Smallest lift so I can get 35" tires?
Discussion in 'Suspension' started by NFSTundra, Feb 26, 2019.
  1. Feb 27, 2019 at 2:17 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Well, the setup he mentioned, or the one I’m waiting on completion currently? This the 6112/5160 with 6112 on top setting and icon aal in rear. Nitto ridge grappler, 295/70r18
    Pbed85, equin, Smiley and 2 others like this.
  2. Feb 27, 2019 at 2:19 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    But not for long...
    Hattori, TOYOTRD8 and NFSTundra[OP] like this.
  3. Feb 27, 2019 at 2:21 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    Btw, no complaints or issues at all with the 6112/5160 set up. I have absolutely no good reason for moving up to those kings. I blame bad influences @Hattori and @Erichudgins
    reywcms, Smiley, Hattori and 2 others like this.
  4. Feb 27, 2019 at 2:27 PM
    TheBeast The Beach
    where did you get those bypasses ? asking for a friend...
    Erichudgins and tbrown[QUOTED] like this.
  5. Feb 27, 2019 at 2:29 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    @Hattori is my man!
  6. Feb 27, 2019 at 2:41 PM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    I had nothing to do with this. Though looking at it, id like to think I did:)
    Hattori and tbrown[QUOTED] like this.
  7. Feb 27, 2019 at 2:42 PM
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Piggybacking on this thread a bit. I'm looking to do something similar to OP, going from the stock 18" with 275/65/18 to Ridge Grapplers in 295/70/18.
    Right now my plan is to install 6112's in the front at the 1.9" setting and nothing in the back.
    Will I rub in that situation with a +25 offset wheel? what if I stick with the stock wheels (+60)? Or would I be better off with a 285/70/18?
    Also, about how much past the fender (no flares) will that setup stick out on a +25 offset wheel?
    zcarpenter92 likes this.
  8. Feb 27, 2019 at 2:44 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    I have those same tires and had to trim bumper and do a small bmc on top setting
  9. Feb 27, 2019 at 2:46 PM
    Erichudgins
    Eric
    Murfreesboro, TN
    NFSTundra[OP] and tbrown like this.
  10. Feb 27, 2019 at 4:44 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Trevor = WIN:mudding:
    Erichudgins and tbrown like this.
  11. Mar 5, 2019 at 7:14 AM
    Nvlendy
    Nvlendy New Member
    Nick
    2011 silver crewmax
    I’m running ridge grapplers in 35x12.50r18 on +35 offset wheels, TRD pro suspension with one CB shim on each side. I removed all the mud flaps and had to heat and push in the inner part of the drivers side fender well liner just a touch. It was only rubbing while cutting the wheel in reverse.
    NFSTundra[OP] likes this.
  12. Mar 12, 2019 at 2:04 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I had to teach mine to wait until I let the tailgate down.. then the running start! LOL
    War Machine likes this.
  13. Sep 20, 2019 at 6:15 AM
    Lunchbox94
    Lunchbox94 New Member
    2012 Rock Warrior
    4.5” BDS suspension Lift, 35x12.50 Toyo RTs, 20x10 Fuel Kranks
    I’m running 35x12.50 toyos on a 4.5” BDS suspension lift on 20x10 wheels. No rubbing at full lock, had to trim little plastic and take off front flaps
    zachzap361 likes this.
  14. Apr 30, 2022 at 1:22 PM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    I know its an old thread but figured id post for anyone looking in the future . I made 325/60r20 fit with only a 2 in level. Bmc, pretty much had to get rid of the front fender liner on the bumper lol had to trim some of the bumper off and pinchweld mod for the 3 inches of pinch weld. 20x9 +20 offset. Tires are 35.5 x 13 basically
    pvn.beluga likes this.
  15. Sep 28, 2022 at 11:04 PM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    I’m also planning on upgrading to 35s on 3 in lift. You mentioned 35 will fit just take off the flaps.. I see other chop the frame to fit them? Will a 35 12.5 18 with +25 wheels fit without chopping?
  16. Sep 28, 2022 at 11:31 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra Cement DC
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    +25 and 35-12.5s will be very close to the body, but possibly no bmc. You will definitely need to remove or adjust the front mud flaps. The front bumper liner would need to be removed or heavily pushed in via heat gun. I was able to do 315-70/17 with +50 with no lift (just the mud flaps removed). As a prior poster said, lifting doesn’t usually add clearance as the tire would articulate into the stock position when off-roading.
    ctdomain likes this.
  17. Sep 29, 2022 at 5:37 AM
    Michael J Bird
    Michael J Bird New Member
    Michael
    2017 Black Limited
    Following ! Big time ! Thanks fellas !
