Siblue’s TRD Off Road
Discussion in '3rd Gen Builds (2022+)' started by Siblue, Sep 23, 2022.
  1. Aug 9, 2023 at 5:22 AM
    #61
    Siblue
    Siblue [OP] Well-Known Honda Butt Pirate on GRC forum
    Ryan
    22 Tundra Limited
    Yota802[QUOTED] likes this.
  2. Aug 11, 2023 at 11:01 AM
    #62
    Siblue
    Ryan
    22 Tundra Limited
    Had an extra VLEDs rear footwell kit and wired up front and rear dome lights.
    Will have night output pics when it’s dark out.
    Cheesy double sided tape top mount but it’s temporary until a Meso option is available.
    kirkb, dan81 and doublethebass like this.
  3. Aug 11, 2023 at 11:03 AM
    #63
    Siblue
    Ryan
    22 Tundra Limited
    Hope to be a GR owner soon and found this OEM engine decal.
    Stuck it above the rear view mirror.
  4. Aug 11, 2023 at 7:39 PM
    #64
    doublethebass
    doublethebass New Member
    Minneapolis
    2017 Tacoma TRD Pro 6MT
    GR Corolla?
  5. Aug 11, 2023 at 7:44 PM
    #65
    Siblue
    Ryan
    22 Tundra Limited
    Yes
    doublethebass[QUOTED] likes this.
  6. Aug 11, 2023 at 8:27 PM
    #66
    Siblue
    Ryan
    22 Tundra Limited
    Finally the illumination I wanted.
    I was hesitant because how it looked cosmetically but the function over form wins.
    kirkb, DannyD303, dan81 and 1 other person like this.
  7. Aug 11, 2023 at 8:33 PM
    #67
    doublethebass
    Minneapolis
    how are you liking the truck compared to your Tacoma now that you've had it a while? I'm hesitant to give mine up
  8. Aug 11, 2023 at 8:40 PM
    #68
    Siblue
    Ryan
    22 Tundra Limited
    I’m still liking it due to size and power but I do miss modding Tacomas. I wish I could have both. Tacomas are great for everyday use, the Tundra is big and clumsy for daily use. Hope the GRC will fill that void.
    doublethebass likes this.
  9. Aug 12, 2023 at 9:52 PM
    #69
    Siblue
    Ryan
    22 Tundra Limited
    Didn’t want black but it was MSRP.
    Will create a separate build thread for the GRC.
    Tundra build will continue to be updated but at a slow pace.
    DannyD303 and doublethebass like this.
  10. Sep 13, 2023 at 5:56 PM
    #70
    Sonnytundra
    Sonnytundra New Member
    Sonny
    Pittsburgh
    2021 Smoke Mesquite Tundra
    Truck looks great! Just curious about how difficult the install was of the dash lights?
  11. Sep 13, 2023 at 7:42 PM
    #71
    Siblue
    Ryan
    22 Tundra Limited
    Driver side is just a slight trim on the dash piece and LED clips right in
    Passenger side no holes for the LED clips behind the trim piece.
    The LED is literally sandwiched in between outer dash piece and soft portion
    Sonnytundra likes this.
  12. Sep 14, 2023 at 12:55 PM
    #72
    Sonnytundra
    Sonny
    Pittsburgh
    Thank you for your reply. One more thing if I may. How did you run the wiring. Sorry if I duplicated this post. Not real good at posting on forums.
  13. Sep 14, 2023 at 1:25 PM
    #73
    Siblue
    Ryan
    22 Tundra Limited
    Running the wires with side panels removed I found to be the easiest. Also dropped down the lower dash panels and zip tied away from heater core and steering column.
    Hope this helps.
  14. Sep 14, 2023 at 1:29 PM
    #74
    Sonnytundra
    Sonny
    Pittsburgh
    Yes it does and thanks again!
    Siblue[OP] likes this.
  15. Sep 15, 2023 at 4:47 AM
    #75
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Pics or f the under seat ones? Thinking f adding blue ones to the back to match the front ones. Worried they might be way to bright though…
  16. Sep 15, 2023 at 4:56 AM
    #76
    Siblue
    Ryan
    22 Tundra Limited
    The white is only when doors are open
    I have light blue when parking lights are on when driving
  17. Sep 15, 2023 at 5:11 AM
    #77
    Ipaddick
    Ipaddick New Member
    Canada
    Sorry. Blue is the one I’m wondering about!
    Thanks
  18. Sep 15, 2023 at 5:29 AM
    #78
    Siblue
    Ryan
    22 Tundra Limited
    From my earlier posts
  19. Sep 15, 2023 at 5:31 AM
    #79
    Siblue
    Ryan
    22 Tundra Limited
    I finished the front doors and need to run wires to the rear doors. I might add the blue for the rear footwell. I have extra parts for them.
    Been working on the Corolla lately.
  20. Sep 15, 2023 at 12:14 PM
    #80
    Siblue
    Ryan
    22 Tundra Limited
    Pick up my will call from Eibach
    Pro lift Stage 1
    Front 2.6”
    Rear 1.1”
  21. Oct 15, 2023 at 6:22 PM
    #81
    YOTA_IL
    YOTA_IL New Member
    How did you get that I don’t see on their site?
  22. Oct 15, 2023 at 7:06 PM
    #82
    Siblue
    Ryan
    22 Tundra Limited
    I’m called them directly since I’m local
  23. Nov 5, 2023 at 6:04 PM
    #83
    Spakylpm
    Spakylpm New Member
    2024 Tundra
    Siblue, what is your opinion on these Recon's thinking about purchasing same size?
  24. Nov 5, 2023 at 7:23 PM
    #84
    Siblue
    Ryan
    22 Tundra Limited
    They’ve been great so far. I’d purchase again
    Spakylpm[QUOTED] likes this.
  25. Nov 7, 2023 at 8:48 AM
    #85
    Zeke21
    Zeke21 New Member
    Couple of questions regarding the interior oem lighting.
    You mentioned the door lighting just clipped in. did you mean it mounted in place or the harness clipped in and you did not need to wire it up to a power source? I know you mentioned wiring the footwell lights to the center console light, if you had to power the door lighting did you go into the same circuit as the footwell lights?
    What about the full panel led bars for the doors make it a difficult install? Does it require cutting to fit the bar?
    Last did you need to trim the dash panels to fit the bar leds?
    Thank you.
  26. Nov 7, 2023 at 9:24 AM
    #86
    Siblue
    Ryan
    22 Tundra Limited
    Each Door LED illuminating cubby will snap in to factory clips. You’ll notice a cavity in your door panel, once you remove the window switch panel you notice the factory opening. Front two doors will need to be hard wired to parking lamp circuit.
    Always always test using a digital multimeter DMM. Don’t rely on someone shouting out wire colors.
    Rear doors you will need to run wires to door jams, I’ve tested the switch wires and no parking lamp circuit(it’s multiplexed)
    Footwell white (double sided tape that came with VLEDs universal kit) is wired to dome light circuit wiring found and ran to roof console.
    Footwell light blue (also clips in factory provisions) is parking lamp wiring found in the left side switch panel for ambient lighting.
    Had the full OEM led bars for the doors but did not want to cut the door panel to make them work so I sold them.
    Yes both dash panels will need to be trimmed as mentioned to allow lighting to be visible.
  27. Dec 8, 2023 at 2:52 PM
    #87
    Siblue
    Ryan
    22 Tundra Limited
    Toyota Crown key glove fits the Tundra key nicely
  28. Dec 16, 2023 at 9:56 PM
    #88
    Kal149
    Kal149 New Member
    2022 Tundra SR5 4X2
    Nothing yet, brand new.
    Do you have the part numbers with their descriptions for all of the ambient lighting? I see the PN’s from your pics, just asking if you have that info.
  29. Dec 22, 2023 at 12:04 PM
    #89
    Siblue
    Ryan
    22 Tundra Limited
    Sorry for the delay. The only descriptions are what’s on the box.
  30. Jan 15, 2024 at 9:53 PM
    #90
    Siblue
    Ryan
    22 Tundra Limited
    Eibach lift was done over Xmas break.
    Also added TRD UCA and rear OEM harness bracket.
    doublethebass and Yota802 like this.
