Skunkworks DCSB
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Jun 6, 2023.
  1. Jun 21, 2024 at 12:52 PM
    #121
    breynolds
    breynolds New Member
    Future Tundra owner
    Indeed
  2. Jun 21, 2024 at 3:22 PM
    #122
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Nice man, I remember following along with your build when you had your sas first gen, my name over there was foxhead. I think we might have some mutual friends around NorCal from MTB as well. Good to see you over here! Sorry @Cruzer, back to your sweet ass build thread now lol
    breynolds[QUOTED] and Cruzer[OP] like this.
  3. Jun 21, 2024 at 8:34 PM
    #123
    breynolds
    Future Tundra owner
    Tight! I sold that truck back in 2021 for a ridiculous amount of money lol. Had to capitalize on the toy market. Truck was really over built for my uses anyway, just want to camp with the fam nowadays
    BreyTundy[QUOTED] likes this.
  4. Jun 22, 2024 at 4:56 PM
    #124
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Today I chopped off the rear body mounts.
    I did the final cut on the bed frame side, still need to do the one under the cab. But this picture shows there’s an 8 inch gap that I can’t close because the top of the frame is hitting the bottom of the cab, near the cab mount. I’ll need to C-notch the cab to fit the frame.
    ATV25, OldGuy03, BOSSARU and 4 others like this.
  5. Jun 22, 2024 at 5:13 PM
    #125
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    hey those look like nice straight cuts!
    Cruzer[OP] likes this.
  6. Jun 22, 2024 at 5:22 PM
    #126
    Cruzer
    Cruz
    Sunnyvale, CA
    I purposely didn’t post a close up of the final cuts cuz they’re not :p Started with the :sawzall: but it didn’t stay straight for long so I finished it with the plasma cutter.
  7. Jun 22, 2024 at 5:24 PM
    #127
    helidave
    flagstaff
    2015 DC 4x4
    Good from far, far from good. Like my welds :rofl:
    ATV25, BeauDacious, BOSSARU and 2 others like this.
  8. Jun 22, 2024 at 7:04 PM
    #128
    Cruzer
    Cruz
    Sunnyvale, CA
    Monet
  9. Jun 23, 2024 at 10:19 AM
    #129
    helidave
    flagstaff
    2015 DC 4x4
    Did monet do a lot of welding?
    ATV25, Mater and FrenchToasty like this.
  10. Jun 23, 2024 at 4:41 PM
    #130
    Cruzer
    Cruz
    Sunnyvale, CA
    I just ordered 8' of the thinnest walled (16 gauge) 2"x3" rectangular tube at my local metal store. I'm going to reenforce the back of the cab from the inside so that I can chop the exterior brace.
    Why such a long tube? I'm also trying to plan ahead because when the time comes to chop up the cab to tuck up the fuel tank I will use this tube as the base for the tunnel structure.
    OldGuy03 and BOSSARU like this.
  11. Jun 27, 2024 at 7:57 AM
    #131
    Wishbone Runner
    Wishbone Runner Toyota Connoisseur
    2019 Platinum
    Here is what I did on my 4Runner for body mounts using the ES bushings, I ended up plating the frame underneath and gusseting after tearing a hole in the frame :anonymous:
  12. Jun 27, 2024 at 9:11 AM
    #132
    Cruzer
    Cruz
    Sunnyvale, CA
    I like the use of the square tube; way more simple.
  13. Jun 27, 2024 at 9:22 AM
    #133
    Wishbone Runner
    2019 Platinum
    Yep, no additional welding needed to fab the mount, drilling the hole was the "hardest" part. After the above fixes, they have been good-to-go for the past three years.
  14. Jun 27, 2024 at 9:41 AM
    #134
    Cruzer
    Cruz
    Sunnyvale, CA
    Are you the one with an Atlas TC?
  15. Jun 27, 2024 at 9:54 AM
    #135
    Wishbone Runner
    2019 Platinum
    Yep! Did the body mounts at the same time as the Atlas install to reduce body movement and get the Atlas as close to the body as possible without worrying about it hitting. It hitting was actually how I noticed the body mounts had broken, I was getting crazy vibes in the cab from the body sitting on the Atlas, which I couldn't figure out, then found the cracked and drooping body mounts.
    BOSSARU and Cruzer[QUOTED][OP] like this.
  16. Jun 27, 2024 at 11:32 AM
    #136
    Cruzer
    Cruz
    Sunnyvale, CA
    Man! It was a video you did right? I've been looking for it hoping to copy how you did the crossmember mounts to the frame.
    ATV25 likes this.
  17. Jul 2, 2024 at 7:19 AM
    #137
    Wishbone Runner
    2019 Platinum
    No videos, but here is where the Atlas install starts in my build thread on TW.
    https://www.tacomaworld.com/threads/wishbone-runners-build.238998/page-63#post-22400441
    Here is the final crossmember setup, belly is totally flat, the driver side cat was moved up after this when I had the exhaust redone.
    texasrho83, Nic146, n0rth and 4 others like this.
  18. Jul 2, 2024 at 3:55 PM
    #138
    Cruzer
    Cruz
    Sunnyvale, CA
  19. Jul 14, 2024 at 3:29 PM
    #139
    Cruzer
    Cruz
    Sunnyvale, CA
    Closing in on that gap,
    At the expense of opening a bigger one :anonymous:
  20. Jul 14, 2024 at 5:58 PM
    #140
    Cruzer
    Cruz
    Sunnyvale, CA
    Need to cut off 2 more inches on the passenger side but this just about how it’s gonna look.
  21. Jul 16, 2024 at 4:45 PM
    #141
    Cruzer
    Cruz
    Sunnyvale, CA
    @Wishbone Runner when welding on a reinforcement plate onto the frame, how close should the plate be to the edges, in this case the top & bottom of the C-channel? Want to add a 3/16th plate to the rear of the hanger to support the body mount.
    Wishbone Runner and ATV25 like this.
  22. Jul 16, 2024 at 6:31 PM
    #142
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Are you going to get that bad boy on the Rubicon this year ?
  23. Jul 16, 2024 at 7:32 PM
    #143
    Cruzer
    Cruz
    Sunnyvale, CA
    Nope. I'm hoping to weld the frame back together and put everything back on so that I can do a shake down run in late August or early September. Want to make sure I'm close to home if the truck decides to to do the splits. If nothing breaks then I'll continue with the rest of the mods.
  24. Jul 19, 2024 at 12:42 PM
    #144
    Cruzer
    Cruz
    Sunnyvale, CA
    Look how cute! They cleaned it up and painted it too.
  25. Jul 19, 2024 at 5:05 PM
    #145
    BOSSARU
    BOSSARU Warthog_Tundra
    Splendora, TX
    2018 Super White 1794 4x4
    7" BDS, Kings, 40" STT Pros, 17" Method 702s
    At least we know you're not compensating :rofl:
  26. Jul 21, 2024 at 4:20 PM
    #146
    Wishbone Runner
    2019 Platinum
    In my experience, as close to the edge of the frame (where it starts to bend) as possible while still keeping the weld puddle on the vertical part of the frame, if that makes sense. If you think about the forces, getting the plate to the bend will transfer the load to the part of the frame that in in the other plane (vertical vs horizontal in this scenario), which is stiffer to resisting flex in the other plane.
    In my example that ripped off the first time, all the force was on a small patch and it just ripped the frame out, by spreading out the load with a bigger plate, as well as moving the forces seen at the edge of the plate to another axis, should create the greatest distribution of forces.
    Is all this necessary to prevent ripping the frame apart? I don't know, it wouldn't be too hard to math and figure out, but I just went overkill (I used 3/16" plate as well), and added gussets where I could. I also did rosettes in a few spots by drilling a hole through the plate and plug welding them for extra strength.
  27. Jul 22, 2024 at 11:16 AM
    #147
    Cruzer
    Cruz
    Sunnyvale, CA
    Thanks! Very good info.
  28. Jul 22, 2024 at 5:10 PM
    #148
    breynolds
    Future Tundra owner
    My fabricator mind has me wondering how I would accomplish this project. Would it have been easier to leave the frame as it was stock and shift the short bed up to the cab and make new mounts for it? Seems like quite a task cutting and splicing the frame and patching all that sheet metal. I think I just hate doing sheet metal work if I can avoid it lol
  29. Jul 22, 2024 at 5:24 PM
    #149
    Cruzer
    Cruz
    Sunnyvale, CA
    My goal is to shorten the wheelbase for better break over angles. The less I get hung up on the frame, the less I’ll break parts.
    helidave, OldGuy03, ATV25 and 2 others like this.
  30. Jul 22, 2024 at 5:42 PM
    #150
    breynolds
    Future Tundra owner
    Yeah moving leaf spring hangars forward is part of all that too which would shift the axle forward
