Review- TRD Rear Sway Bar- before and after
Discussion in 'Suspension' started by frichco228, Dec 9, 2020.
  1. Jul 19, 2021 at 12:15 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    I've added the front sway bar in addtion to the RSB. It makes about 20% difference, the rear one made a huge improvement.
    Woodwreck[QUOTED] likes this.
  2. Jul 27, 2021 at 12:12 PM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    I am planning on doing the rear sway bar next month (Sept). Should I also change the front to a TRD as well???
    A little background
    I dont do any towing or hauling
    Off roading limited to beaches here on Long Island
    Basically the truck is a pavement princess
    I do plan on adding a Magnuson supercharger in the spring of 22.
    Any advice is appreciated.
  3. Aug 29, 2022 at 8:39 AM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Will this TRD Rear Sway Bar still go on my truck? I have Alcan spings with a 1' lift built in, and Alcan shackles set to lift the truck 1", so a 2" lift in the rear. Any length problems?
  4. Aug 29, 2022 at 8:44 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Should not have an issue. You could get a little more length out of it if you put the brackets 90 degrees up.
    TundraTRD08[QUOTED] likes this.
  5. Aug 29, 2022 at 8:45 AM
    TundraTRD08
    Wesley
    Thanks! Has anyone here tried running the rear sway bar only and seeing how it runs? (No front sway bar)
  6. Aug 29, 2022 at 8:47 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have 6112s with 2.5" lift in the front Toyrec shackles set on the 1" setting with no issues..
    F131B29B-396F-45F9-B6DE-5F1AF30227A4_zps_235bbdc1735108a14858d154c6ce6b71b0d85b34.jpg
  7. Aug 29, 2022 at 10:19 AM
    MadMaxCanon
    I havent done it in the Tundra, but not having a front sway bar in other trucks that ive had was a downright scary experience lol, multiplied exponentially if you have a lift.
    willy likes this.
  8. Aug 31, 2022 at 9:38 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Not sure about your Alcans, but I bet they’re somewhat similar to my Deaver U748s. My rear sway bar would not fit with it mounted beneath the axle. The links needed to be extended if it was gonna stay that way. The fix was to simply mount the bar behind the axle. I also attached the links to the next hole back on the frame. Easiest retrofit in the world if it doesn’t work with your springs.
    Plus side is a bit more clearance now without the bar being lower than the axle housing.
  9. Sep 1, 2022 at 4:20 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I’ve had no front sway bar for a few years. I installed the TRD rear and it handled good.
    However, since adding the supercharger I often find my self doing 85+ mph and it is not stable at those speeds. I just put the front bar back on last weekend and all the threads in the frame and control arms were rusted. It was a disaster install. I tapped out the 4 frame bolt holes but did not have a tap for the larger bolt size in the control arms. Ended up breaking the welded nut inside 1 control arm and wasn’t able to tighten either bolt. Long story short, I’ll be replacing the lower control arms at some point.
  10. Sep 5, 2022 at 6:39 AM
    TundraTRD08
    Wesley
    You have my luck!:rofl: Let me know if it’s any more stable at high speeds with the front sway bar, that is, if you can get it on anyway;)
    willy likes this.
  11. Sep 5, 2022 at 10:53 AM
    ZPhilip
    Philip
    West Chester, PA
    It’s back on but the end links are not bolted tight to the control arms.
    And it does handle better at high speeds, no more side to side swaying going on (go figure).
  12. Sep 22, 2022 at 7:21 AM
    SnowLizard
    SnowLizard New Member
    Richard
    Thanks! I'm looking for this exact info. I'm not a speed demon, I take my time in 65mph + places, usually because I'm towing 5k trailer.
    I had a 99 4runner with front removed and rear beefed up, it was amazing offroad, little top heavy on road but my natural self just went slower... I've been thinking this Same setup on tundra would be great...
    I'll be going 5.29 gears soon, basically making 6th gear run like current 5th (34 inch tires), but when I pull the sway bar, I'll make sure to put the bolts back in.
    The only question I have now is who makes the strongest/thickest rear sway bar?
    willy likes this.
  13. Sep 22, 2022 at 8:12 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Yes.
    I did the rear 1st...it works well.
    then I did the front...it works well.
    and...you will need traction bars as well. I use Caltracs. https://calvertracing.com/product/8110-caltracs/
    the S/C will cause wheel hop when you do what you will do when you have a S/C.
  14. Sep 22, 2022 at 9:35 AM
    ZPhilip
    Philip
    West Chester, PA
    My opinion, leave the front sway in unless you’re rock crawling.
    willy likes this.
  15. Dec 8, 2022 at 11:23 PM
    benrobert
    benrobert New Member
    Sway bar hitches for campers are extras you can get for your car. It will, however, make driving a lot more comfortable. A sway bar will aid in regaining weight and balance for simple driving. The apparatus will reduce the movement.
  16. Dec 9, 2022 at 4:37 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Does anyone know where you can get the factory lube for the two bushings that comes in the complete TRD kit from Mama Toyota??
    After 4+ years of installation I think I want to refresh the lube in there.
    Or I might consider some Loctite anti-seize.
    What has anyone else done to refresh those bushings???
  17. Dec 9, 2022 at 4:38 AM
    centex
    centex New Member
    A good moly lube should work. I use Lucas red and tacky.
  18. Dec 9, 2022 at 5:26 AM
    ZPhilip
    Philip
    West Chester, PA
    Silicone grease such as Super Lube is usually put on suspension bushings.
  19. Apr 6, 2023 at 10:29 AM
    #49
    RodneydUSMC
    RodneydUSMC New Member
    Rod
    New Jersey
    2015 Toyota Tundra SR5 Crewmax 4WD 5.7L
    Stillen CAI, Bullydog GT Platinum Tuner, RC Exhaust, TRD RSB
    Installed RSB and it took less than 1/2 hour. Simple installation and detailed instructions. After a short test drive (no high speeds yet) I noticed it alleviated the roll sensation on turns. Hoping this helps out at highway speeds on windy days. NOTE: Ensure you torque all bolts to spec
    UPDATE: April 08, 2023
    Drove over 100 miles at highway speeds (In NJ that is 80mph) and she handles so much better. Nice smooth ride with little to no sway during lane changes. The gust of wind movement that I can normally feel has diminished (albeit we only had winds in the 30mph range yesterday). The biggest difference is on exit ramps with loops, the truck hugs the roadway and tracks excellently.
    I'm sorry I waited this long to do this upgrade. Definitely has better bang for the buck than the CAI or Bullydog GT tuner and a close second to the upgraded exhaust. In my opinion... if you're, not an off-roader, this is a must-have upgrade.
    WVI and Cpl_Punishment like this.
  20. May 20, 2023 at 7:29 AM
    #50
    unsub1
    unsub1 New Member
    Steven
    2020 MGM Tundra 4x4 SR5 TRD Off-Road Package, Convenience Package,
    Victory 4x4 sliders, RSI SmartCap, ICI Alumilite front bumper, TRD Pro wheels, Nitto RidgeGrapplers, FrontRunner rack, National Luna DC25 dual battery, X2Power AGM main battery, Cascadia 4x4 hood-mount solar panel, NOCO X2 Pro charger
    Late to the thread but I have this setup and the RSB went on without issue.
  21. Jul 19, 2023 at 6:48 AM
    #51
    jham101
    jham101 New Member
    I'm going back and forth on whether to add this to my truck. I'm on bad dirt roads hunting or camping about 50ish days a year in Montana. I'm not trying to rock crawl or doing anything wild. I do hit big pot holes unintentionally occasionally and will go over largish rocks occasionally. Most of my time is spent on logging roads that aren't well maintained. I can see the upside of adding these for the 300 days a year i'm not on dirt roads, but will they significantly impact the trucks performance on relatively unmaintained backcountry roads? thanks
  22. Jul 19, 2023 at 7:04 AM
    #52
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Get some quick disconnects for the linkages and you'll enjoy it when you need it.
  23. Jul 19, 2023 at 1:53 PM
    #53
    jham101
    jham101 New Member
    I can find quick disconnects for Jeeps but nothing tundra specific? Do I need to find the rear sway bar link length and then find something that works?
  24. Nov 13, 2023 at 9:29 AM
    #54
    erkme73
    erkme73 New Member
    I scanned through this two-page thread but didn't see any answers to your question. I have a 2011 Limited Sequoia. With independent rear suspension (unlike the rigid straight axle on the Tundras), the Sequoia already has front and rear sway bars. At least mine does ;)
  25. Nov 13, 2023 at 9:35 AM
    #55
    jham101
    jham101 New Member
    So i ended up going with the sway bar link. Ultimately the articulation needed without the sway bark link in the rear is so fringe case that the need for quick disconnects didn't make sense. With that said the lean is still not great even with the rear sway bar links. I think i will plan to upgrade leaf springs in near future. thanks
  26. Jan 4, 2024 at 10:36 PM
    #56
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    Just got my sway bar kit in.
    Anyone else get the mounting hardware powder coated? The thought of the gold hardware makes me cringe.
    I'll be giving a few places a call tomorrow to get them painted black.
  27. Jan 4, 2024 at 11:09 PM
    #57
    Chad D.
    Chad D. New Member
    Western Oregon
    Say it with love; say it with Krylon…
    831mic[QUOTED] likes this.
  28. Jan 5, 2024 at 2:00 AM
    #58
    Xcumminsguy
    Xcumminsguy New Member
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Added one to my ride just last weekend. Great upgrade.
    831mic likes this.
  29. Jan 5, 2024 at 3:16 AM
    #59
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I used Krylon. works fine.
  30. May 20, 2024 at 1:06 PM
    #60
    BushBandit
    BushBandit New Member
    2021 Tundra Limited TRD
    Where's the best deal to get the TRD rear sway bar?
    The link in the first post is $350...
