Please show me your 285/70/17's
Discussion in 'Wheels & Tires' started by Highsierraguy, Oct 13, 2019.
  1. Sep 4, 2021 at 7:30 AM
    #61
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    Anybody have to Re-gear… or feel their truck is sluggish? With 285/75/17?
  2. Sep 4, 2021 at 1:16 PM
    #62
    Andrew4776
    Andrew4776 New Member
    Andrew
    2018 tundra trd off-road
    I have 275/75/18 with KO2, about an inch smaller than 285/75/17. Feels more sluggish than oem, but it’s surely gonna feel slower. The bigger tire is completing less rotations/mile, so it’ll require more power. Lightweight wheels can somewhat suppress that by reducing the weight of the entire wheel slightly but nothing significant.
  3. Feb 15, 2022 at 11:28 AM
    #63
    big_green_tundra
    big_green_tundra New Member
    I’ve been going back and forth between 17 and 18 wheels and think I’ve landed on going forth with 17’s. I am getting the nitto ridge grapplers 285/70/17 C rated paired with method mr316 17in 8” wide and +25 offset…my questions is what does the width of the tire do between 8, 8.5 or 9 inches? Pros/cons? I just know to get the +25 offset I had to go with 8in wide wheels.
    Picture of the tires sitting next to truck below in case others were interested
  4. Feb 15, 2022 at 12:43 PM
    #64
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Here are mine. I still get big tire envy but I do think these are better than the stock 18s with 275/65/18.
  5. Feb 15, 2022 at 2:13 PM
    #65
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Have you SuperCharged that truck yet?…… :wave:.. Waiting. :rofl:
  6. Feb 15, 2022 at 2:26 PM
    #66
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    No I wish. :( I can only hide mods from my wife in increments of $1k.
  7. Feb 15, 2022 at 2:56 PM
    #67
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Yeah I hear ya… Bummer.. That doesn’t get you much these days!… I put a spending moratorium on myself after getting a $9000. Front bumper and lights install quote :eek2:… Crazy times Brother!.. Better to save your money right now… may need it for a loaf of bread… let me know if you need another set of those tires… got’ em sitting in my basement
  8. Feb 15, 2022 at 3:14 PM
    #68
    Kalash1794
    Kalash1794 New Member
    Murrayville
    2016 White OR 1794
    DD ditch lights Tyger blade Borla cat back OEM led headlights Excelon reference
  9. Feb 15, 2022 at 3:20 PM
    #69
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  10. Feb 26, 2022 at 12:24 PM
    #70
    big_green_tundra
    Method MR316 with 285/70/17 Falken wildpeak at3w SL
  11. Feb 28, 2022 at 11:25 AM
    #71
    4.6LBenchCrewMax4x4
    4.6LBenchCrewMax4x4 New Member
    Nice. Is this on stock suspension?
  12. Feb 28, 2022 at 1:02 PM
    #72
    big_green_tundra
    Yes all stock
  13. Mar 1, 2022 at 8:09 AM
    #73
    4.6LBenchCrewMax4x4
    Looks good. I have the same size tire and exact wheels on order. How much space do you have from the UCA and the tire? How much space is between the tire and fender at full Left and right turn? Do you think a set of spacers 1.25" could fit? Thanks
  14. Mar 1, 2022 at 6:43 PM
    #74
    big_green_tundra
    There’s alot of space between the tire and uca. I can it three fingers in between. No problem with full lock left/right turn. I did move the front flap forward by a 1/4” just by moving the screw slightly forward. No rubbing at all.
  15. Oct 25, 2022 at 10:47 AM
    #75
    scottiewarman
    scottiewarman New Member
    Scottie
    2019 White Tundra TRD Sport
    17x8.5 Method 307 with 285/70/17 BF Goodrich KO2 and Bilstein 5100
    Here's what I went with: 17x8.5 Method 307 with 285/70x17 BF Goodrich KO2 and Bilstein 5100 in the front.
    LD_15 and dpast88 like this.
  16. Nov 1, 2022 at 5:44 AM
    #76
    davenportkurt
    davenportkurt New Member
    Which offset did you go with? When I look they have 2 widths available ( 8 and 8.5) with different offsets.
    I assume that you can do the 8.5 width with 0 offset -or- 8 width with 25 offset and the net is the same as far as clearance/trimming/etc. And the amount the tire protrudes out of the wheel well is similar as well?
  17. Nov 1, 2022 at 12:20 PM
    #77
    scottiewarman
    Scottie
    Mine is a 0 offset which I like the look of. I don't have any issues with rubbing. IMG_9512.jpg IMG_9513.jpg IMG_9514.jpg IMG_9515.jpg
  18. Nov 1, 2022 at 6:01 PM
    #78
    davenportkurt
    Thanks for the reply. It just concerns me that you have the modified front suspension. Mine is all stock.
    Also, any regearing/reprogramming done or needed after the wheel change ?
  19. Nov 7, 2022 at 5:55 AM
    #79
    davenportkurt
    I thought as a potentially useful follow up to this .. the Method MR316 +25 will not fit (according to local shop) on the 2nd Gen based on brake placement. It seems fine on 3rd gen forward. I decided to go with the Method MR316 0 offset with 285/70R17 BF Goodrich tires. Technically not installed yet but should be fine w/o need for any modifications.
  20. Nov 7, 2022 at 6:09 AM
    #80
    king.cong.1119
    king.cong.1119 New Member
    285/70 R17 KO2 on stock suspension
    285/70 R17 on 2inch lift front and 1inch lift back.
    QuikreteTundra and J&ATundra like this.
  21. Jul 12, 2024 at 1:28 PM
    #81
    pg_osborne89
    pg_osborne89 New Member
    Method 703 17x8.5 35mm offset. Toyo AT3 285/70. OME BP51 with Dakars. Approx 2.5” lift all around.
    Referenced this thread a lot when considering tire size so figured I’d return the favor.
    RealTruck likes this.
  22. Jul 12, 2024 at 1:59 PM
    #82
    RealTruck
    RealTruck New Member Vendor
    The 703's bring the whole look together. Primo choice!
    pg_osborne89 likes this.
  23. Jul 12, 2024 at 4:49 PM
    #83
    pg_osborne89
    Thanks. I am quite pleased.
  24. Jul 12, 2024 at 4:54 PM
    #84
    ravingndrooling
    ravingndrooling New Member
    2021 Gray TRD
    Just got ‘em! FN Six Shooters, 17x9,+25, new made in the USA Nokians! Love ‘em
    Dustin at FN was cool as hell to deal with as well. New center caps coming.
  25. Jul 25, 2024 at 3:26 PM
    #85
    BigMike22
    BigMike22 New Member
    You made a better call getting the Falkens versus Nitto's. I have heard so many good things about those Wildpeaks, from quiet road noise to last a long time, man. I have heard the Ridge Grapplers are hyped up and don't do as well on wet surfaces. I don't know, though, just what I have been reading.
  26. Jan 16, 2025 at 10:00 AM
    #86
    QuikreteTundra
    QuikreteTundra Previously owned '16 Tacoma SR5 Pro
    '21 Tundra Cement TSS OR 4x4 | '23 T4R Lunar TRD ORP
    This is the tire size I'm looking at getting but with a Method 317. What are your wheel specs? 17x8.5 with 0 offset / 4.75" backspacing? And you're on stock suspension as well?
