Show your Tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by G-manCO, Nov 13, 2017.
  1. Jan 20, 2020 at 7:53 PM
    #241
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    How has this held up?
  2. Jan 20, 2020 at 7:56 PM
    #242
    dv8TRDPRO
    Chattanooga
    How are liking it now?
  3. Jan 22, 2020 at 11:53 AM
    #243
    russellthom
    russellthom New Member
    R
    2015 Toyata Tundra SR5 Offroad
    Too many to list
    Undercover Ridgelander
    equin and Rex Kramer like this.
  4. Jan 29, 2020 at 11:40 AM
    #244
    Delvys-perez
    Delvys-perez New Member
    2007 Toyota Tundra Doblecab Limited
    I saw a lot of reviews about this cover and I decide to order it and I'm just waiting for it. I searched and on youtube I found a video with a coupon code of 15% OFF. I order it with the platinum package the price of the cover is 799 plus the package is 199 mines the discount of 149. I'm excited waiting for it
  5. Jan 29, 2020 at 3:59 PM
    #245
    dv8TRDPRO
    Chattanooga
    How has it held up?
  6. Jan 30, 2020 at 5:09 AM
    #246
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    I have the T3 no issues or leaks.
  7. Jan 31, 2020 at 1:18 AM
    #247
    Dusty Toy
    Dusty Toy New Member
    Great Falls, MT
    2020 Toyota Tundra Crew Cab SR5 TRD
    1.5" front spacers, ARE Outlander Topper, Flowmaster Super 10 dual exhaust
    I own a Tonneau cover for my bed. Except for minor scratches that are buff-outable, it's in like new condition. I bought the truck with it, but am seeking to replace it with a topper.
    I have NO CLUE as to what to ask for it. My truck is a '12 double cab with 6 1/2 ft bed.
    Your thoughts?
  8. Feb 2, 2020 at 2:15 AM
    #248
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    I got a lomax that arrived yesterday. I’m having trouble getting the cover to lay centered on the side rails, ie even overhangs on both side of the bed and square across the back of the tailgate.
    I spent quite a bit of time trying to fine tune the side rail positions but none of it really made much difference, still seems like the cover overlaps the left side rail more then right and the cover doesn’t look square against the tailgate. I’m starting to wonder if the actual bed is of the truck is square.
    I’m a little disappointed with the gap I have between the end of the cover and the top edge of the tailgate. It seems easier then I expected for someone to stick ther fingers under the cover lip and rip the cover right up if they really wanted to get in. Hoping some more adjustments with the rail might get the end of the cover to sit lower and tighter to the tailgate.
    Steelerjax likes this.
  9. Feb 2, 2020 at 3:29 AM
    #249
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Mine required no adjusting and fit snug and flat as soon as I dropped it on there. May sure the brackets you install mimic the pictures. The gaps/teeth need to line up for proper installation. I just threw them all on there before realizing the photos were different and the gap between the bracket's teeth and the bed looked different.
    If you cant figure it out, I'll pop the cover off and PM you some photos of how mine looks when the sun comes up.
  10. Feb 2, 2020 at 8:00 AM
    #250
    jlarkin1918
    Jared
    C0B159A8-0520-43B5-85A4-1A8F43ACEDBE.jpg 551C41E5-4DEA-4A80-8F89-4E5C9950DDB3.jpg D17BBC7E-E032-42A1-B043-09F631831322.jpg 25FE4A08-F159-4123-AF8E-BFEBB391A147.jpg
    It seems a little better today after the last round of adjustments I made last night and then sitting closed overnight seems to have helped if settle into place a little better. But it’s still not sitting evenly on each side. The left side rail has the frame on the under side of the cover snug up against it and the right side still has a gap. You can also see it looks uneven on the top of the bed rails on each side. This is probably just my OCD and it looks like the cover will function fine but I’m still hoping I can adjust it so the gaps between the rails and the cover frame are the same on both sides and so the latches are engaged evenly on both sides.
    I’m not sure if the spray on bedliner might be uneven and causing some issues.
  11. Feb 2, 2020 at 8:26 AM
    #251
    Ckatz53
    Ckatz53 Newish
    MD
    Toyota factory liner or aftermarket? I'll take pics of mine in a bit. Mine sits flush I know that but I never paid much attention to left/right overhang.
  12. Feb 2, 2020 at 9:26 AM
    #252
    Ckatz53
    Ckatz53 Newish
    MD
    20200202_122222.jpg 20200202_122229.jpg 20200202_122247.jpg 20200202_122156.jpg 20200202_122150.jpg
    @jlarkin1918 here's how mine sits. Flush and even both sides and even against the cab and tailgate. Uses factory bed rails and cleats still installed.
    tonedraw likes this.
  13. Feb 2, 2020 at 9:51 AM
    #253
    jlarkin1918
    Jared
    Thanks for all the pictures.
    Good news is I measured everything and double checked all my brackets and everything was installed correctly and the cover itself is square.
    Bad news is I figured out the issue is one of my bed sides leans out about a 1/4” up top by the tailgate. So the cover isn’t the problem.
    Not sure if it’s even worth worrying about, I’m guessing I’m not the only one with a truck bed that’s out of square.
  14. Feb 2, 2020 at 9:52 AM
    #254
    Ckatz53
    Ckatz53 Newish
    MD
    I've heard of a few folks with this and Toyota responding with essentially "it's a truck, not a luxury car." I love the Lomax tho. Pickup some Aerospace 303 UV protectant for it tho!
  15. Feb 5, 2020 at 4:22 PM
    #255
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I installed spacers on my Truxedo Pro X-15 to help with that.
    Before...
    After...
    Wiesy442, jlarkin1918 and Hbjeff like this.
  16. Feb 10, 2020 at 2:28 PM
    #256
    dv8TRDPRO
    Chattanooga
    Add an UnderCover Armor Flex Tonneau Cover. It comes with a Linex finish, prop rods to hold the cover in place when folded all the way up and a five-year warranty. Pretty dry so far, we have had a ton of ran over the last week and only had a little water at the tailgate. Which I expected to have that issue
    GGODON and eddie98 like this.
  17. Feb 13, 2020 at 1:03 PM
    #257
    jlarkin1918
    Jared
    10 day update on the Lomax:
    I eventually discovered my bed itself was slightly out of square which makes the cover look slightly out of square but it’s not.
    I‘m not sure if other low profile cover options would have been better or worse with my bed issues, I’m thinking worse if the seals weren’t big enough to seal tightly while sitting between the bed side rails that are not square.
    Even with the install issues and my OCD I still am happy with the Lomax. The seals on the sides are pretty water tight even if the overhang is a little smaller on one side. I’ve been through the car wash a few times and had some highway driving in moderate rain and sleet and the water in the bed has been minimal and mostly by the tailgate.
    I think my tailgate sits slightly lower than the sides so the seal isn’t quite as tight, I might look into adding a bigger seal and adding a full tailgate seal kit in the Spring when I have nicer weather for these truck projects.
    Overall I’m happy so far with the look and function of the Lomax.
  18. Feb 16, 2020 at 4:37 PM
    #258
    Dos Cylindros
    Dos Cylindros New Member
    2022 1794 Edition Smoked Mesquite
    Still love it. Very versatile and well built.
  19. Mar 2, 2020 at 5:12 AM
    #259
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    I have an Extang Solid Fold on my 2012 regular bed. It was on the truck when I bought it used in 2019. I like it and it looks good but I do get a little trickle of water in the bed when it rains at the front of the bed, not at the tail gate. I'll investigate where the gap is20200301_101925.jpg when weather warms up here.
  20. Mar 2, 2020 at 5:58 AM
    #260
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    I had an Extang 2.0 Solid Fold and it leaked at the joints. (trickles of water only) I went to a Tyger Vinyl trip fold and it was a dry as can be. I now have the Diamondback SE and it is terrific (and dry). Just listed the Tyger locally here in NC
  21. Mar 16, 2020 at 9:13 PM
    #261
    2020TNtundra
    2020TNtundra New Member
    So what options are out there for a roll back with the stock bed rail system??
  22. Mar 17, 2020 at 6:34 PM
    #262
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    Very nice. Looking into it for mine.
  23. Mar 29, 2020 at 5:48 PM
    #263
    Ketchumj
    Ketchumj New Member
    South Texas
    2020 Tundra SR5 4x4 Double Cab
    2020 Tundra 4x4 SR5 Magnetic Grey – TSS Off Road Toytec Complete performance 3” Lift kit with Aluma Series 2.5 Coilovers, SDP Upper Control Arms, Black Rhino 18” Gauntlet Wheels - +12 Offset, Nitto Terra Grapplers – 295/70R18, Victory 4x4 strike Front Bumper, Fab Fours Premium Rear Bumper, Smittybilt X20 12k Winch
    can you show pictures of how it is mounted? I have the factory bed rails, and i dont want to lose them.
  24. Apr 8, 2020 at 1:42 PM
    #264
    Dos Cylindros
    I removed my bed rails. If you look up the cover on YouTube a member here posted a video showing how to keep them.
  25. Apr 8, 2020 at 3:33 PM
    #265
    Ketchumj
    Ketchumj New Member
    South Texas
    Thanks. I see how he did it. I like it.
  26. May 2, 2020 at 11:21 AM
    #266
    Charruabrew
    Charruabrew New Member
    Wappingers, New York
    2014 Tundra 1794 Edition
    This is the one that came with my 2014 1794.
    Extang solid 3 panel fold. One behind cab does not fold.
    Henry1jg likes this.
  27. May 2, 2020 at 12:20 PM
    #267
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    RetraxPRO MX
    Low profile, water tight, lockable and very sturdy.
    GGODON, Y0TA PR0 and (deleted member) like this.
  28. May 29, 2020 at 3:15 PM
    #268
    aceshigh73
    aceshigh73 New Member
    2020 Tundra Sport Dbl Cab Voodoo Blue
    Tyger T1 roll-up cover from Amazon. Fresh install took about 45 mins because I over analyze everything...
    I used the bedrail clamps. Went well for the most part. Supposed to rain tonight so i'll see how it holds up.
    TK1979, jewsNbrews and MICKs18yota like this.
  29. Jun 2, 2020 at 8:17 PM
    #269
    Drifthopper
    Drifthopper New Member
    '20 Limited Double Cab Silver Sky
    1918....Did you get a bed cover..???.if so... what kind..?
  30. Jun 2, 2020 at 8:19 PM
    #270
    Drifthopper
    Danny......
    For those tyger fans on here, which tyger model is it you have and like?
    Website shows T1, T3 and a T5 wondering which one it is that people are posting about?
    Which one did you get..?
