Please help me understand the Rear Sway Bar argument
Discussion in 'Suspension' started by gdiep, Feb 20, 2020.
  1. Oct 20, 2020 at 4:46 AM
    #61
    betotundra
    betotundra Toyota for Life
    Thanks.
    Very clear explanation, although I believe you missed a couple of important scenarios.
    Turning with pot holes on the road with and without rear sway bar.
  2. Oct 20, 2020 at 5:04 AM
    #62
    timsp8
    NY
    I think you’re mixing up packages and trims. TRD Off Road and Sport are packages, while the Pro is a trim, like the Limited, Platinum, and 1794. The TRD Off Road package adds stuff like different shocks and a skid plate and can be added to different trims.
    TTund16[QUOTED] likes this.
  3. Oct 20, 2020 at 6:52 AM
    #63
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    First thing I would check is my tire pressure.
    Second would be to add a couple sand bags to the back to see if it helped.
    Third, poly bushings.
    If those didn’t work, then I’d look at new shocks. If after the smoothest ride while still being able to tow effectively, the Fox shocks off a Pro are your best option (albeit expensive).
  4. Oct 28, 2020 at 1:34 PM
    #64
    Mr Bill
    Mr Bill New Member
    Bill
    2017 Platinum 5.7
    I need the 22mm bolt, washers, spacer and bushing from inside the link arm for the right side (I think both sides are the same) for the TRD PTR11-34070 rear sway bar. Anyone have that they want to sell? just those parts or the whole assy? Thanks!
  5. Feb 22, 2025 at 12:55 PM
    #65
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Is there any difference (aside from maybe a little extra ground clearance?) mounting the sway bar this way instead of under the diff?
  6. Feb 22, 2025 at 6:30 PM
    #66
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    it gets mounted like that due to either lifting or lowering the truck
  7. Feb 22, 2025 at 7:24 PM
    #67
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You want sway bar end links to be perpendicular to ground.
