Power inverter project...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dragracer_Art, Sep 2, 2020.
  1. Sep 19, 2020 at 9:11 PM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    Any info on the build? I'm reading up on solar for the shed then ultimately house. This would be cool if I could do it for the truck. I dont have a sun roof so that'd be perfect.
  2. Sep 20, 2020 at 5:36 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    starts here. goes for a pages.
  3. Sep 20, 2020 at 7:07 AM
    jsquared22
    jsquared22 _________________
    2018 White Tundra Platinum
  4. Sep 20, 2020 at 7:41 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Another option for laptops that many forget about is a direct DC power adapter. After all laptops do run off DC power :)
    I kinda went down the same train of thought when I redid the solar setup in my truck and added a real inverter (1100W). I was thinking how to get a connection from the inverter for my Surface Pro's power adapter then found a DC one on Amazon for less than $20. Plenty of other uses for an inverter but if running a laptop is a primary use case then that's an option to check on.
    dgtulsaguy likes this.
  5. Oct 6, 2020 at 5:43 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I've ordered the switch, the relay, happened to buy the same Inverter, AC plugs, 4g cable, 80 amp fuse. Now to figure out where to mount these plugs as I'm not looking forward to cutting into anything.
  6. Oct 6, 2020 at 6:36 PM
    Linuxmale
    Linuxmale 2018 Tundra 2003 Tj
    Sault Sainte Marie, MI
    2018 CREWMAX TRD Off Road ( a Canadian import )
    I've been looking at adding a second battery and inverter to mine. With the battery being in the bed somewhere. One good source for thick cables that are longer is jumper cables. (cut the ends off)
  7. Oct 6, 2020 at 7:33 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    What an awesome setup! How did you configure this? Under the Radio/AC?
  8. Oct 7, 2020 at 3:44 AM
    Dragracer_Art
    Dragracer_Art [OP] New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    The inverter is under the middle of the back seat and held to the carpet with velcro. No holes or mods to the truck.
    The dash switch (powered by keyed 12v+) controls an 80 amp relay under the hood.
    The relay powers the inverter. (since the inverter switch is always on)
    The nice thing about the dash switch/relay combo is that the inverter is always "OFF" unless I need it.
    I haven't cut-in the 110v outlets yet.
    For now I just have a short 6ft extension cord run under the rear floor mat up to the front passenger seat. It works perfectly and has been used a few times already.
    fbingha[QUOTED] likes this.
  9. Oct 7, 2020 at 4:23 AM
    timsp8
    NY
    I got an amp wiring kit with 4 gauge wire. The wires are run, but the inverter was giving me issues. I returned it yesterday. Waiting on the new one to get here tomorrow to try again. I ran 17 ft of 4 gauge and it came with a 100 amp fuse that I’ll probably replace with a lower one. I am mounting it in the middle bin of the esp storage.
    Dragracer_Art[OP] likes this.
  10. Oct 7, 2020 at 4:27 AM
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    I still cant get over how much room there is in the back of these cabs.
    With the rear seat removed, it looks like a double bed mattress would fit in there perfectly. :rofl:
    timsp8[QUOTED] likes this.
  11. Oct 7, 2020 at 4:30 AM
    timsp8
    NY
    Yeah. The seats are still out waiting on the new inverter. Every time I look back there I think once the kids are gone and it’s just me and the wife, the backseats will stay out. So much more room.
  12. Oct 8, 2020 at 3:20 PM
    timsp8
    NY
    Got mine in finally. Used 17ft of 4 gauge wire to the battery and just grounded it to a bolt on the rear wall of the truck. I also mounted my cell phone booster.
    I originally tried a cobra inverter. I ordered a 1000w and a 1500w to see the size difference. But both gave me an olp error on startup, even when using their wires straight to the battery. I got a bestek pure sine wave one and it works so much better. I’m glad I got this one.
    I also did rear seat heat while I was at it. I am never taking the rear seats out again. It was a pain getting them back in.
    https://www.amazon.com/BESTEK-Inver...a-893003582327&psc=1&ref=&adgrpid=81184753329
  13. Oct 8, 2020 at 5:07 PM
    dgtulsaguy
    dgtulsaguy New Member
    18' 1794
    You sir are brilliant!
    Same goes with cordless tool battery chargers for those with inverter issues when trying to charge them.
    abomb60[QUOTED] likes this.
  14. Oct 11, 2020 at 8:22 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    About this .. I figure I needed about 15 ft of cable to wire this behind the back seat. 15 ft, 80 amps, that's 4 gauge on most charts. The 80 relay goes in the middle there somewhere and that has 10 gauge wire on it's harness for in and out. I'm flummoxed about what to do with this at the moment.
  15. Oct 12, 2020 at 10:46 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Decided the problem is the relay, so going to use one of these instead. https://www.amazon.com/Heavy-Duty-Relay-Split-Charge/dp/B07T35K8S2
  16. Oct 12, 2020 at 11:47 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    how's the weboost? might be my next addition to the truck...
  17. Oct 12, 2020 at 1:44 PM
    timsp8
    NY
    It works pretty good. My inside antenna is on the windshield next to the mirror mount and it seems like I have to have my phone around the console area to pick up the signal. But it’s given me a signal and internet when I didn’t have any without it. It seems like it adds a bar or 2.
  18. Oct 12, 2020 at 2:22 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    Try the Smoothtalker. I’ve installed thousands of those. To this day I’ve not found another booster that out performs and outlasts it. They are used more in industrial vehicles here in the hills and mountains.
  19. Dec 24, 2023 at 8:46 PM
    #49
    Kal149
    Kal149 New Member
    2022 Tundra SR5 4X2
    Nothing yet, brand new.
    What is the largest inverter I can install for the stock battery in my stock 2022 tundra SR5 4x2? I am considering installing a separate battery, but just wanted to ask.
    Mike59 likes this.
  20. Dec 25, 2023 at 3:25 PM
    #50
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Pretty vague question, but I’ll try…
    Powering from your battery without the truck running is a recipe for disaster.
    With the truck running, you have a big alternator that makes the juice!
    A 1,500w inverter can pull over 100A at 13.6V, which is the limit of my comfort level for a stock charging system. That’ll give you a 12.5A peak capacity at 120V.
    What are you hoping to run?
    Warreng and Mike59 like this.
  21. Dec 28, 2023 at 11:55 AM
    #51
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    I had a 500w inverter in my work van, and it wouldn't run hardly anything. Maybe a small drill.
    I got tired of fooling with it and installed a HF 2000W continuous/ 4000W. Now I can run my impact, drills, Sawzall, chargers, etc. I used size 2 wire to the van battery, grounded locally. Works pretty well.
  22. Dec 29, 2023 at 10:12 AM
    #52
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    really diggin this mod. Just thinking twice about where to mount the converter.
