Reset Flex Fuel Alcohol/Ethanol Percentage Level with Bidirectional Scan Tool
Discussion in '2nd Gen Tundras (2007-2013)' started by lowercaseg, Apr 25, 2023.
  1. Feb 8, 2025 at 4:58 AM
    #241
    backcountryj
    backcountryj New Member
    GA
    2016 Crewmax
    Ordered. Will be here tmr.
    Any specific steps with this unit to be rid of the awful long crank?
    Timwfm likes this.
  2. Feb 8, 2025 at 5:34 AM
    #242
    RobertD
    Robert
    DFW, Texas
    @backcountryj
    These were the steps I followed and it worked for me
    Whizzit, backcountryj and Timwfm like this.
  3. Feb 8, 2025 at 7:21 PM
    #243
    kchupe
    kchupe New Member
    I selected reset alcohol density learning and test drove as instructed by the scanner prompt. I then checked and alcohol is at 68% not zero. Also, it shows learning is incomplete. I’m hoping I don’t end up having to take it to the dealer for a fuel pump replacement.
    Whizzit and Timwfm[QUOTED] like this.
  4. Feb 8, 2025 at 8:08 PM
    #244
    Timwfm
    Timwfm New Member
    I had to run it a couple time before it say complete...
  5. Feb 9, 2025 at 10:21 AM
    #245
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    2013 Crewmax sr5 4x4
    Interior led, reverse led bulb
  6. Feb 9, 2025 at 10:22 AM
    #246
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  7. Feb 9, 2025 at 10:23 AM
    #247
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Did you add fuel after resetting alcohol density? I went to the pump, reset it, added fuel and then ran through the procedure listed below. Worked for me and has been great since
  8. Feb 9, 2025 at 11:03 AM
    #248
    nmsTundra89
    nmsTundra89 New Member
    2019 MGM CMAX 4x4
    Question for my fellow flex fuel owners.
    Is this issue only occurring for people who live in cold environments? I’ve had my 2019 FF since Sept 2022 bought with 56,149 mi currently have 127,100 as of writing. I have never had this issue and although I live in Northern Mississippi we do occasionally have some cold weather. I have yet to experience a long crank or CEL light I’ve even ran E85 and never had issues. This being said I don’t have a bidirectional scan tool so I have no clue what my Alc % is, so it worth getting a bidirectional since I haven’t experienced any of these said issues? I feel like it’s probably going to happen eventually when I least expect it and at the worst time possible.
    EDIT: wanted to add that it’s the factory fuel pump still in the truck never been replaced.
  9. Feb 9, 2025 at 3:16 PM
    #249
    kchupe
    kchupe New Member
    I can confirm that doing it the way you said reset the alcohol to 0%. Thanks!
    Hbcon20 likes this.
  10. Feb 9, 2025 at 3:20 PM
    #250
    kchupe
    kchupe New Member
    Honestly, the scanner is on sale for $120 from Amz from regular $178. I would go ahead and get it. It’s only for Toyota/Lexus though. The dealer quoted $1500 to replace the fuel pump. If this is a permanent fix then I saved myself over $1400.
    Whizzit and szabo101 like this.
  11. Feb 9, 2025 at 4:15 PM
    #251
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    It works for global OBD2 as well, so you can scan whatever you want and get generic/global OBD2 codes. Glad it is working for everyone, I am still pleased with mine.
    OldGuy03 likes this.
  12. Feb 10, 2025 at 6:39 AM
    #252
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    After you reset the density to zero, is it necessary to throw in a couple gallons of fuel right afterwards? I heard the dealerships did 3 gallons. My portable gas can only holds 2 1/2 gallons. If that’s needed Is that amount suffice?
  13. Feb 10, 2025 at 7:04 AM
    #253
    kchupe
    kchupe New Member
    It needs to be enough to make the needle on the gas gauge move up.
    Hbcon20[QUOTED] and Timwfm like this.
  14. Feb 10, 2025 at 7:11 AM
    #254
    Timwfm
    Timwfm New Member
    I didnt put any gas in mine and it stay at Zero.:p:p:p:p
    Whizzit and Hbcon20 like this.
  15. Feb 10, 2025 at 7:13 AM
    #255
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Good to know. Lol
  16. Feb 10, 2025 at 7:30 AM
    #256
    kchupe
    kchupe New Member
    And just to be clear, I was under the impression that there was an actual setting you had to access to set the alcohol to 0%. There is not. Go to the gas station or fill up a gas can so you can follow the procedure after selecting learn fuel density option.
    There is still white smoke that comes out when first starting up, not sure what that’s about.
  17. Feb 10, 2025 at 9:13 AM
    #257
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Did you leave the truck on while doing the alcohol reset? I bought that same scanner. If should be here today or tomorrow. Thanks.
    Timwfm[QUOTED] likes this.
  18. Feb 10, 2025 at 10:19 AM
    #258
    Timwfm
    Timwfm New Member
    Yeah it was running. If that doesnt work try to leave the key in ON position and dont start the vehicle.
    Hbcon20[QUOTED] likes this.
  19. Feb 10, 2025 at 12:24 PM
    #259
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    long FT B1S1 & B2S1
    what do these of numbers mean when doing the alcohol density test?
    Timwfm likes this.
  20. Feb 10, 2025 at 12:39 PM
    #260
    Timwfm
    Timwfm New Member
    Google will explain better if you google it.
  21. Feb 10, 2025 at 1:26 PM
    #261
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    I’ve cleared it twice. It says complete but my alcohol density is still reading 73%
  22. Feb 10, 2025 at 1:28 PM
    #262
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    My density is still showing 73%
  23. Feb 10, 2025 at 1:35 PM
    #263
    Timwfm
    Timwfm New Member
    That what happen to my friend truck too. It would NOT take the reset. Since his was still under the TSB (2016 model with 98k), we took into the dealer to flash the ECU (updated) then the value stay at Zero. Sorry to hear that it not working. Maybe try to add 3 gallon then do the reset?
  24. Feb 10, 2025 at 1:38 PM
    #264
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    yeah I’m at 169k miles. So no warranty there. I’ll get to add my 2.5 gallons of spare fuel. See if that works.
  25. Feb 10, 2025 at 1:48 PM
    #265
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    here’s what I got.
  26. Feb 10, 2025 at 1:50 PM
    #266
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Here’s after adding 2.5 gallons of gas. Now it won’t “complete” the learning process
  27. Feb 10, 2025 at 1:50 PM
    #267
    AZBoatHauler
    So.Arizona
    Why can’t you do the reset sitting parked at the fuel pump then add gas and drive as the FSM calls for?
    see post 247
  28. Feb 10, 2025 at 1:53 PM
    #268
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    Should I drive around at all? Then re try?
  29. Feb 10, 2025 at 1:54 PM
    #269
    Hbcon20
    Hbcon20 New Member
    Northeast Tennessse
    My tank is already full. I literally got gas yesterday. I guess I might have to try the reset after a tank?
    Timwfm likes this.
  30. Feb 10, 2025 at 1:55 PM
    #270
    AZBoatHauler
    So.Arizona
    You need to be able to move the gauge. 50 miles of driving ought to be enough to trigger the reset when topped off. Read and understand the process so you add the fuel and start the truck in the correct sequence after reset.
