ScanGauge II users for monitoring transmission temperature
Discussion in 'Towing & Hauling' started by smstoyloy, Jun 21, 2020.
  1. Dec 29, 2020 at 11:07 AM
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    Transmission Pan
    Bammer[QUOTED] likes this.
  2. Jan 11, 2021 at 8:47 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Just some food for thought here , When I retrofitted my 2019 with a Cooler kit , I also removed the trans pan and installed a bung for a Autometer Trans Temp gauge sender so that I could read pan temps all the time without the use of an obd reader .
    My findings were that My autometer gauge reads consistantly about 20 degrees cooler that my obd scan tool for trans pan temps . I have come to the conclusion that this is due to the OE internal trans temperature sensor is actually located in the valve body of the trans , It monitors the fluid temp after its already been sucked up . So in theory when monitoring trans pan temps using an obd reader , it is not really a true trans pan temp reading . your pan temps are cooler than you think ! .
    tundra_20, SSPey, batman900 and 3 others like this.
  3. Mar 2, 2021 at 4:03 PM
    Rick111
    Rick111 New Member
    Rick
    2021 Lexus GX 460
    Uni filter for secondary air pump, a/c drain extension, and breather extension for rear differential.
    I am new to Tundra (I am a former Tacoma World member). I recently purchased a new Lexus GX 460 (with the 1UR-FE engine and A760F transmission) so I have been scouring the Web for useful information. Thanks to sites like Tundra and Tacoma World, I learned about the Uni filter mod for the secondary air pump, the a/c drain extension, the rear differential vent extension, ScanGauge2 and so on.
    I recently installed a ScanGauge2 and have a couple of observations regarding the transmission temperature reading (as it applies to my vehicle):
    - I have read on a few sites that the ScanGauge displays two (2) distinct transmission temperatures and that one is higher than the other. More specifically, that the lower reading is for the pan fluid temperature and the higher for the torque converter. According to pages 130 through 134 of the 2010 “Toyota Tundra - New Features” technical data sheet (you can find it on-line or I can email whoever wants a copy) regarding the Aisin A760F transmission there are two (2) distinct temperature sensors inside the transmission housing, they are both located just above the filter, but their functions are not for reading pan and torque converter temperatures. The technical data sheet states that:
    - “The ATF temperature sensor No. 1 (THO1) is used for hydraulic pressure control. This sensor is used for revision of the pressure that is used to apply clutches and brakes in the transmission. This helps to ensure smooth shift quality.”
    - “The ATF temperature sensor No. 2 (THO2) is used as a basis for modifying the ECT shift timing control when the ATF temperature is high. It is also used for the ATF temperature warning light.”
    I entered the four (4) X-gauges applicable to Toyota-Lexus-Scion Specific CANSF for 2010+ into my ScanGauge2. I named them TF1 through TF4. Only “TF3” gave data when I turned on the vehicle:
    TXD 07E02182
    RXF 046105820000
    RXD 2808
    MTH 00090005FFD8
    Name TFT
    I renamed “TF3”, TFT. Just an observation, for what it’s worth.
  4. Mar 3, 2021 at 3:17 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    I can't get mine to work for trans temps....:burp:
  5. Mar 3, 2021 at 6:43 AM
    Rick111
    Rick111 New Member
    Rick
    2021 Lexus GX 460
    The folks at ScanGauge are very friendly and helpful. I think if you reach out to them they should be able to walk you through the problem. If I was able to find one code to work your vehicle should have the same result. Do you have the Aisin A760 series transmission?
  6. Mar 3, 2021 at 6:58 AM
    Bammer
    Monroe, CT
    Not sure????
  7. Mar 3, 2021 at 7:08 AM
    Rick111
    Rick111 New Member
    Rick
    2021 Lexus GX 460
    If you are not sure what transmission you have it is on the data sheet on the door.
  8. Mar 3, 2021 at 7:11 AM
    Bammer
    Monroe, CT
    About the A760 transmission
  9. Mar 3, 2021 at 7:15 AM
    Rick111
    Rick111 New Member
    Rick
    2021 Lexus GX 460
    Look at the decal on your door frame. Bottom left-hand text.
  10. Mar 3, 2021 at 8:00 AM
    Bammer
    Monroe, CT
    Thank you
  11. Mar 10, 2021 at 9:11 AM
    Bammer
    Monroe, CT
    No A760F for me ???
  12. Mar 10, 2021 at 11:32 AM
    Rick111
    Rick111 New Member
    Rick
    2021 Lexus GX 460
    Nope, you have the AB60F. There is information on-line for that model. You could also log onto TIS for $20.00 to access the maintenance manual for your specific vehicle. For example, my transmission has to be between 115-126 degrees Fahrenheit in order to check for proper level of fluid.
    Regarding the ScanGauge2 and my transmission’s normal temperature readings, I finally took the vehicle out for a 300 mile round trip down to Key West. Outside air temperature was between 75-71 degrees Fahrenheit. The highest reading of the day was 199 degrees Fahrenheit for a few seconds during acceleration onto the expressway. The rest of the day the transmission ran between 185-195 degrees Fahrenheit.
  13. Aug 7, 2021 at 8:17 PM
    mg21Tundra
    mg21Tundra New Member
    2021 TRD OR
    This worked for my 2021 with AB60F trans….thanks OP!
  14. Sep 12, 2021 at 2:42 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Thank you, worked great on for my 2015 Tundra as well.
  15. Sep 30, 2021 at 3:20 PM
    Retired...finally
    As well as my 2021.
    Mike59 likes this.
  16. Sep 30, 2021 at 10:34 PM
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    Did yours register temperature right away? I tried on my ‘21 and only the pan temp worked. I figured the torque converter one wasn’t valid, but now I need to go back and try again.
  17. Oct 1, 2021 at 2:05 AM
    Retired...finally
    Yes it did....Sort of. After I corrected my typo. At first neither worked. I went back in and found my error and fixed it. I used the copy function for the second changing only 2808 to 3808 and the name.20210929_145516.jpg
  18. Oct 1, 2021 at 3:41 AM
    Bammer
    Monroe, CT
    I still can't get it to work !:frusty::frusty::frusty::frusty:
  19. Oct 1, 2021 at 3:45 AM
    #49
    Retired...finally
    Can you get the *fWT to work? That one didn't require Xgauge programming on mine to come up. Wasn't sure what it was but figured out it was coolant temp in degrees F water Temp.
    At first my mind read it as *WTF
  20. Oct 1, 2021 at 7:22 AM
    #50
    Bammer
    Monroe, CT
    Yeah water temp works, I just can't get to a screen to program?
  21. Oct 1, 2021 at 9:01 AM
    #51
    Retired...finally
    The manual walks you right through getting to the xgauge screen. Some say I resemble a neanderthal and I did it.
  22. Oct 1, 2021 at 9:53 AM
    #52
    Bammer
    Monroe, CT
    Whats below a Neanderthal? THATS ME ! :)
  23. Oct 1, 2021 at 10:20 AM
    #53
    Retired...finally
    Twin sons of different mothers
  24. Oct 1, 2021 at 10:53 AM
    #54
    Bammer
    Monroe, CT
    :cheers:
  25. Oct 1, 2021 at 7:48 PM
    #55
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    Well, I feel like an idiot. I realize now I had a typo. :facepalm:Worked after fixing!
  26. Oct 5, 2021 at 5:19 AM
    #56
    Bammer
    Monroe, CT
    Want to come do mine??
  27. Oct 5, 2021 at 6:18 AM
    #57
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    here's a pretty good video describing the steps:
    0:57 What is the X-Gauge feature?
    1:20 Where to find commands.
    2:35 How to check for Protocol.
    4:11 Creating a custom gauge.
    Oey12 likes this.
  28. Oct 5, 2021 at 6:33 AM
    #58
    Bammer
    Monroe, CT
    MUCH OBLIGED Sir ! :hattip: Very helpful
    classiccat[QUOTED] likes this.
  29. Nov 12, 2021 at 10:33 AM
    #59
    daveeasa
    David
    Just got my gauge installed yesterday. Excited to one day monitor trans temp if I can figure out the magic passwords to get there :)
  30. Dec 9, 2021 at 5:46 AM
    #60
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    So are you now able to monitor both pan temps and TC temps?
