Putco Blade LED Tailgate Light Bar
Discussion in 'Lighting' started by Storm, Oct 1, 2018.
  1. Oct 6, 2018 at 11:51 AM
  2. Oct 6, 2018 at 3:11 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Got one and ordered the Curt on Amazon, thanks OP! Did some research and the cheap ones just end up looking cheap especially when they start to fail.
    I watched these vids which answered all my questions, and a CDN Auto parts store discount this weekend sealed the deal!
    After install, gotta be an idiot to rear end me now.
  3. Oct 6, 2018 at 8:14 PM
    Storm
    Storm [OP] Elite Member
    2018 TRD SPT
    I agree! Just need to save my pennies!
  4. Oct 7, 2018 at 12:27 AM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Saw the same video that @JoshuaA posted and was going that route. But I like not having to splice any wires, thanks @Storm
    Looks even better on a white truck.
    Storm[OP] likes this.
  5. Oct 13, 2018 at 12:56 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    @Storm did you use the unconnected black wire in the quick connect harness?
  6. Oct 13, 2018 at 6:57 AM
    Storm
    2018 TRD SPT
    No, the black wire on the harness you will not use. Just the white wire for reverse.
  7. Oct 13, 2018 at 8:24 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Thank you
    Storm[QUOTED][OP] likes this.
  8. Oct 13, 2018 at 12:00 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Don’t want to assume, which wire in the bunch I exposed is the white from the Blade tapped into for the reverse?
    Cheers
  9. Oct 13, 2018 at 1:30 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    This forum has a bad influence on my wallet!
  10. Oct 13, 2018 at 2:21 PM
    Storm
    2018 TRD SPT
    Are you hard wiring it to your truck or did you purchase the quick connect harness? I did not have to open up any wire looms to tap into any wires. There is a white wire on the light bar itself and a white wire coming off of the harness.
  11. Oct 13, 2018 at 2:23 PM
    Storm
    2018 TRD SPT
    lol it sucked me right in! :spending:
    MotoTundra[QUOTED] likes this.
  12. Oct 13, 2018 at 2:24 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
  13. Oct 13, 2018 at 2:27 PM
    Storm
    2018 TRD SPT
    Ok I thought you were using the Putco harness. You're correct, you will need to tap into the reverse. I do not want to mislead you as I am not exactly certain which white wire you would have to tap in to. Hopefully someone on here could provide some insight...
    JoshuaA[QUOTED] likes this.
  14. Oct 13, 2018 at 2:41 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    Just look at the back of the 7-pin trailer connector. The one in the middle is the reverse. That's how I figured out which was which.
    phabej, 1UPPER and JoshuaA like this.
  15. Oct 16, 2018 at 4:50 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks! This worked great, I posi-tapped into the harness itself, white in the middle, easy! You're right Storm, the reverse is BRIGHT, glad I didn't skip it.
    Day or night, people seem to stay further back, awesome!
  16. Oct 16, 2018 at 5:44 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Never been a fan of under the gate lights.
  17. Oct 16, 2018 at 6:20 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    At one time I wasn't either, especially that dotted diode look. Then I happened to see it in person following a RAM the other day, it looked like it was OEM, I knew I wasn't returning it.
    A super bright clean solid light and the safety factor sold me. Not for everyone of course.
    NewImprovedRon, 1UPPER and MotoTundra like this.
  18. Oct 16, 2018 at 6:48 PM
    Storm
    2018 TRD SPT
    Glad it worked out!!
  19. Oct 16, 2018 at 7:39 PM
    #49
    TCREW
    TCREW New Member
    2018 Crewmax TRD
    Level kit sitting on 20s
    Guys I'm trying to hardwire an Opt7 led on the rear and having trouble noting the color code on the 7pin connector, the pics you guys posted above call out a brown wire. Does your harness match the pics ? My harness consist of red,green,black +,pink,blue,white -, yellow(in center)
  20. Oct 17, 2018 at 4:49 AM
    #50
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Did you buy an additional easy connect harness or are you referring to the Opt7 harness and you’re splicing? To be honest I didn’t look at any colors except the white reverse wire because the rest is plug and play using the Curt 55384. If you haven’t figured it out, I can take a look later/early evening when I’m home.
  21. Oct 17, 2018 at 5:01 AM
    #51
    TCREW
    TCREW New Member
    2018 Crewmax TRD
    No I didnt buy the curt harness ( actually wasnt aware before reading these post it was available) it got late late night so I pulled the splice off and temporarily plugged into the 4pin on the bumper next to the liscense plate. I am having no luck with finding the wiring diagram for the 2018 harness. If you find anything please let me know
  22. Oct 17, 2018 at 5:15 AM
    #52
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
  23. Oct 17, 2018 at 6:03 AM
    #53
    TCREW
    TCREW New Member
    2018 Crewmax TRD
    Thanks. The harness will be the option if I cannot get any clarification on the color code going into the 7pin. Thanks again
  24. Oct 17, 2018 at 5:57 PM
    #54
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    If you do don't mind asking you. How taillights holding so far and are they plug and play without any modification? Also what type of tails are that? Brand??
  25. Oct 17, 2018 at 6:23 PM
    #55
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    My led taillights are Recon with smoked lenses. They’ve been great! I’ve had them for 1 1/2 years. They are direct plug and play. Does that answer your questions?
    Storm[OP] and LKSR5-14[QUOTED] like this.
  26. Oct 17, 2018 at 6:24 PM
    #56
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks for answering. Any link where could get them? I may put them on my list
  27. Oct 17, 2018 at 6:27 PM
    #57
    1UPPER
    TEXAS
    Flux capacitor!
    Here is the website. All though you will find better prices from other vendors. They offer smoked, clear & red taillights. They also have the third brake light but it’s a pain to replace.
    https://gorecon.com/shop/?filters=car-make[toyota]|model[tundra]
    LKSR5-14[QUOTED] likes this.
  28. Oct 17, 2018 at 6:31 PM
    #58
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Thanks a lot notice that comes with two dark options, are yours dark or smoked? Sorry to everyone that I jumped into this thread. Sorry
    1UPPER[QUOTED] likes this.
  29. Oct 17, 2018 at 7:28 PM
    #59
    Storm
    2018 TRD SPT
    The harness should you choose to go that route will give you the ability to plug the 4 pin into the harness which in turn will plug into the 7 pin. I am not exactly sure of the color codes on the 7 pin. But for the basics, the 4 pin will give you the same functionality. Although you will still need to tap into white for the reverse. The Putco harness gives you a white wire on the harness which taps out of the 7 pin.
  30. Oct 17, 2018 at 8:47 PM
    #60
    1UPPER
    TEXAS
    Flux capacitor!
    Smoked.
