REAR SWAY BAR 1st GEN
Discussion in '1st Gen Tundras (2000-2006)' started by coyote, Jun 17, 2020.
  1. Sep 28, 2023 at 8:41 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    22 Acura tlx type S. 05 DC, 4.7, 4wd. 04 Highlander limited.
    I watched part of it. Makes me miss my t4r with kdss.
  2. Sep 28, 2023 at 8:47 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    They're welded to the rear axle and the bushings bolt into the mounts. Then there's mounts bolted on the frame for the links to bolt to.
  3. Sep 28, 2023 at 8:49 AM
    DJenerated
    Dija
    The Lone Star State
    I question those results only because we have leaf spring rears. So I can't help but question whether or not that even applies to us. Apples to oranges and all.
    @Voss had the helwig rear on his 4x4 and removed it.
    I have no sway bars on my 4x4 and both front and rear on my street queen.
    Elevatorguy and shifty` like this.
  4. Sep 28, 2023 at 9:09 AM
    DJenerated
    Dija
    The Lone Star State
    Interesting how different the helwig orientation is from the TRD. I always thought the main difference was the way it mounted to the axle and the thickness of the bar itself. But looked tlike the helwig end links go to the front of the diff, to the frame. Where as the TRD end links bolt the the rear of the diff, to the frame.
  5. Sep 28, 2023 at 9:32 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    I would like to try a rear sway bar myself. Several members have said it's one of the best mods they have done. Sadly the Hellwig has almost doubled in price.
    DJenerated[QUOTED] likes this.
  6. Sep 28, 2023 at 10:02 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    DJenerated likes this.
  7. Sep 28, 2023 at 10:04 AM
    shifty` Pattern Against User
  8. Sep 28, 2023 at 10:09 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs
    See Refresh Thread
    I purchased an ADDCO rear sway bar two and a half months ago. It still hasn’t arrived.
    When I called ADDCO directly (numerous times before getting a response) they told me that one of the OEMs they worked for had just pulled out of a contract and they were really scrambling.
    It’s actually arriving tomorrow, but still. It shouldn’t have taken that long. It’ll likely be another 4-5 weeks before I can install it, so I won’t easily be able to give y’all a good review for y’all, but just keep that in mind before you order one.
    FirstGenVol, DJenerated and shifty` like this.
  9. Sep 28, 2023 at 11:04 AM
    FirstGenVol
    East TN
    2002 AC
    Do you still have yours or did you sell it? Does the Hellwig bolt up without having to drill the frame?
  10. Sep 28, 2023 at 2:17 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It's on the access cab I sold to my nephew. He still has it. No drilling required, install was really easy.
    If he was local to me, I'd borrow it for a day and drive it with and without the rear sway bar.
  11. Oct 1, 2023 at 5:43 PM
    CaliTundra916
    CaliTundra916 New Member
    2006 Tundra DC
    Thanks! Are the brackets where the end links attach to the frame already on the frame or did you have to add those also?
  12. Oct 1, 2023 at 6:37 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I added those. Just some 3/16" flat bar with a hole drilled through it welded to the frame.
  13. Oct 3, 2023 at 6:50 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Video has me wondering about whether not to give the front removal a try and see how she drives. *If not considering adding a rear - perhaps front removal isn't so bad.
  14. Oct 3, 2023 at 6:57 AM
    DJenerated
    Dija
    The Lone Star State
    It's fine if you have decent coilovers. I wouldn't do it if you're stock. Honestly I wouldn't even do it on a DD unless you have 700lb coil springs
  15. Oct 3, 2023 at 7:01 AM
    noahrexion
    Washington
    2005 4WD DC
    I've got 6112's that are fresh with the stock 650lb.
    Have you been rolling w/out?
  16. Oct 3, 2023 at 10:21 AM
    DJenerated
    Dija
    The Lone Star State
    I thought 700lbs was recommended for a DC. Might be ok to run without but I'm not going to say it is or isn't. If you had the 700lbers I'd say do it .
    I been without sway bars for like a year now on 700lb Kings in my fully armored AC
  17. Feb 18, 2024 at 9:06 PM
    CaliTundra916
    2006 Tundra DC
    Thanks everyone for the help in figuring out how the stock bar attaches to the frame. I ended up going the Hellwig route. It was impossible to find a OE rear bar on EB or anywhere. The ones that did list the rear bar ended up sending me the front bar, multiple times. So if anyone wants a 27mm front bar for a first gen let me know :)
    FiatRunner and shifty` like this.
