Show us your latest detailing purchase
Discussion in 'Detailing' started by Pudge, Oct 8, 2019.
  1. Oct 22, 2019 at 8:28 AM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    What do you use to seal the lights after polishing? That seems to be the biggest issue with any headlight restoration
    Rocko9999 likes this.
  2. Oct 22, 2019 at 8:41 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    That polish/ restoration product claims 1 year protection. It works in like a wax as my last step. I remind all my clients to wax the lights at least once yearly to protect them from UV rays and re-yellowing. Failure to upkeep is the biggest reason lights will re-yellow or haze over again after a restoration.
    There is a product from Mickees 37 that offers 3 years protection. I believe it’s closer to a ceramic coating that will seal them for that amount of time. I want to purchase it to offer longer protection but it’s pretty pricey. Something like $60 for a 4 ounce bottle.
    Pudge[QUOTED][OP] likes this.
  3. Oct 22, 2019 at 8:41 AM
    War Machine
    War Machine SSEM # 5 3MW
    Very nice! I have the same question as @Pudge . The one headlight restoration I did went back to hazed up after a few months.
    Pudge[OP] likes this.
  4. Oct 22, 2019 at 8:45 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I responded to pudge the same time you replied to me. Lol
  5. Oct 22, 2019 at 8:46 AM
    Pudge
    CT
    I have done a few and they always looked so good for a short period then hazy. I hear that using 2k clear is now the way to go. It used to be automotive spray lacquer. I think a polymer, sio2, or ceramic product would work okay but again you'll only get a few months, whereas the new 2k clears are pretty amazing as far as longevity goes
  6. Oct 22, 2019 at 8:47 AM
    Pudge
    CT
    And I responded before knowing you responded.
  7. Oct 22, 2019 at 8:51 AM
    Pudge
    CT
    2k clear would definitely be the answer but I think you would only get one use out of a can because they are a 2 part "paint" that you mix by popping something on the can. Not very cost effective is you want something to do multiple sets of lights at different times. Maybe regular UV protective clear coat would be okay as well.
  8. Oct 22, 2019 at 9:11 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yeah I’ve tried 3 different kinds of clear on my own lights here at home. I got rustoleum enamel to look good on some but not so good on others. Rustoleum also has a lacquer clear that got worse results. Maybe it was a bad painting process but I couldn’t get it to come out clear after drying.
    I purchased a can of 2K because of mixed results with others. I however didn’t know it was something that has to be activated and used within 48 hours. It would probably be the best bet if I did 5-6 cars per day because I could use it up and not throw away money.
  9. Oct 22, 2019 at 9:13 AM
    Pudge
    CT
    Yeah that's the only drawback to the 2k, well as far as I know anyway. I have never used it but from reading up about it, it's pretty damn good stuff except the needing to use it up all at once.
  10. Oct 22, 2019 at 9:18 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Depending on the wax and the washing techniques. I always suggest my clients to do it every two months, as they normally don't follow up with a regular hand wash but rather choose to use automatic car washes or touchless wash, both of which use harsh chemicals and accelerate degradation of the wax.
    The Mckees37 headlight coating https://www.mckees37.com/headlight-coating.html works great, I've used it on my cars and B pillars black plastic covers and the results are awesome.
    Alternatively I have also been experimenting, on my brothers car, using Mckees37 Hydro Blue SiO2 spray as sealant/protection, after restoring his highly yellowed headlights, for 7 months now and there is no sign of yellowing or cloudiness on the restored plastic, clarity remains optimal. I have been applying the spray once every two months.
    War Machine and Pudge[OP] like this.
  11. Oct 23, 2019 at 7:58 AM
    Tmank87
    Tmank87 New Member
    Just pass along the cost, a true business :)
  12. Oct 23, 2019 at 8:14 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've had good luck finishing head lights with Meguairs Headlight coating. Like $8.xx off Amazon. The little can will cover a handful of cars doing 2x coats each.
  13. Oct 23, 2019 at 7:30 PM
    Pudge
    CT
    I don't think this is the one you got, this looks smaller and cheaper by quite a bit. I wonder if it would dry my truck in a reasonable amount of time? I have about an hour to decide if I'm gonna spend money I really shouldn't, plus what will I do with all my griots PFM drying towels?
    https://www.detailedimage.com/Metro-Vacuums-M11/Blaster-Car-Dryer-P917/
    Not much time left but I have had this is my cart at detailedimage since last night. 15% off rarely covers the metrovacs. I would likely add a few more other items to get my money's worth as far as the shipping cost goes. What do you think? Don't mind the junk in the cart, its parts of the 15% coupon.
  14. Oct 23, 2019 at 7:43 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    The Master Blaster unit I purchased for detailing is the 8hp unit. It retails around $400. It’s amazing how quick you can dry off a vehicle.
  15. Oct 23, 2019 at 7:47 PM
    Pudge
    CT
    Dude thank you for your quick response, I was considering this 4hp unit at $200 as that's about $60 off normal. I'm afraid this isnt enough power and I will regret not saving up or waiting for the 8hp model.
  16. Oct 25, 2019 at 6:18 PM
    OV-1794
    OV-1794 New Member
    @Pudge did you end up purchasing the master blaster? If so, let me know if you want to offload the Griot's pfm towels.
  17. Oct 25, 2019 at 6:21 PM
    Tmank87
    Tmank87 New Member
    Likewise!
  18. Oct 25, 2019 at 6:40 PM
    Pudge
    CT
    Sorry gents, I couldn't pull the trigger. And I opened up my new XL edgeless PFM towel today to try it out. Wow that thing is bad ass, it seems even more absorbent than the medium size. 2 passes total for the hood and its dry, I'll be using this one more often now that i tried it. I also used my 18v ryobi mini blower to help dry and that little thing does well with a 4ah battery in it. Some day I'll get a real dryer but for now its electric leaf blower and PFMs
    OV-1794[QUOTED] and War Machine like this.
  19. Oct 25, 2019 at 6:42 PM
    #49
    War Machine
    Keep in mind Shine Supply has the master blasters, and we get a discount.
  20. Oct 25, 2019 at 6:51 PM
    #50
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    How do you like that glass polish?
  21. Oct 25, 2019 at 7:03 PM
    #51
    OV-1794
    OV-1794 New Member
    No worries and glad you're happy with the way things worked out. I think a dryer would be nice but certainly more of a luxury than a necessity.
  22. Oct 25, 2019 at 7:14 PM
    #52
    Pudge
    CT
    It's okay buy I think my expectations were too high. It did a really, really good job of cleaning the glass and I think it took out some scratches but not anything major. Glass is just too hard. I think polishing it like you do your clearcoat and hoping for the same results is unrealistic, so my expectations were unrealistic.
    I do not regret buying it or the rayon pads cuz they were both cheap. I do not think a good compound or polish like meg's M105 or M205 would do as good of a job as the ceriglass if that means anything. I will definitely try again and do my side windows come spring time, I will use more water (i think water plus some carpro immolube sprayed liberally will help a lot) and spend more time.
  23. Oct 25, 2019 at 8:40 PM
    #53
    19TundraPlatinum
    Maryland
    Glass cleaning Is my downfall when it comes to detailing
  24. Oct 26, 2019 at 3:52 AM
    #54
    Tmank87
    Tmank87 New Member
    Completely agree. I roll with my Milwaukee blower for the time being!
  25. Oct 26, 2019 at 3:53 AM
    #55
    Tmank87
    Tmank87 New Member
    Tell me more about this discount. I've been interested in some wise guy, hear it's great stuff.
    Other recommendations if I'm ordering?
    War Machine[QUOTED] likes this.
  26. Oct 26, 2019 at 4:45 AM
    #56
    War Machine
    Use the code tundra10 at checkout for 10% off.
    Pretty much everything they have is top notch. I haven’t tried any of their compounds or polishes, but everything else I’ve used has been great.
  27. Oct 26, 2019 at 5:06 AM
    #57
    Tmank87
    Tmank87 New Member
    Awesome. Thanks guys. Expensive place here! :spending:
  28. Oct 26, 2019 at 7:21 AM
    #58
    owb2gp
    owb2gp New Member
    ID
    Same here.
  29. Oct 26, 2019 at 7:26 PM
    #59
    Pudge
    CT
    Well I made an impulse buy last night at autogeek at 1159pm. 25%+free shipping +free gifts+ triple miles bonus. Anyway I don't even remember what all I ordered, I think brake buster, solutions finish, ONR and some clay mit towel combo, and some other stuff. All stuff I "needed" to buy at a good deal lol. I'll post up when it gets here.
    War Machine likes this.
  30. Oct 26, 2019 at 7:40 PM
    #60
    War Machine
    My wife surprised me with this:
    Borador, WFD473, owb2gp and 1 other person like this.
