in these photos. The slightly wrinkled lower area is where I goofed and didn’t set it all the way in the channel. No cutting was needed.IMG_5235.jpg IMG_5236.jpg
    G_unit3000 and shifty` like this.
  23. Nov 6, 2024 at 10:08 AM
    #53
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Could always go used from a wrecker or part out. That's what I did with my old AC. Cost $35 for new stripping that was molded to fit and didn't have holes.
  24. Nov 6, 2024 at 10:10 AM
    #54
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I just got the fairchild window belt molding for my DC and got those installed. Front and rear fit well and seem to be good quality. Looks way better than the peeling, faded, and broken ones that were on there.
    G_unit3000 and Weagle like this.
  25. Nov 6, 2024 at 10:13 AM
    #55
    Outbound
    Aaron
    Northern Alberta
    Dealership quoted me $15 each for lug nuts. NAPA was $12 each. I bought a full set off Amazon for $60.
  26. Nov 6, 2024 at 10:38 AM
    #56
    Weagle
    Prattville, AL
    I believe so. All i saw was extended cab which can be double cab or access cab, depending on which website you're on
    But it works fine
    B pillar is fine. A pillar has a good sized gap. You can see it in that picture I posted above
  27. Nov 7, 2024 at 7:57 PM
    #57
    zingvs
    zingvs New Member
    Zander
    2001 4x4 SR5
    I bought that tailgate protector from the junkyard for $9 last week lol. Dealer price is outrageous
  28. Nov 7, 2024 at 9:02 PM
    #58
    WaterOp
    WaterOp New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    For me, it was the $42.41 for an OEM gas cap.
    Finally got the "check engine" light to stay off, but really the only thing wrong was the O-ring on the original gas cap was cracked.
    So, $42.41, because I couldn't find a 99 cent O-ring that would work. :annoyed:
  29. Nov 8, 2024 at 9:13 AM
    #59
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    https://www.theoringstore.com/
    Teutonics likes this.
  30. Nov 8, 2024 at 9:41 AM
    #60
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    Good Lord....how would you even begin to identify the size and material/ composition/ compatibility for any given application in our trucks. Do we have a resident expert to lean on?
    I can't keep up with all the "projects" in the queue that I am working on to incorporate that task into the learning curve...lol
    shifty` likes this.
