RCI Skid plate. Aluminum or steel?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Robster80, Jul 1, 2021.
  1. Jul 3, 2021 at 8:12 AM
    15whtrd
    15whtrd Mr. Blonde
    I did this with all the hardware. Took a little time matching up all the little nuts, bolts and washers at home dump, but I think it was worth it. Added a little anti-seize to the ones that go into blind holes.
    Acedude likes this.
  2. Jul 3, 2021 at 8:17 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Same actually. Lotsa salt here in Wisco. Didn’t use anti seize but coated with MPHD. Probably still take them off once a year and check them. Hate rust with a passion.
    15whtrd[QUOTED] likes this.
  3. Jul 16, 2021 at 7:59 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Adding a used Red steel (shop painted) RCI with hardware for $200 Canadian (he even delivered) to my truck shortly.
    No damage. Bolts are not seized. 1 year old. He traded into a 4Runner.
    Black Wolf likes this.
  4. Jul 16, 2021 at 10:24 PM
    cain0725
    cain0725 New Member
    that for a new tundra?
  5. Jul 17, 2021 at 4:12 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Do you happen to remember the specs of the oil filter door bolts ? Just installed my plates last week.
  6. Jul 17, 2021 at 4:47 AM
    I simply used gorilla glue. No need to mess with tape. :thumbsup:
    15whtrd likes this.
  7. Jul 17, 2021 at 5:55 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m sorry, I don’t. I did it all rudimentary, I matched up bolts in hand at the hardware store.
  8. Jul 17, 2021 at 6:05 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Believe they are 10mm x 1.5mm x 70mm(1”)
    15whtrd likes this.
  9. Jul 17, 2021 at 9:29 AM
    BayRunner
    2017 Tundra Platinum
    If I remember correctly, I believe this is correct. I had to replace my access door bolts and Lowe’s had what was needed.
    Barrett50[QUOTED] likes this.
  10. Oct 30, 2021 at 7:57 AM
    cat3
    cat3 New Member
    2010 Tundra SR5
    What is the forum discount code? Yes, I searched-couldn't find it.
  11. Oct 30, 2021 at 8:53 AM
    AZBoatHauler
    So.Arizona
    I’m not aware of one but tagging
    @RCIoffroad for you.
  12. Oct 30, 2021 at 9:20 AM
    CTundraForMe
    CTundraForMe New Member
    Try tundraforum
    Black Friday deals will be coming up, if you can wait...
  13. Oct 30, 2021 at 9:30 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    How does the steel coating hold up to salt and corrosion?
  14. Oct 30, 2021 at 11:00 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Steel is my vote...
  15. Oct 30, 2021 at 3:07 PM
    AZBoatHauler
    So.Arizona
    I went aluminum and if you plan to wheel it hard and often I’d recommended steel. I’ve definitely moved / removed a fair amount of aluminum on mine.
  16. Oct 30, 2021 at 8:36 PM
    cain0725
    cain0725 New Member
    waiting in black friday deals, following
    Damie Street likes this.
  17. Oct 31, 2021 at 6:38 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    I went with Aluminum, but it all depends on your overall use & goals.
  18. Dec 9, 2021 at 2:47 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Added a new in box, steel, powdercoated, transmission skid for $150cad today.
    Both will be installed in spring. I have to get new hardware for the front.
  19. Dec 9, 2021 at 3:02 PM
    #49
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I say steel also. Stronger and cheaper, win win for me. Granted I dont live where rust is an issue.
    Side note, does anyone know if these plates can be used as a jack point in the center or should i stick with the crossmember area?
  20. Dec 9, 2021 at 3:02 PM
    #50
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I would not use them as a jack point
  21. Dec 9, 2021 at 3:05 PM
    #51
    MadMaxCanon
    Didnt think so.....I guess thats one big benefit of the TRD Pro skid.
  22. Dec 9, 2021 at 3:18 PM
    #52
    Wallygator
    I had aluminum on my 4runner and it was well worth the price for the weight savings I felt was needed for that vehicle. Went with steel on the Tundra due to sufficient power and because of the weight of the Tundra. RCI makes a quality product no matter which material you choose.
    Spyker likes this.
  23. Dec 9, 2021 at 3:57 PM
    #53
    1/4" aluminum is approximately less than 20% in strength than 3/16" steel. Not bad. I think the RCI Aluminum skids are 1/4".
    Wallygator and Spyker like this.
