Seat heater install on 2014+ Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by trdlife, Jan 27, 2018.
  1. Nov 19, 2022 at 11:11 AM
    #61
    nocean
    nocean New Member
    Nick
    2014 Tundra + GFC
    I installed these and I don't think they're working right. I get maybe a bit of heat but maybe not, its subtle. I decided to dummy proof it and run it straight to the battery with a fuse to make sure power wasn't the problem. I get a light on the switch, but there's a new "green" wire that I'm not sure where to put. I tied it into something that was open near the USB plug. I don't know, directions kinda suck.
  2. Nov 19, 2022 at 4:13 PM
    #62
    NorthDyota
    NorthDyota New Member
    Nick
    2017 SR5 Crewcab
    Did you connect the ground?
    Jaypown likes this.
  3. Nov 21, 2022 at 1:44 PM
    #63
    nocean
    nocean New Member
    Nick
    2014 Tundra + GFC
    Ended up leaving the seats on during a 30 min drive and now they work. Maybe just needed to get something going? I don't know. Weird issue.
  4. Mar 25, 2023 at 5:49 AM
    #64
    prozac
    prozac New Member
    Zach
    Southern California
    2015 Inferno Orange Tundra TRD Pro
    see my build thread - https://www.tundras.com/threads/prozacs-2015-inferno-orange-trd-pro-build.122370/
    Does anyone have a more recent link of the kit on Amazon they’d recommend both OP and another link on this thread seem to be dead now
  5. Mar 25, 2023 at 7:47 AM
    #65
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I honestly just went on eBay and ordered a set with plugs I liked. I can get you the link of the ones I got if you like.
    #65
  6. Mar 25, 2023 at 8:12 AM
    #66
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
  7. Mar 25, 2023 at 8:47 AM
    #67
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I like those. I only had one blank spot so I went with the small circular rocker switches.
  8. Mar 25, 2023 at 8:54 AM
    #68
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I went back and read the one review that was visible. It says they suck and don't get hot. Dammit! I really like those controls. I have an SR, so I have many blanks.
    I wonder if other heating elements would be compatible to swap out, if I order them and they don't get hot enough.
  9. Mar 25, 2023 at 9:13 AM
    #69
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ironically, I just looked at my past order and it’s no longer available so I can’t post a link. Mine get very hot on the high setting. Hotter than factory IMO
  10. Apr 7, 2023 at 11:58 AM
    #70
    prozac
    prozac New Member
    Zach
    Southern California
    anyone have a wiring diagram for how they wired these? I was planning on tapping the power outlet in the console as well but figured maybe it would be smart to see exactly what others are doing, I've watched multiple youtube videos and seen everything from people tying them into the battery directly, to tapping into power outlet, but it's not clear where to use the accessory wire and where to use the power wire if you're tapping in. Ground is obvious but would just love to use the same setup someone has that is installed and has been working for a while so I'm not doing this twice
  11. Apr 7, 2023 at 12:03 PM
    #71
    Taco-Spike
    Two Trucks
    What switches are you using. OEM style or round universal?
    there are more connections with the OEM style
  12. Apr 7, 2023 at 12:04 PM
    #72
    prozac
    prozac New Member
    Zach
    Southern California
    I ended up going with this ebay set with the potentiometer
    #72
  13. Apr 7, 2023 at 12:25 PM
    #73
    Taco-Spike
    Two Trucks
    Gotcha
    I don't see all wires listed / function of that switch - but I'll list all of mine (4) wires per kit. Or I missed it in the descriptions.
    1. 12V power ~ below
    2. Ground ~ below
    Mine had (4) wires total in my (1) outlet. (2) power (2) ground. I couldn't tell if both center console and rear console were tied together.
    3. Switch power ~ I ran an add a fuse to the interior fuse boxed label seat heat
    4. Switch Illumination ~ I tapped my anytime rear camera illumination switch (below HVAC controls) wire since it was close. From a pigtail cargo light harness. (below) but can use anything close by like the shift gate light wiring etc.
    I will say it might be a lot for two seats but I mainly got them for the wife so will probably only run one seat at a time. Running directly to the batter would be a better overall application. I just wanted to use what I had close by.
    I've tested them three times and they got pretty warm.
    Last, I completely terminated the center console cig port. I never used it anyway and have three others close by.
    result
    #73
    panicman and Jaypown like this.
  14. Jul 14, 2023 at 3:21 PM
    #74
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Interesting. I haven’t had an issues with mine. Especially in the cold. I can feel the heat on mine come on within like 2 minutes of turning them on.
    edgewardoe[QUOTED] likes this.
  15. Dec 18, 2023 at 7:02 AM
    #75
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    I recently purchased ^^^these^^^ switches to replace the 3-pole, button type rocker switch(s) currently installed on my seats. Has anyone else attempted this job? If so, any insight you could share would be greatly appreciated.
  16. Dec 18, 2023 at 12:48 PM
    #76
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Post #75 on this thread used them but as the whole kit. I don't see any reason why you couldn't just splice in the wiring.
  17. Dec 18, 2023 at 1:32 PM
    #77
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    Thank You Sir. I plan on jumping on this late this week. I saw the post you referenced, and was able to glean good intel there.
  18. Dec 18, 2023 at 1:59 PM
    #78
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Nice! Good Luck. It’s a well worth it upgrade
  19. Dec 20, 2023 at 12:43 PM
    #79
    brkncly
    brkncly New Member
    Oregon
    Do you have a link where you bought those switches from? Please & thank you!
  20. Dec 20, 2023 at 1:42 PM
    #80
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    #80
  21. Dec 20, 2023 at 1:43 PM
    #81
    chuck416
    chuck416 New Member
    chuck
    Sharpsburg GA
    This is the switch(s) ONLY. If you want the heaters, they are also available.
  22. Jan 28, 2024 at 9:13 AM
    #82
    Shoe2015Tundra
    Shoe2015Tundra New Member
    2015 Tundra SR5 TRD
    CarABC wireless CarPlay, custom double USB power outlets in dash, heated front seats (Rostra 260-1870-TOY kit), custom 115v outlets on rear of center console
    I just installed the Rostra 250-1870-TOY kit - https://www.mnrelectronics.com/250-1870-toy-seat-heater-toyota-vehicles-w-custom-switch/. So far I only have done the passenger seat, but I also grabbed the Rostra 250-2951 - https://www.mnrelectronics.com/250-2951-source-power-plus-w-switch/ To power it on automatically when the truck starts and off when it turns off.
    Initial thoughts.. the seat heaters and switch are awesome! They work very well, and took like 3 hours taking my time to do it all.
    The only issue I have is that the Source Power Plus isn’t relaying properly. It is keeping the seat heater on until you turn off the seat switch. Then it relays off and doesn’t come back on until you turn the truck on again. “Reprogramming” it according to the instructions doesn’t seem to do anything.
    Anyone on here ever use this - and did you get it to work? It’s wired correctly (yellow to the battery, black to the frame, and red to the positive for the seat heater), so my only other thought is does it not work like the directions say? I have seen the 20 flash mode and confirmed it, so it should be in power mode.
    Anyway, it’s a very nice upgrade that my wife has been disappointed that my truck didn’t have seat heaters, and now it does! So thanks for posts like this and all your help in advance!
  23. Jan 28, 2024 at 10:30 AM
    #83
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't see the point of the power-plus switch.:confused:
    I tapped the seat heater power into the 12V socket circuit in the console, they only get power when the truck is 'on'.
    If you want the seat heaters 'on' when you start the truck, make sure they are 'on' when you shut the truck off.
    They will come on when you restart the truck.
    You're already doing that with the power-plus switch, right?
    Used the inline fuse that came with the kit..
    Only reason I installed seat heaters was for the wife.
    But I find myself using them a lot more than I thought I would..:thumbsup:
  24. Jan 28, 2024 at 1:00 PM
    #84
    Shoe2015Tundra
    2015 Tundra SR5 TRD
    it allowed me to not take the power from the 12 V outlets. The point of that would be to allow those to still run at full power for other accessories.
  25. Jan 28, 2024 at 1:23 PM
    #85
    1lowlife
    DADA
    2014 MGM DC SR5
    I see.
    I didn't realize anyone actually plugged things into those sockets.
    I never have..
    Good luck..
  26. Jan 28, 2024 at 4:49 PM
    #86
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    In four years of ownership, never used mine other than to tap power for my heated seats :rofl:
    1lowlife[QUOTED] likes this.
  27. Jan 28, 2024 at 6:42 PM
    #87
    1lowlife
    DADA
    2014 MGM DC SR5
    I added a voltmeter with USBs for one of mine in the dash.
    But I only use the USB if the wife needs to charge her phone...:D
    aawawv8m_zpsridvswcc_4118b6230759fd2ba4953355028e2667160dfca8.pngcq2vfxrw_zpsgkik3zng_98530dd04f3427c8e8ac95a71dbc4218518ff7c6.png
    Jaypown[QUOTED] likes this.
