Scangauge 3 Available
Discussion in 'General Tundra Discussion' started by Bergy24, May 19, 2022.
  1. Jun 12, 2022 at 12:35 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
  2. Jun 12, 2022 at 1:11 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    I’ve had mine installed for about a week now using the TackForm magnetic air vent mount.
    Still working up on setting it up just right, but currently have everything set up for transmission pan temps, TPMS, intake air temp, speed (little bit higher up towards my FOV), fuel mileage, coolant temp, and trip information
    3A7F45DF-3603-4905-934D-BF82669FA8F3.jpg 0E188CDF-93DB-40D6-BD17-E1E50650FDCA.jpg
  3. Jun 12, 2022 at 2:23 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  4. Jun 12, 2022 at 2:41 PM
    Saltyhero13
    Unfortunately, I really don't know yet. I just filled up a to a full tank yesterday and I'm not doing a great deal of commuting on one vehicle. It may be some time before I hit 1/4 tank on the Tundra.
    I will report any findings here once I've had time to make the proper observations and figure out a fix, assuming it won't read correctly on a boosted vehicle.
    nobodyintexas[QUOTED] likes this.
  5. Jun 12, 2022 at 5:00 PM
    Saltyhero13
  6. Jun 12, 2022 at 5:54 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
  7. Jun 12, 2022 at 6:15 PM
    Saltyhero13
  8. Jun 13, 2022 at 1:27 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Yup
    I’m 1.11
    it is confounding
    I suspect it will be a simple fix
    me = simple
    Retired...finally likes this.
  9. Jun 13, 2022 at 3:10 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    to further belabor my MPG issue...
    this morning
    24 mile drive mostly hwy 59mph
    indicated on SG3 - 27.45
    my usual avg = 17.8
    ~35% difference.
    I am eager to see what the remedy is - as I have finagled just about everything on the unit.
  10. Jun 13, 2022 at 5:54 AM
    Saltyhero13
    Seems strange unless they made an error with their logic and formulas which is likely with a new product.
  11. Jun 13, 2022 at 5:57 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed
    even when I change the fuel flow rate manually, it does not alter the MPG rate.
    Saltyhero13[QUOTED] likes this.
  12. Jun 13, 2022 at 6:01 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I hope yours is off by the same amount - as tuning for the 650's is what is tricking the ODB output. and I'm guessing you have very similar fueling tables to me.
  13. Jun 13, 2022 at 8:31 AM
    Saltyhero13
    Most likely. I would expect they are close in scaling. If the fill up %correction isn't working I would think they missed something in how the MPGs are calculated. I did notice "Fuel Cutoff" now has an Auto setting; the old model required an entry to be made, hence my early question a few posts back.
  14. Jun 13, 2022 at 8:33 AM
    Saltyhero13
    Good to know. Every little bit of info helps.
    I may install my old setup until this gets sorted out.
  15. Jun 13, 2022 at 8:37 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    what is "fuel cutoff" and what is it supposed to do. Mine is still in auto.
  16. Jun 13, 2022 at 9:00 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @nobodyintexas have you reset to default settings and started over?
  17. Jun 13, 2022 at 9:07 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    not yet.
    I will on this next fillup. and start from scratch.
    I assume Scanguage will tell me to do the same.
    I'm guessing my mistake was treating just like my SG2.
    aside from MPG...it does everything I need/want it to.
  18. Jun 13, 2022 at 9:11 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm on the fence about buying one but will probably pull the trigger on a sale. Mounting location will probably be the unused cubby area underneath the AC controls.
  19. Jun 13, 2022 at 10:00 AM
    #49
    Saltyhero13
    Keep in mind this unit is taller; it is about the size of two of the old units stacked on each other.
  20. Jun 13, 2022 at 10:08 AM
    #50
    Saltyhero13
    Not 100% sure but it has something to do with Open/Closed loop.
    Old manual suggested looking at the throttle setting and adding 4. Adjust from there but it looks like it could be off by a little bit and you can still get the correct readings.
    One way to test the setting is correct is by ensuring you don't see 9999MPGs when the pedal is being depressed.
    No guarantee this will fix anything.
  21. Jun 13, 2022 at 10:35 AM
    #51
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have an external speaker I no longer use mounted in the location I could put the gauge. Do you think it would fit there?
  22. Jun 13, 2022 at 11:18 AM
    #52
    Saltyhero13
    Yes, it is fairly flat as in shallow depth.
  23. Jun 13, 2022 at 11:53 AM
    #53
    Saltyhero13
    The one thing I hate is you can't have different layout on each page. All three pages present the same baseline layout.
  24. Jun 13, 2022 at 11:55 AM
    #54
    nobodyintexas
    nobodyintexas What?
    South of Houston
    and...I wish I could make the eco screen modifiable. I'd like my AFR to be in the center.
  25. Jun 13, 2022 at 12:13 PM
    #55
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    For the guys that have first hand experience with this new unit. Are you able to get TPMS data on this? It looks like yes is the answer, but I always like to double check!
  26. Jun 13, 2022 at 12:16 PM
    #56
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes. & tire temp.
    Saltyhero13 and aelarson[QUOTED] like this.
  27. Jun 13, 2022 at 12:17 PM
    #57
    aelarson
    aelarson New Member
    AZ
    Sounds like I need to swipe the credit card. Thanks for the input!
  28. Jun 13, 2022 at 12:34 PM
    #58
    Saltyhero13
    This.
    It automatically scans several X-Gauge monitors. Tire Pressure and Tire Temps came right up for all four corners and the spare.
    I'll list out the other monitors when I get a chance to fire up the unit again.
  29. Jun 13, 2022 at 1:21 PM
    #59
    Saltyhero13
    Standard tab:
    A/F X 4 (both banks and both sensors)
    A/F Commanded
    Absolute Load
    Ambient Temp
    Barometric Press
    Battery Voltage
    Cat Temp (both sides)
    Coolant Temp
    Engine Load
    Engine RPM
    Fuel Flow
    Fuel Level
    Fuel Loop
    Glow Plug Lamp
    Gross HP
    Ignition Timing
    Instant MPG
    IAT
    LTFT X2
    LTFT O2 x2
    MAF
    O2 Amps, Volts, and %
    Recommended Gear
    Reference Torque
    Relative Throttle
    Speed
    STFT X2
    STFT O2 x2
    Throttle Pos
    TRQ % Actual
    Trip tab:
    A bunch of Trip and Fuel data
    X-Gauge tab:
    A/T Oil Temp1/2
    Current Gear
    TCL Lockup
    Ambient Temp
    Tire Pressure x5
    Tire Temps x5
  30. Jun 13, 2022 at 1:50 PM
    #60
    ScanGauge
    ScanGauge New Member
    Based on what I've read you're doing everything correctly. The 'Fill Up' procedure should adjust the fuel flow calculation, as well as manually setting the fuel flow correction in the adjust menu. It appears that correction may not be factored in for one of the fuel flow calculation the SG3 performs. I'll work on addressing that in a firmware update ASAP.
    That would certainly be nice. Something that may help though is that you can swipe up/down on any screen with two fingers to raise/lower the screen brightness. That will at least save navigating to the display settings to change the brightness.
    This is correct! The SG3 now also has an 'Auto' setting where it will figure this all out for you.
    Finally, if anyone has any questions feel free to ask - I'll do my best to answer them.
    James DeLong
    Linear Logic LLC
    Development Engineer
