Scangauge 3 Available
Discussion in 'General Tundra Discussion' started by Bergy24, May 19, 2022.
  1. Jun 13, 2022 at 1:52 PM
    #61
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    You’re awesome
    thanks for the feed back
  2. Jun 13, 2022 at 1:56 PM
    #62
    Saltyhero13
    Saltyhero13 Throbbing Member
    ScanGauge likes this.
  3. Jun 13, 2022 at 5:10 PM
    #63
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Does the gauge tell you the actual number of gallons remaining? Seems like that would be useful since Toyota leaves a large buffer when the tank shows empty
  4. Jun 13, 2022 at 5:22 PM
    #64
    Thanks for joining.....that will be a big plus with assistance on the SG3. Any military discount or Father's Day sale codes? Thanks
  5. Jun 13, 2022 at 7:34 PM
    #65
    nopsFU
    nopsFU New Member
    2019 Tundra TRD Pro
    I'd love to see logging capability in the future. Press a trigger button or user-defined stacked conditions, with ~30 second buffer before and after trigger. Internal storage or external micro SD, export to csv file. :)
  6. Jun 13, 2022 at 8:27 PM
    #66
    Saltyhero13
    I've not tried that monitor but under the "Trip" tab there is a "Fuel Remaining" monitor. I don't know what units it is measured in but I can test it tomorrow.
  7. Jun 13, 2022 at 8:30 PM
    #67
    Saltyhero13
    And here I was going to ask him where babies come from...
  8. Jun 14, 2022 at 1:27 AM
    #68
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It does gallons and % remaining
    and gallons used
    this is how I monitored the calc. It expected 12 gallons at fillup. I put in 15
    Saltyhero13[QUOTED] likes this.
  9. Jun 14, 2022 at 3:13 AM
    #69
    nobodyintexas
    nobodyintexas What?
    South of Houston
    @ScanGauge
    the dimming feature is right on. does what I needed it to do.
  10. Jun 14, 2022 at 10:57 AM
    #70
    ScanGauge
    ScanGauge New Member
    There are a couple of possibilities. First, there's a Toyota specific parameter that can possibly report how many gallons remain in the tank. Currently the SG3 doesn't auto scan for this parameter (although it probably will be added in future updates), but it can still be entered as a manual XGauge:
    Fuel Remaining (Gallons)
    TXD: 07C021C8
    RXF: 446185C83000
    RXD: 2808
    MTH: 003200130000
    That XGauge code can be punched into the SG3 or the SG2 and if the vehicle supports that parameter it will work. Looking at the data I've gathered from Tundra's this XGauge should be supported at least back to 2014 Tundra's, and it's possible it's supported further back.
    The next option is using the 'Fuel Remaining' trip gauge. This value is calculated by the ScanGauge based on fuel use, so if you always let the ScanGauge know when you've filled up your tank and the SG is dialed in well on your MPG calculation it's a good option to go with.
    Finally, around the 2020 model year for Tundra's there's a standard OBDII Fuel Level parameter that reports the tank level in percent. If the vehicle supports this parameter the SG3 will detect it and display it as a gauge option in the 'Standard' gauge list. Personally my experience with this parameter is that it usually caps out around 90% and won't usually go below 10% even on a nearly empty tank. Still an option, but has those caps that can be annoying when your tank is low.
    We have a Military discount. If you reach out to Orders@Linear-Logic.com or Service@Linear-Logic.com and let them know you need the Military discount they'll get you set up with a discount code.
    Definitely something on our radar - down the road it's likely some form of data logging will be added.
    Good to hear!
    Saltyhero13 and Lodge14 like this.
  11. Jun 14, 2022 at 11:09 AM
    #71
    Thank you!
  12. Jun 17, 2022 at 3:53 AM
    #72
    nobodyintexas
    nobodyintexas What?
    South of Houston
    latest fill up....
    indicated 11.3 gallons used
    fill up with 16.3
    I'm sure @ScanGauge is all over this....
    sidebar...that's a 44% fuel variance. Which is "primarily*" caused by tuning for my larger injectors...now we see the effects of ecu tuning.
    does this delta correlate? I'm using 650cc injectors what was the stock size injectors? 480cc? that would jive with the delta.
    I still get 16.8 mpg (hand calc'd), so don't get lathered up over the variance.
    *the Harrop has an affect as well...:rolleyes:
  13. Jun 17, 2022 at 9:22 AM
    #73
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    But it doesnt automatically dim with the headlights and dash does it? I built a custom display for my insturment cluster and just read the CAN Bus signal for the headlights coming on/off, when the display sees the headlights come on it dims its self to 50% brightness. As soon as the headlights go off my display goes to 85% brightness.
  14. Jun 17, 2022 at 9:24 AM
    #74
    Saltyhero13
    Not that I've experienced. The two finger swipe motion quickly dims it though.
  15. Jun 27, 2022 at 10:01 AM
    #75
    nobodyintexas
    nobodyintexas What?
    South of Houston
    did anyone mount the SG3 yet?
    I liked the A/C mount, but it's Africa hot in Houston, had to rule it out*.
    still pondering ideas.
    *I sure miss the lower A/C vent the '06 sequoia had (ball vent).
  16. Jun 27, 2022 at 10:05 AM
    #76
    Its so hot here in Fl too. My SGII is mounted with the high strength VHT tape and its coming off...never done that in the past.
    nobodyintexas[QUOTED] likes this.
  17. Jun 27, 2022 at 10:52 AM
    #77
    Saltyhero13
    My old one was velcroed to a special mount but I'm having adhesion issues with this new one that is using a magnetic plate.
    Waiting on one more mount but it looks like it will be a toss up with Tackform or the Maclean (hasn't shipped yet).
  18. Jun 28, 2022 at 8:39 AM
    #78
    Saltyhero13
    I'm using silcone tape as a stop gap, seems to be holding up.
  19. Jun 28, 2022 at 8:40 AM
    #79
    nobodyintexas
    nobodyintexas What?
    South of Houston
    The mileage is now calculating dead on!
    now, I wait for my flexpod to arrive Friday. to test mount it.
    Saltyhero13 likes this.
  20. Jun 28, 2022 at 9:06 AM
    #80
    Is the upgrade worth it to go from a SG2 to the 3?
  21. Jun 28, 2022 at 9:07 AM
    #81
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Yes
    much more data
    easy to use
  22. Jun 28, 2022 at 9:07 AM
    #82
    Sweet. I could always sell the 2.
  23. Jun 28, 2022 at 9:12 AM
    #83
    Saltyhero13
    What is your "Fill up" procedure on the gauge?
  24. Jun 28, 2022 at 9:20 AM
    #84
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Would an iPad Mini with an OBD app be just as good?
  25. Jun 28, 2022 at 9:34 AM
    #85
    Saltyhero13
    Which app? There is more than one
    Depends on what you are looking for and what sensors you can monitor with whichever app you are using.
    This monitor is a lot smaller than a mini but a mini can be used for a lot more things and isn't a single use product.
    This monitor also autoscans a bunch of monitors and handles trip related data as well, not sure what apps can do.
  26. Jun 28, 2022 at 9:48 AM
    #86
    nobodyintexas
    nobodyintexas What?
    South of Houston
    same as instructed.
    I believe they had to fix a formula. Works just like SG2 now.
  27. Jun 28, 2022 at 6:28 PM
    #87
    Saltyhero13
    WHAT HAVE YOU DONE @ScanGauge !?! Version 1.12!
    THIS. UPDATE. IS.
    AMAZING!
    And thank you to the Alphas that took part in the Beta....you know how you are!
    Each screen allows you to have a different format. Its been reported the fill up issue is fixed too!
  28. Jun 29, 2022 at 2:24 AM
    #88
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    Please expand on the latest update.
  29. Jun 29, 2022 at 3:15 AM
    #89
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I really like the diff format for the 3 screens.
    i now have a:
    performance screen - AFR/timing/MAF/TC lockup/IAT
    mileage screen - for old man driving - using the eco graph thing
    towing screen - gear/TC lockup/trans temp/coolant temp
    Friday - I mount the thing permanently.
    WVI and Saltyhero13[QUOTED] like this.
  30. Jun 29, 2022 at 4:49 AM
    #90
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    SG2 still reads tranny temps, but will research 3 for future purchase. Thanks for the heads up.
