SCS Ray 10 Gunmetal on 2018 Cement Tundra-Test Fit
Discussion in 'Wheels & Tires' started by Wildtrout, Sep 26, 2018.
  1. Oct 22, 2018 at 4:09 PM
    Wildtrout
    Wildtrout [OP] New Member
    Seattle
    2018 Tundra Crew Max
    OME BP51 Front and Rear, Complete de badge, ARE Z Series camper shell, Decked system, TRD CAI, painted hood bulge and grill surround, WeatherTech mats
    OLD MAN EMU BP51 at all 4 corners, minus the Dakar leaf pack. Used a 1” ToyTec block to level the rear. About 2.75 all around.
  2. Jun 25, 2019 at 11:35 AM
    Wildtrout
    Seattle
    Have since removed the block and went with the OME Heavy leaf pack in the rear.
  3. Jun 25, 2019 at 11:48 AM
    cart99
    cart99 New Member
    Russ
    2016 Tundra Platinum CrewMax
    Fab Four front bumper
    That looks awesome. Hoping there is an option to black out the bead-lock bolt heads when I order mine. Might resort to DIY if not.
  4. Jun 25, 2019 at 11:49 AM
    Wildtrout
    Seattle
    It’s a DIY. Be careful removing the bolts as they’re allegedly a little soft and can strip.
  5. Jun 26, 2019 at 7:52 PM
    kustomeyez
    kustomeyez New Member
    2019 Tundra double cab
    N-Fab steps AVS low profile window vents some front window tint 'N that's it
    DOPE
  6. Sep 9, 2020 at 7:58 AM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Perfect Setup. What camper shell is that?
  7. Sep 9, 2020 at 8:26 AM
    Zero One Actual
    285/75R18 Bronze Ray 10s. Cooper AT3 XLTs. No rubbing at all. You may need to do a new alignment.
    Pangaea likes this.
  8. Sep 9, 2020 at 8:57 AM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    legit setup
  9. Nov 8, 2020 at 2:48 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    I was thinking matte gray, now its matte gunmetal. Nice pairing!
