Rear seat fold down mod
Discussion in 'General Tundra Discussion' started by joonbug, Oct 29, 2016.
  1. Oct 30, 2018 at 5:57 PM
    #61
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    You lift the bottom up about 30 to 45 degrees. The back rises at the same time and releases the shortened hooks.
    TomC843 and 15whtrd like this.
  2. Oct 30, 2018 at 7:04 PM
    #62
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I think this would be good mod
  3. Oct 31, 2018 at 6:57 AM
    #63
    tanabersx
    tanabersx New Member
    Miguel
    Puerto Rico
    2017 Tundra DC SR5 XP
    When you lift the bottom part of the seat, the top half slightly slides up. The stock bracket holds the top part of the seat in place so that it slides up and down. When you cut it, you allow the seat to come forward when it slides up and lock on the hinge when it slides down. Think of it as some sort of magic!
    Part_time[QUOTED] and 15whtrd like this.
  4. Oct 31, 2018 at 6:38 PM
    #64
    Part_time
    Oregon
    Ok one last question does it make it a pain in the ass to access the storage under the seat?
  5. Oct 31, 2018 at 6:42 PM
    #65
    15whtrd
    15whtrd Mr. Blonde
    No it’s the same. Just have to make sure the seat back is up against the back wall as you drop the bottom back into place. Just so that it hooks again.
    JMB likes this.
  6. Oct 31, 2018 at 6:45 PM
    #66
    Part_time
    Oregon
    Copy that
    15whtrd likes this.
  7. Dec 30, 2018 at 1:40 PM
    #67
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    This is a great mod! Anyone come up with a clean solution to cover the back of the seat when folded down? My old 2010 CM had fold down with hard molded plastic on back of the seat. Would we great to come up with similar protection.
  8. Mar 5, 2019 at 12:42 PM
    #68
    FredD
    FredD New Member
    2016 Barcelona Red Ltd
    For those who have done this mod, does the rear seat back stay in the upright position when you lift the seat bottom? Meaning do you have to manually pull the rear seat back down? I'd like this to be the case, so if I add a rifle rack in the back, it won't 'show itself' when I lift the seat bottom.
    joonbug[OP] likes this.
  9. Mar 5, 2019 at 1:16 PM
    #69
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, if you pull the bottom up, they stay in the upright position.
    FredD[QUOTED] likes this.
  10. Mar 11, 2019 at 6:29 AM
    #70
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    They rear seat headrests fold down on my 2016 D.C. The middle one doesn't cuz it's a tiny one but the two side ones do. I just remove the center one so I can see out the window but others stay in folded down.
  11. May 6, 2019 at 9:33 PM
    #71
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m trying to figure out why I haven’t done this yet. I’ve had a whiskey or two, but it still seems like I should have done this by now. I must be one lazy SOB.
  12. May 6, 2019 at 9:41 PM
    #72
    15whtrd
    15whtrd Mr. Blonde
    There’s also the method with a hammer. Instead of cutting the brackets on the back of the seat, bend down the hoop on the back wall.
    Tundyfundy and Trooper2 like this.
  13. May 6, 2019 at 9:45 PM
    #73
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ooh. Think I’ll cut the hooks. Worst case senario - it’s reversible buy replacing the hooks. :)
    And I don’t end up with paint flaking off the back of the cab. :eek:
    15whtrd[QUOTED] likes this.
  14. May 6, 2019 at 9:49 PM
    #74
    15whtrd
    15whtrd Mr. Blonde
    Trooper2 and landphil[QUOTED] like this.
  15. May 6, 2019 at 10:26 PM
    #75
    Twinky
    07 double cab work horse
    I did the mod on my 07. Hardest part was bolting the seat back in. A friend for about 5 minutes would have been appreciated.
    Still pretty easy and totally worth it.
    Trooper2 and landphil like this.
  16. May 7, 2019 at 5:19 AM
    #76
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    Sorry if this has been asked already, but which underseeat storage box is that?
  17. May 7, 2019 at 8:01 AM
    #77
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    That’s the factory box for doublecabs.
  18. May 17, 2019 at 5:59 AM
    #78
    HawkeyeHauler
    HawkeyeHauler New Member
    North Dakota
    2019 Tundra 5.7L SR DC (Family Cruiser)
    Just did the back seat mod last night...it’s a beautiful thing for sure. Didn’t take long at all and was very simple.
    It makes installing seat covers a breeze!!
    TomC843 and JMB like this.
  19. May 29, 2019 at 1:51 PM
    #79
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I may have put the “pro” in “procrastinate” on this project, but I just might be one of the cool kids now. I tried to trim 15/16” off, hoping for a bit of a “detent” effect to have to pull the seat back past, but by the time they were smoothed off and evened out with a 4.5” flap wheel they were closer to 1” trimmed and clear the loops completely.
    The seat backs stay nicely against the back wall unless you pull them forward anyway, so that’s a moot point.
    I just have to vacuum under / behind the storage box before reinstalling it and re-organize all my crap and :smokertransformer: :yes::bananadance:
    JMB likes this.
  20. May 29, 2019 at 3:05 PM
    #80
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    There, toys cleaned up and put away. Mom would be proud.
    Nice easy access to my tow strap, Viair 85P, booster cables and tarp, and still room for a couple of rifles in soft cases.
    15whtrd likes this.
  21. May 29, 2019 at 4:29 PM
    #81
    15whtrd
    15whtrd Mr. Blonde
    I keep my collapsible fishing pole back there! Never know when you need to fish. Also a machete fits in the backing of the double seat. I picked up a cheapo from Harbor freight. Plus I have multiple things back there. I’m one of those that is always ready to go swimming so I keep swimming trunks. Along with a rain jacket as well as a full rain suit. Don’t forget about a portable compressor LOL
    landphil[QUOTED] and TheBeast like this.
  22. Sep 25, 2019 at 11:32 PM
    #82
    Comtech
    Comtech New Member
    Dave
    2007 Crewmax 5.7. heavily modded
    ToyTech lift, 35” Toyo, SAR radio, Red/white wig wags, Spyder Halos, rear cam with manual switch, power camper locks, Firestone air bags, P3 Tekonsha brake control in dash, Baja Design Squadron Pro fog kit, Kenwood 8”:touch screen sat/ bar in nav, bazooka sub, fog light anytime with Orem switch mod. a/c power inverter, Safari roof rack on Leer matching shell with Led interior lights. Accessory 20amp outlet in bed.
    My 2007 CM has tons of room behind the rear seats depending on how far forward you slide the seats. Both seats fold forward down to flat already. My rear seats are the 60/40 split with huge armrest. I would love a quick disconnect option to remove seats for those two man hunting road trips.
  23. Sep 30, 2019 at 12:15 PM
    #83
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I got 32 of those just in case
  24. Sep 30, 2019 at 2:34 PM
    #84
    SiberianTundra
    Greg
    War Machine
    Can we swap out the mechanism from doublecab to crewmax you think ?
    joonbug[QUOTED][OP] likes this.
  25. Sep 30, 2019 at 3:05 PM
    #85
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I think it would take the entire seat to be changed. But because of the drop down glass window on the CM, I would think mounting the loops would be very difficult. And the seat heights are different because the floor is raised on the CM.
  26. Aug 20, 2020 at 2:18 PM
    #86
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Instead of starting a new thread, I'll add to this one..
    I did this mod this week, it was what I was doing when I stripped the bolts in my other thread.
    I figured I'd take some pics and show y'all how much room is back there.
    I keep three jackets in my truck:
    Work rain jacket
    Work zip up hoodie
    A Cabela's zip up hoodie for my wife because she gets cold in restaurants.
    I used to keep them under the passenger's side small seat on the floor and they all get covered in dog hair.
    They are now bungeed to the back of that seat.
    There isn't a lot of room back there, but enough to store or hide things.
    I bought these 4 hooks 3 or 4 years ago on my old forum and never installed them.
    They've been sitting in my Tundra storage box in my attic.
    Wish I'd seen this thread when it came out, I would have just hammered the rear wall hooks down.
    It would have been a lot easier to hammer those hooks down than to remove the torx screws out of these hooks out of the seat back.
    Although my luck the rear window would have broken...
    I think there are thread on cutting those stock hooks to accomplish this mod.
    In the beginning..
    Both seats down.
    Had to put the front seats forward a bit because of the head rests.
    Three folded jackets, bungeed to the lower part of the seat back.
    I keep hers wrapped up..
    That seat folded up, to show clearance..
    How much room is really back there..
    I don't keep a gun back there (yet), these pics are just for reference.
    I could put one of 870s back there if I put the folding stock on..
    Could easily fit my beater pistol grip Mossberg..
    You could make or mod just about anything and attach it to those seat rods.
    Got all my room back to stash her purse or whatever..
    Gabrielo93, JMB and Trooper2 like this.
  27. Aug 20, 2020 at 5:07 PM
    #87
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    That looks good I put a breaker bar wrapped in a ski mask in between one the seat rods. I attached a organizer to the back wall of the truck I’ll upload some pics later but good spot for spare jackets/blankets
    1lowlife[QUOTED] likes this.
  28. Aug 20, 2020 at 6:57 PM
    #88
    Gabrielo93
    Gabriel
    Grand Prairie, TX
    Have a extra bungee dog lease attached
    Storage pocket for hidden organization
    Held by four zip ties instead of drilling
    Undo the back brackets to hold the organizer in place
    Final product can fit ratchet straps, extra small items to clear floor boards
    I had the underseat storage both oem and duha but I needed to use the floor board again for my dog and prefer the clean look.
    Tundyfundy and 1lowlife like this.
  29. Aug 21, 2020 at 7:15 AM
    #89
    1lowlife
    DADA
    2014 MGM DC SR5
    I like that..
    Under my driver's side is taken up with my Stealthbox.
    I may rig something like that to put stuff into and get it out of the front seat pockets..
    You can see here where I used to keep my jackets.
    IMG_1616_zpsskszdojb_600c484264a6fba26d5e433e701e86d2b308856d.jpg 82DE4E42-F7E5-49A3-B972-55194F2F7411_zps_ba0b0e48da37d4ba7f9044dd00f2fe96f1539e92.jpg
    Gabrielo93[QUOTED] likes this.
  30. Aug 22, 2020 at 12:04 PM
    #90
    1lowlife
    DADA
    2014 MGM DC SR5
    One more pic I took yesterday.
    With the seat bottom flooded up, whatever room you have behind the set greatly diminishes..
    Might be good to know if you're planning on doing this..
    FourCatDay and ToyoD like this.
