RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Oct 18, 2023 at 8:01 PM
    #871
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Factory USB-C port OPTION 1 (2020 / 2021 trucks only)
    Toyota part number 85532-08040 is a unit with one USB-A / one USB-C.
    The back of this particular unit has the exact same connector socket as the dual USB-A connector that comes in our trucks from the factory (connector part number is 90980-12D25 if you want to know). Bought this one on ebay for $25 (used). Note the little flap covers are NOT spring loaded like the original USB-A ones - they stay up like the CarPlay port does.
    It is a quick process to pop out the lower dash area, pop out the old unit, plug in the new unit, and put the dash piece back in. Confirmed that both ports provide power (don’t expect 45W PD here, but it is at least decent standard charging speed - should be ~25W).
    Factory USB-C port OPTION 2 (2020 / 2021 trucks only)
    Toyota part number 85532-0E100 is a unit with two USB-C.
    The back of this unit does NOT directly match up with the connector in the truck wiring harness. Instead, it requires a grey connector (part number 90980-12B59), which the Toyota Parts place I ordered from told me the one I bought was the only one in their system in the US…
    If you can score the connector, then you will need to de-terminate the one in the truck and plug in the new one to the two terminals (both connectors use the same terminals - they are just a mirror image of each other).
    Otherwise, you could try modifying the connector on the wiring harness or the port on the new socket so that it fits.
    And here is a view of the two connector sockets side-by-side. Black (right) is the factory socket while grey (left) is this new socket.
    Wallygator, eSkittles, Do58 and 11 others like this.
  2. Oct 18, 2023 at 8:04 PM
    #872
    RainMan_PNW
    Casey
    Clark County, WA
  3. Oct 18, 2023 at 8:06 PM
    #873
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  4. Oct 18, 2023 at 8:08 PM
    #874
    RainMan_PNW
    Casey
    Clark County, WA
    If only they’d sponsor an onx6 for my roof rack…
    SAGE63, FrenchToasty and bulldog93 like this.
  5. Oct 18, 2023 at 8:15 PM
    #875
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    if only they’d sponsor any of us plebes…
  6. Oct 18, 2023 at 8:21 PM
    #876
    RainMan_PNW
    Casey
    Clark County, WA
    I know, right?!
    Blue Thunder and TaquitoBandito like this.
  7. Oct 18, 2023 at 8:32 PM
    #877
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    There was a 50” 6plus for 500 bucks a few weeks ago. Was first in line when it popped up at 7pm and had to choose between a great deal w/ a spousal fight or no light bar and I get to sleep in my bed. I don’t drive at night really so I chose my bed. Kinda kicking myself in hindsight as I coulda scored the deal for someone on here.
    I’ll keep my eyes peeled for ya
    WILLINH, SAGE63, Blue Thunder and 6 others like this.
  8. Oct 18, 2023 at 8:49 PM
    #878
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Any chance of making the USB covers spring-loaded using springs from the old ones?
    Tripleconpanna and Mater like this.
  9. Oct 18, 2023 at 9:02 PM
    #879
    RainMan_PNW
    Casey
    Clark County, WA
    Not unlike eyeballing bronze BBS heritage wheels
  10. Oct 18, 2023 at 9:05 PM
    #880
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @AZBoatHauler LC has been in your dreams, hasn’t it.
    Fotnot, AZBoatHauler, Mater and 2 others like this.
  11. Oct 18, 2023 at 9:06 PM
    #881
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t really think so. The lids/hinges are designed differently with a recess and stuff for the spring and a rubber “stop” over the port to make it not bang closed vs a friction hinge and a snap that holds the lid fully closed.
    Personally, I like that they don’t spring closed while I’m trying to plug in the cord.
  12. Oct 18, 2023 at 9:08 PM
    #882
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  13. Oct 18, 2023 at 9:10 PM
    #883
    FrenchToasty
    Mo
    Bone stock
    This was one of me and my buddies favorite lines to quote after saying something outlandish, another common theme was, “if I pushed you off this cliff into a bunch of jumping cholla, would you still be my friend?”
  14. Oct 19, 2023 at 8:23 PM
    #884
    RainMan_PNW
    Casey
    Clark County, WA
    Updated this post with the second option for factory USB-C charging port.
    Currently, I’m sticking with option 1 because it’s kind of nice to have both options without having someone plug into my CarPlay port for USB-A charging. I may change my mind though…
    WILLINH and Blue Thunder like this.
  15. Oct 21, 2023 at 10:25 PM
    #885
    RainMan_PNW
    Casey
    Clark County, WA
    Spent some time today prepping some lights. I prefer the Sumitomo connectors that Toyota uses over the style BD uses, so I cut off their factory connectors and put these ones on.
    Gotta get some different hardware for installing the chase lights to my rack (the S2 brackets have a 3/8" bolt hole in them, but the t-nuts for the rack cross bars can only be gotten in 1/4"). Going to look at some different hardware for the ditch light mounting as well.
  16. Oct 21, 2023 at 10:33 PM
    #886
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I really curious to see how those squadron lights mount up. Can't remember if you still have OEM front bumper or not, but when I've looked at the the BD website for those squadron driving lights, it looks like they still use the same mounting to plastic bezels, which is a no go for me. Hard to tell from webpage instruction pics.
    I currently have the OEM rigid driving lights cable tied to stop from shaking so bad.
    RainMan_PNW[OP] likes this.
  17. Oct 21, 2023 at 11:08 PM
    #887
    RainMan_PNW
    Casey
    Clark County, WA
    EDIT 4/6/25 - Scrapped this plan in favor of the Bullet Proof Diesel mount outlined at this link.
    Small steps on the comms installation as well. I'm going to dedicate this post to the antennas, while the previous post will be focused on the actual radio install.
    The plan is to mount two NMO antenna bases to the Sherpa rack and combine them via a duplexer to route a single coax into the radio.
    Antennas:
    Rugged Radio Stealth GP VHF
    Rugged Radio Stealth GP UHF
    Mounts & Wiring:
    Larson NMOKHFUD (x2) these have 17' of RG58 coax attached to each one
    Larson TMB34B angle brackets (x2)
    Larson NMOCAPB rain caps (x2) (we'll see how much I use these)
    Amphenol UHF Male Crimp Connectors (4 pack)
    Coax Seal
    8020 10-series Stainless 10-32 Roll-in T-Nut with Ball Spring (PN 3669)
    Duplexer:
    Comet CF-4160 J (UHF Female connectors on all three connections)
    There will also be various wire routing appurtenances as this progresses.
    As part of the process, I was trying to find the ideal method for running the coax from the roof rack and also where to mount the duplexer. Ideally, I want to run a single line down from the roof to make it easier to conceal and one less thing through the firewall. I looked at weatherproof enclosures that I could mount on the rack somewhere and wasn't having a lot of luck finding something that wasn't monstrous in size. So I reached out to Comet directly and asked them about ideas, and their President replied back within an hour and suggested that I could "simply remove the back panel, apply a silicone bead around the edges and the screw holes, and seal the connectors with coax seal or similar." He followed up stating to check it every so often to ensure it is sealed, but that Motorola has hundreds of them sealed the same way in use without issues.
    So I pulled the five screws from the back plate and applied a liberal amount of black silicone RTV to the edge and screw holes and mounted the plate back down. I also plan on trimming a piece of ABS sheet and sealing it to the back of the Comet in a "sandwich" when I bolt the Comet to the underside of my rack crossbar.
    41FA6084-314C-4345-B4D4-7C471BC5A9A5_1_201_a.jpg 88D651A2-8A0F-4EBC-B195-82592D766434_1_201_a.jpg 152A964E-F353-4D47-92FA-12080A126592_1_201_a.jpg
    Today I made up a secondary back plate for the duplexer out of 1/8” thick ABS and sealed it to the back of the duplexer using a bunch more RTV. Currently it’s being held on with a couple machine screws while the silicone cures.
    More to come...
  18. Oct 22, 2023 at 10:14 AM
    #888
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    couldn't have just used the BPD mount and NMO to SO-239 adapters to remote mount your antenna's to the rack?
  19. Oct 22, 2023 at 10:16 AM
    #889
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Casey right now:
  20. Oct 22, 2023 at 10:36 AM
    #890
    RainMan_PNW
    Casey
    Clark County, WA
    True
    But that also makes the BDP TBL the equivalent of a $500 cable grommet. :D
    It’s gonna look very nice on Cruzer’s DCSB build, and those funds got me ditch and chase lights.
  21. Oct 22, 2023 at 10:37 AM
    #891
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    JSON sees no issue with this
  22. Oct 22, 2023 at 10:38 AM
    #892
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  23. Oct 22, 2023 at 10:41 AM
    #893
    RainMan_PNW
    Casey
    Clark County, WA
    I’m trying to build to JSON spec without spending JSON money. It’s not easy…
  24. Oct 22, 2023 at 7:49 PM
    #894
    RainMan_PNW
    Casey
    Clark County, WA
    Hit a Yahtzee on the ODO while driving into town today.
    Also swapped out the S2 reverse light lenses for work/scene pattern.
  25. Oct 22, 2023 at 10:25 PM
    #895
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    I had to play that on my 6’s to get the bonus points. :(
  26. Oct 23, 2023 at 12:01 AM
    #896
    SAGE63
    San Diego County
    damn Casey you have some miles on your 21.... Almost double mine. I took my 21 home on 26 Oct 2020...
    bulldog93 likes this.
  27. Oct 23, 2023 at 6:35 AM
    #897
    RainMan_PNW
    Casey
    Clark County, WA
    It was either 10/28/20 or 10/29 when I drove mine home.
    Tripleconpanna likes this.
  28. Oct 23, 2023 at 6:38 AM
    #898
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Yeah I just hit the 66666 mark on my 2016 a few weeks ago haha
  29. Oct 23, 2023 at 7:10 AM
    #899
    Kung
    KG, VA
    @RainMan_PNW - do you have the first one working in your vehicle? I'm not so worried about charging speed...but if it works, hooray!
  30. Oct 23, 2023 at 7:24 AM
    #900
    SAGE63
    San Diego County
    cool....
