Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Mar 15, 2024 at 6:20 AM
    #91
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like once a year or so.
  2. Mar 15, 2024 at 8:21 AM
    #92
    AZBoatHauler
    So.Arizona
    I’ve had to do it twice. First time in 2022. Again this winter.
    There is a working theory the health of your O2 sensors will determine reset frequency as they are what is used to calc the alcohol percentage.
    Ohannon7 likes this.
  3. Mar 15, 2024 at 8:58 AM
    #93
    pablo89
    pablo89 New Member
    pablo
    Miami
    2018 tundra platnium
    Rollnlock amp steps fuel wheels nitto ridge led lights
    has any one replaced o2 sensors to try?
  4. Mar 15, 2024 at 8:36 PM
    #94
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Returned the Launch tool and bought the D7. I like a bigger display and the ability to program keys.
  5. Mar 17, 2024 at 8:24 AM
    #95
    pablo89
    pablo89 New Member
    pablo
    Miami
    Just got my launch tool how did you guys get to that setting to reset the ethanol density? Can’t find it
  6. Mar 17, 2024 at 8:31 AM
    #96
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I think this one worked for me:
    Diagnostic > Automatically Search >System Sclection > Selcet "ECMECT(Engine and ECT)" System > Special Functions > Fuel Density Learning Value Reset
    The software has to run its updates before using the Launch.
  7. Mar 17, 2024 at 9:23 AM
    #97
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @Dkheaddo helped me out with this too. Here's what we did to see the current values (you'll want to know what you're at before you clear):
    Diagnostic, 16pin, System, powertrain, ecmect, read data stream, check these boxes - alcohol density estimate, long FT #1 & #2, click ok and it’ll split screen all three
  8. Mar 17, 2024 at 1:08 PM
    #98
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Does anyone else (FFV only) with the D7 see "Ethanol" where it states your fuel type?
  9. Mar 20, 2024 at 1:38 PM
    #99
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    My Launch came in today, picked it up for $112 delivered on Ebay. It showed I had a P1604 stored in the ECM which I didn't know about. I am not having any starting issues, but my fuel mileage blows (big tires probably) and my idle isn't perfect. LT fuel trims were 9/10% and alcohol density estimate was 0%, weird. Cleared it all out, we will see how it goes. I was a little worried about this one as it came from Ebay, but looks identical to the other pictured with a different serial number on the box.
    #99
    Skew12 and texasrho83 like this.
  10. Mar 20, 2024 at 1:42 PM
    #100
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks legit. Ever since I reset my trim levels, my truck's been running smoother and, seemingly, quicker... I hammer down and I swear it scoots better than before.
  11. Mar 22, 2024 at 7:13 PM
    #101
    kbahus
    kbahus New Member
    MI
    I definitely noticed an improvement with how the truck runs, surprised about that one.
    texasrho83 likes this.
  12. Mar 23, 2024 at 6:36 AM
    #102
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Bought the XTOOL D7, super easy to use. 170+ updates was a pain. Connects and works fast. Engine noticeably noisier initially.(Injectors?)
    Took it on a 15 mile run with 2nd tank of non ethenol fuel and reading remained at "0". Best economy I have seen. (16-17) cruising on flat at 55. Yes, it will go down commuting.
    Stared at the tool for about 3 days wondering if it would work but it was a non event.
    My reading was 18% with non ethenol fuel.
    Thank you to everyone in this thread.
    Skew12, Ohannon7 and Pillslinger like this.
  13. Mar 25, 2024 at 8:58 AM
    #103
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    Has anyone bought a non FlexFuel ECU from eBay and tried it?
    They are only $100-ish used.
    I "assume" it would not work without some programming help but wanted to ask.
    OldGuy03 likes this.
  14. Mar 26, 2024 at 6:04 PM
    #104
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    D7S on sale right now. About $100 off of normal price. According to the 'camel' they do this mark down pretty regularly.Screenshot_20240326_211120_Outlook.jpg
    Limited-time deal: XTOOL D7S Automotive Diagnostic Scanner, Bidirectional Scan Tool, Upgrade of D7, ECU Coding, 36+ Resets, All Systems Diagnosis, Crankshaft Relearn, CAN FD & DoIP, 3 Years Updates https://www.amazon.com/dp/B0BTBQ1NR4
    Skew12 and Ohannon7 like this.
  15. Mar 27, 2024 at 8:16 AM
    #105
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Just placed my order for the D7S for $366. I sure hope this thing is legit. I didn't exactly want to get into programming my truck but I got 100 miles to my last tank and the extended crank is killing me. I'm also getting paranoid about carbon buildup. Thank you and good luck all.
  16. Apr 5, 2024 at 4:30 AM
    #106
    DCRB4X4
    DCRB4X4 New Member
    After commuting 10 or so days Mileage showing 15mpg. Up from 13.5mpg
    Ethenol still at 0% (checked with torque pro and Xtool D7). Have filled up twice from 1/4 tank with E10.
    Should it show above 0% yet?
  17. Apr 5, 2024 at 4:40 AM
    #107
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Mine has been stuck on 0 for a couple months now, and I have used E10 gasoline. I’m in no rush for it to begin rising!
  18. Apr 5, 2024 at 5:23 AM
    #108
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I'm on my 2nd tank of the cheap gas (85 or e10?).
    My alcohol % is at zero from 80's and the LT fuel percentage is low, 4 % iirc. It's starting better and driving better too. I got a slight bump in MPG but hoping for more this next tank. Thanks for help all!!!
  19. Apr 5, 2024 at 6:13 AM
    #109
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
  20. Apr 5, 2024 at 6:39 AM
    #110
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Does it reset fuel trims simultaneous with fuel alcohol density reset, or do you have to reset each individually?
  21. Apr 5, 2024 at 6:48 AM
    #111
    helidave
    flagstaff
    2015 DC 4x4
    Not sure. I didn't see a function specifically for fuel trims. I reset the density and did the relearn procedure and everything is back where it should be
  22. Apr 5, 2024 at 10:25 AM
    #112
    lowercaseg
    lowercaseg [OP] New Member
    2013 Tundra Crewmax TRD
    Glad y'all have found other scan tools that read and reset the alcohol fuel density. My Tundra's alcohol level remains at zero since I reset it one year ago and I haven't had any problems (still starts right up and gets much better gas mileage).
    Markd4, nhw544, Ohannon7 and 2 others like this.
  23. Apr 15, 2024 at 3:31 AM
    #113
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    +1 for the Xtool D7. I reset my truck this past weekend and I'm seeing 15-15.5 MPG up from a max of 13.7. Definitely worth the money to anyone on the fence
    Timberline and texasrho83 like this.
  24. Apr 24, 2024 at 5:53 PM
    #114
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    So if I am supercharged what are signs of the alcohol level going up. Does it run richer along with the hard start?
  25. Apr 24, 2024 at 6:34 PM
    #115
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I would imagine so. Might be worth picking up an Air/Fuel Ratio gauge if you have forced induction
  26. Apr 24, 2024 at 7:02 PM
    #116
    AZTundra
    Paul
    Phoenix, AZ
    I'm supercharged also and I haven't had any symptoms, but I do periodically check the ethanol percentage. Are you running HPTuners? If so, you can connect to VCM scanner and read the percentage and go from there. If mine creeps up then I'll probably buy one of the mentioned bidirectional scanners and reset as needed.
  27. Apr 25, 2024 at 8:03 AM
    #117
    Diesel305
    Diesel305 New Member
    2017 tundra trd off road
    Mine does i wonder if this is normal?
  28. Apr 25, 2024 at 8:42 AM
    #118
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    MPG update: 15.7 average over about a 120 mile round trip this morning with about a 1,200 Ft elevation drop and gain on the way back. Not too bad for a N/A V8 spinning 35's at 6,000 Ft average elevation.
    Timberline, OldGuy03 and Pillslinger like this.
  29. Apr 25, 2024 at 9:11 AM
    #119
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I was thinking for us FFV owners, it is. Maybe we can get a non-FFV guy to chime in and tell us if it says something else for them.
  30. Apr 25, 2024 at 11:02 PM
    #120
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Winning!
