Payload Stickers?
Discussion in '3rd Gen Tundras (2022+)' started by AnalysisParalysis, Dec 10, 2021.
  1. Mar 24, 2022 at 2:40 PM
    #391
    mass-hole
    mass-hole New Member
    Weigh your truck on a cat scale. Toyota is just stamping the same number on the payload sticker of every truck in that configuration weather its a 1794 or a SR. You gotta weight the truck as configured and then subtract that from the GVWR. Otherwise there may be unaccounted for payload that the sticker is not accounting for.
    Have you crawled under the truck to see if there is a rating sticker on the hitch. Ford has a sticker on their hitches and its the same for all F150's whether the truck is rated for 6000 lbs or 12000 lbs. My 2014 has the max tow package, which comes with a beefier hitch than the standard F150. For that year the highest rating for max-tow was 11,300 lbs with an 1130 lb tongue weight. Thats what my hitch sticker says, even though my particular truck configuration is only rated for 11,100 lbs.
    So if you crawl under you might find that the hitch on your truck is rated for the maximum possible tongue weight even if your truck is rated for a lower tow rating.
  2. Mar 24, 2022 at 2:46 PM
    #392
    poop_bubbles
    poop_bubbles New Member
    My 2010's payload is 1,820 lbs. I routinely exceed that by 1,000 lbs or more. Air up the bags and it rides great, still stops like a camry.
    rruff likes this.
  3. Apr 1, 2022 at 2:52 PM
    #393
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    The Canadian 2022 Tundra Hybrid Owner's Manual was released today and page 541 from the owner's manual identifies the model codes and vehicle capacity weights (i.e. payload capacity). I've reviewed various points of reference (including the breakdown by @xc_tc in post #426 in this thread) to come up with the following breakdown of the model code information. I'm thinking the Capstone trim is the PSVUZA code as it's unique but I may stand corrected. Please let me know if you confirm any of the information otherwise and I'll update it.
    - VXKH70L-PSVLZA - Limited 2WD - 5.5' box
    - VXKH70L-PSVZZA - Platinum 2WD - 5.5' box
    - VXKH71L-PRVLZA - Limited 2WD - 6.5' box
    - VXKH71L-PRVZZA - Platinum 2WD - 6.5' box
    - VXKH75L-PSVLZA - Limited/TRD PRO 4WD - 5.5' box
    - VXKH75L-PSVUZA - Capstone 4WD - 5.5' box
    - VXKH75L-PSVZZA - Platinum/1794 4WD - 5.5' box
    - VXKH76L-PRVLZA - Limited 4WD - 6.5' box
    - VXKH76L-PRVZZA - Platinum/1794 4WD - 6.5' box
    2022 Toyota Tundra Hybrid - Model Code and Vehicle Capacity Weight - Canada.jpg
    EDIT 15 Apr 2022 - I have confirmed the model code information is correct as verified with page 587 from the hybrid owner's manual.
    gmcguire7220 and Mattedfred like this.
  4. Apr 2, 2022 at 7:18 PM
    #394
    toddtonis
    toddtonis New Member
    2015 Tundra 1794 4x4 CM
    stock
    Hello, new member here. I was reading this payload sticker thread and also watched the video above that JamesAS posted where the Toyota engineer references an SAE J2807 specification for towing on light duty trucks which are below GVWR of 8500lbs. I believe that this spec. already has cooked into the load rating a driver and passenger weight of 150 pounds each (yes, very light people) as well as tow hitch equipment of 70 pounds. That is a total of 370 pounds that is already calculated into the load carrying capacity. So the sticker that gives the load rating has already included some weight for the driver and single passenger and tow hitch equipment in that posted number. Additional passengers and luggage are not included.
    Can someone on this forum check my assumption on this SAE spec. and let me know if I'm interpreting it correctly? This may be a source of why actual truck weights on scales and sticker weights aren't aligning. But, I'd like someone else who is knowledgeable on the SAE spec to weigh in.
  5. Apr 2, 2022 at 7:28 PM
    #395
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    I don’t think that’s correct. The language on the door jamb says “occupants and cargo” not to exceed XXXX lbs. A driver and passenger are occupants, so I don’t think this number assumes there are two people in the cab. Cargo includes anything else you put in the truck that wasn’t there when it left the factory, whether that’s in the bed or cab. Notice how your truck may have an extra little yellow sticker that says “payload reduced by _____”…this refers to port- or dealer-added options such as spray-in bed liner, steps, console safe, etc…
    Any occupant and anything added to the truck after the factory counts against the payload number.
    The one thing I think the door jamb capacity number assumes is that you have a full tank of fuel. Fuel is neither an occupant, nor is it cargo. The capacity to hold 38 gallons is one reason why payload is so low on these trucks. That door jamb number accounts for fuel.
    Cpl_Punishment likes this.
  6. Apr 2, 2022 at 7:45 PM
    #396
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    I did read the same information regarding two 150 lb passengers in an on-line article at RV-project.com but I don’t know whether it’s accurate. I’d like to read the SAE J2807 standard but I’m not interested in the $87 price tag.
  7. Apr 2, 2022 at 7:50 PM
    #397
    toddtonis
    stock
    Thanks for the reply. I went back and reviewed the details of the SAE testing statement I found and re-read it after reading your response. I think I see my mistake. These weights (driver, passenger, and hitch equipment) that I referenced are used during the acceleration, braking, and cooling tests for SAE when calculating max. trailer weight rating, not the load carrying capacity. I think that was where I got confused.
    Here is what I saw (taken from an article found on Jalopnik discussing SAE J2807):
    SAE J2807 also uses a specific set of assumptions to calculate maximum trailer weight ratings:
    • For light-duty full-size pickups (GVWR < 8,500 lbs.), SAE J2807 assumes that the tow vehicle includes any options with higher than 33 percent (market) penetration;
    • It assumes there is both a driver and passenger in the vehicle, each weighing 150 pounds;
    • It assumes that tow vehicles also include up to 70 pounds of aftermarket hitch equipment (where applicable)
  8. Apr 2, 2022 at 7:53 PM
    #398
    mass-hole
    This would make sense if each individual truck had its own payload number on the door sticker. But that is not the case. There are only like 8 possible payload values even though there are probably 100 different possible cab, bed, drive and option configurations. Toyota seems to just be slapping generic labels on everything.
    all J2807 says is that the GCWR need to include 300 lbs of passengers and 75 lbs(i believe) of WDH, if required, when they are calculating the maximum trailer weight.
    so basically, they can’t advertise the maximum trailer weight assuming an empty truck.
  9. Apr 2, 2022 at 8:00 PM
    #399
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I believe it may be calculated into the towing capacity but not into the payload capacity, which is most likely going to limit how much you can tow anyway.
    ETA: I see you reached this conclusion on your own already. :thumbsup:
  10. Apr 23, 2022 at 7:22 AM
    #400
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I have some encouraging information to share with everyone. I had picked out a 2022 SR5 crewmax, 4wd. The door sticker, like others here said 1395lb payload. Our local dealership is fantastic. They did a ton of searching, talking with toyota, etc. So we decided that when the truck came in we would take it to the scale down the road. They had the 33 gallon tank full for me. We weighed the truck, with no one in it. The GVWR listed on the door is 7210. The truck curb weight was 5560 lb. Do the math, you get a payload of 1650lb! I'm thinking that the payload listed on the door is considering a passenger weight(s) of 250lb. That's just a guess. I'm happy that the truck met our requirements (we will use it to tow a travel trailer). Proud new Tundra owners!
  11. Apr 23, 2022 at 7:39 AM
    #401
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    Congratulations on the new Tundra and the positive news regarding payload! Once my hybrid arrives, my first stop will be the Cat Scale two minutes from the dealership to get the true vehicle weight. Enjoy your new truck and you’ll have to post about your towing experience.
  12. Apr 23, 2022 at 12:26 PM
    #402
    xc_tc
    xc_tc New Member
    Definitely considering their heaviest spec, all factory options included.
  13. Apr 23, 2022 at 2:17 PM
    #403
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Me, I doubt J2807 applies to realworld towing. It's an arbitrary thing trying to get mfg'rs in a line instead of publishing whatever numbers they choose.
    Even meeting J2807 didn't prevent TFL's F150 and Silverado from overheating towing at high altitude. The good news is TFL's '22 Tundra didn't overheat towing at high altitude.
    Mattedfred likes this.
  14. Apr 23, 2022 at 2:21 PM
    #404
    That math, even if correct, still doesn't change the payload rating of the truck. It may make you feel better about exceeding the payload number assigned by the manufacturer, but that doesn't change the payload rating. That is determined by the manufacturer and unless you are getting it officially/properly recertified the official payload rating stands. Same goes for if you replace springs, struts, or add air bags. That rating is determined by the manufacturer and you can't change it.
  15. Apr 23, 2022 at 2:56 PM
    #405
    Terndrerrr
    Music City
    6UR-FE
    Disagree. It does change the available payload. GVWR is the number anyone cares about. Assuming those scales aren’t way off, Toyota put the wrong number on the door to reach GVWR.
    In the event that he gets forced onto some scales to be weighed (which I don’t think will ever happen, by the way), they’re going to compare his weight to the GVWR on the door jamb, which happens to take 1650 lbs added to the truck to reach, not 1395 like the door jamb says.
    They’re not going to take everything and everyone out of the truck and make sure it doesn’t exceed 1395 lb.
    JamesAZ and Cpl_Punishment like this.
  16. Apr 23, 2022 at 3:11 PM
    #406
    Nope. Doesn't increase it. You'd have to be certified to rate it. I'm speaking in the most strict sense of it, and it can't legally be done. Whether there would be reprecussions or issues is a completely different conversation. Google it. EVERYTHING will tell you you can't increase payload ratings.
  17. Apr 23, 2022 at 3:17 PM
    #407
    Terndrerrr
    Music City
    6UR-FE
    I get what you’re saying. But I’m speaking practically. He can put 1650 lb in his truck before hitting GVWR. That’s all anyone is ever going to measure. No one is ever going to know that he has more than 1395 as long as he has less than 1650 because all they’ll measure is gross weight.
    250 lb leeway isn’t insignificant. Good news indeed!
  18. Apr 23, 2022 at 3:29 PM
    #408
    I think somebody mentioned it earlier in the thread that they might be running 250 low in order to account for the driver. On average we are getting bigger as a nation after all. Tell me I'm wrong in thinking some bonehead out there would see a 1650 payload and think they could put a 1650 lb camper/load of mulch/side by side in the bed of their truck without leaving any room for a driver.
    Terndrerrr[QUOTED] likes this.
  19. Apr 23, 2022 at 3:30 PM
    #409
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    Agreed even CMV vehicles all that is ever measured is GVWR not payload
  20. Apr 23, 2022 at 3:31 PM
    #410
    Terndrerrr
    Music City
    6UR-FE
    Yeah you’re not wrong there!
  21. Apr 23, 2022 at 5:10 PM
    #411
    xc_tc
    xc_tc New Member
    The weight capacity does not exclude the weight of occupants. The sticker literally says it. Toyota doesn’t really make a sticker for each truck considering what factory options it has, it makes one sticker for each variation (VXKA35L-######) and it shows in the owners manual each configs load capacity.
    Archive likes this.
  22. Apr 23, 2022 at 5:15 PM
    #412
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The GVWR is the official number. The payload is just a calculation based on the GVWR and the curb weight.
    Let's say I have two trucks with GVWRs of 7200 lbs and payload stickers of 1500 lbs for some reason even though the first one weighs 5000 lbs and the second one weighs 7000 lbs. If I put 2200 lbs of stuff in the first one and 200 lbs in the second one, they're both within the manufacturer's capacity specs, despite what the payload stickers say.
    rruff and xc_tc like this.
  23. Apr 23, 2022 at 5:19 PM
    #413
    You're trying to apply true math to something that manufacturers have a huge amount of leeway with. They don't run a formula for it. I wish they did. It's nebulous and they phuck around with it for marketing all the time. But, the official payload rating of the truck is determined solely by the manufacturer and there is nothing the consumer can do to increase it.
  24. Apr 23, 2022 at 5:26 PM
    #414
    sparky412
    SW Pennsylvania
    It’s also a number in the real world that no one ever uses if you were ever pulled over by a Leo for weight reasons in a half ton truck the only number they would be concerned with is GVWR quit getting hung up on the payload number it means nothing
  25. Apr 23, 2022 at 5:31 PM
    #415
    Not hung up at all. Already said I'm just playing devil's advocate. Not saying people can't do as they please, and even if I were it wouldn't mean anything. It's the internet. Nothing is real. :p
  26. Apr 23, 2022 at 5:33 PM
    #416
    sparky412
    SW Pennsylvania
    I’m just saying if your payload sticker says 1300 pounds and you put 1400 pounds in your truck and you’re still under GVWR you’re fine
  27. Apr 23, 2022 at 5:34 PM
    #417
    sparky412
    SW Pennsylvania
    The only time anyone looks at a payload sticker when they slap it on the door jam other than that it’s not a number that is used for anything
    cnoyes72 likes this.
  28. Apr 23, 2022 at 5:35 PM
    #418
    I'm not saying anything different. I'm just saying you can't change your payload rating.
  29. Apr 23, 2022 at 5:36 PM
    #419
    sparky412
    SW Pennsylvania
    OK so you can’t change your payload rating but it’s worthless if it’s incorrect it means absolutely nothing
  30. Apr 23, 2022 at 5:37 PM
    #420
    I would refer you back to post 475 https://www.tundras.com/threads/payload-stickers.99329/page-16#post-2737898 as it explains the "logic" behind what was done with it. Companies have to account for customers being entitled, litigious, and idiots.
