Ramps, jackstands, or…….?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Nov 19, 2023.
  1. Nov 19, 2023 at 8:35 AM
    Oldandfat
    Oldandfat [OP] New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    Just curious what y’all are using?
    as I am fat, I’m able to just barely slide under the tundra for oil changes. I was able to instal running boards.
    I will at some point need to remove/retorque my cat shield. Myke (asylumdezyns) used a pair of rhino ramps to instal. They were pretty slick.
    I do own a badlands Jack, and a set of 3 ton, and 6 ton Usjacks Jack stands.
    the Jack stands are cumbersome. Rhino ramps seem like there’d be easier, and they are on sale at our local “Ukrainian tire” stores.
    was also thinking of glueing some 2 x 12 pieces together to slide under the front tires.
    if I’m really feeling spendy, raceramps sell ramps, and blocks made of foam. Very lightweight but $$$.
    Quickjacks are cool but possibly more than I want to spend. They seem cumbersome to use, but we have 3 vehicles to change oil / winter tire swap.
  2. Nov 19, 2023 at 9:26 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I wouldn't get quickjacks, I have them and you'd need all the extensions in order to lift the truck any. Just use the jack and stands, the other two options will require spending and storage space.
    RickyBobbysTundra likes this.
  3. Nov 19, 2023 at 9:31 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  4. Nov 19, 2023 at 9:33 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    12 ton jack stands for the added height. I don't even bother with 6 tons since they're so short.
  5. Nov 19, 2023 at 9:36 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Run your truck into a shallow ditch (perpendicular) and position the oil pan over the deepest part. Slide under and get to it. Cost: free fitty.
  6. Nov 19, 2023 at 9:37 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    831Tun[QUOTED] likes this.
  7. Nov 19, 2023 at 9:40 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The concept is simple enough, a properly cut block of wood would almost do the same thing. There is the possibility of the wood splitting though.
    joonbug likes this.
  8. Nov 19, 2023 at 9:41 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    These are the 16K Rhino Ramps under my Tundra. You can only use these on a solid surface such as concrete or asphalt.
    I use my air jack the most and my NAPA 3.5 ton floor jack when I need more stability or just need two jacks.
  9. Nov 19, 2023 at 9:44 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Could make it outta notched box channel steel.
  10. Nov 19, 2023 at 9:49 AM
    Oldandfat
    Cannuckastan
    Usjack 6 ton has 25” height. Their 10 ton is 28” but it’s 700 bucks. That’s raceramps territory
  11. Nov 19, 2023 at 9:50 AM
    WBW
    WBW Resident lurker
    Bruce
    Just for reference, I took a screenshot of the NAPA 3.5 ton floor jack that I use. I've had it for somewhere around 20 years without any issues at all.
  12. Nov 19, 2023 at 9:51 AM
    Oldandfat
    Cannuckastan
    who is “they”?
  13. Nov 19, 2023 at 9:51 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ProEagle
  14. Nov 19, 2023 at 9:52 AM
    Oldandfat
    Cannuckastan
    does the garage floor have to be perfectly level? We have a drain in the floor, so there’s some slope.
    also, tell me more about this air Jack?
  15. Nov 19, 2023 at 9:55 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well yeah but the size of wood for that is nowhere near what you'd fit in between the wheel axle on a jack and its support pad.
  16. Nov 19, 2023 at 9:55 AM
    Oldandfat
    Cannuckastan
    I can’t see the wood splitting. (Not using it on edge). Even just 2 2x12’s glued together would give me 3” of lift. That’d be enough to comfortable to an oil change at least
  17. Nov 19, 2023 at 9:56 AM
    WBW
    WBW Resident lurker
    Bruce
    The floor just needs to be solid and flat under the ramps. All four corners should be touching the floor before driving up on them.
    I bought the air jack on Amazon for my trailer because the floor jack is really heavy and I'm pushing weight limits on it when it's loaded. I'll try to post up a link for it.
  18. Nov 19, 2023 at 9:57 AM
    Oldandfat
    Cannuckastan
    no, I’m talking about 2 x 12’s (15” or so pieces) glued together so I can drive up on them, or Jack the truck, and then slide the wood under the tires. Kinda like a rhino ramp. im just looking to get room under neath the truck for oil changes, and removing the cat plate
  19. Nov 19, 2023 at 9:58 AM
    WBW
    WBW Resident lurker
    Bruce
  20. Nov 19, 2023 at 10:00 AM
    Oldandfat
    Cannuckastan
    where do they say this? I’m on their website right now. Did they say outright no, or did they say “we don’t recommend use of non pro eagle accesories on non pro eagle jacks for safety reasons”?
    I’ll bet it will work. They don’t want to say so for obvious reasons.
  21. Nov 19, 2023 at 10:01 AM
    Oldandfat
    Cannuckastan
    sold! lol. Screw quickjacks
    WBW likes this.
  22. Nov 19, 2023 at 10:04 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I see no issue with the way you're talking about using wood. I was referring to using a smaller piece of wood in lieu of the Pro Eagle jack stop.
    joonbug and texasrho83 like this.
  23. Nov 19, 2023 at 10:07 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Same.
  24. Nov 19, 2023 at 10:09 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'll look real quick.
    By the way, did you see these?
  25. Nov 19, 2023 at 10:30 AM
    Oldandfat
    Cannuckastan
    I did not but I like those! My usjackstands are fine, but they are heavy and cumbersome.
  26. Nov 19, 2023 at 10:35 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I plan on getting a set. They aren't expensive.
  27. Nov 19, 2023 at 10:37 AM
    Oldandfat
    Cannuckastan
    ^ they are almost 100 less than my us jacks, and they ship free. Not a bad deal.
    but the Jack stands need to go where the Jack point is. Have you jacked fr from the front cross beam? It looks thin.
  28. Nov 19, 2023 at 10:42 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I usually stick my stand under the shock mount.
  29. Nov 19, 2023 at 12:26 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    This exactly! I quit using floor jacks years ago when I quit rotating my own tires (have Big-O do that now). Drive up on the ramps, you're done, no need to scoot around placing jack stands, one side then the other. I will have my oil draining before that is done using ramps. Simple, easy, safe.
  30. Jan 8, 2024 at 8:18 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Brand new cabin air filter!
    Any thoughts on Harbor Freights ramps? Anybody have these? Compared to the Rhino ramps
