SoCalDave’s Overland Build
Discussion in '2.5 Gen Builds (2014-2021)' started by SoCalDave, Oct 5, 2017.
  1. Mar 20, 2018 at 7:17 AM
    #121
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Dude! Thank you for this post. Extremely useful.
    @papasmurf why don't you just buy the cross member??? Seems easier than making one
  2. Mar 20, 2018 at 9:22 AM
    #122
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    I’m going to now
  3. Mar 20, 2018 at 10:58 AM
    #123
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Nice build Dave.
    SoCalDave[OP] likes this.
  4. Mar 21, 2018 at 1:42 PM
    #124
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @SoCalDave
    I’ve been following your build and enjoying the quality a lot. Well thought out and well executed.
    From the first day I got my Tundra, I’ve been researching and watching dual battery setups and this is the cleanest I’ve seen so far. Not interested in having a battery in the cab, in the bed, or underneath.
    My question: can you list the rest of the items (controller, switch, solenoid, wires, etc) that you used to make the system complete? Pictures of where you mounted and routed the components would help immensely.
    I am probably not the only one hoping for this information.
    Thanks, and I’m looking forward to continued progress on your build!
  5. Mar 21, 2018 at 2:07 PM
    #125
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Awesome setup Dave... Tagging along since this is just about the same setup that I'm looking to do. Since I'm right here in MV, you are most likely "local", so I may hit you up with questions etc.
    LOVE the dual battery setup. Like most others, I really don't want to have the 2nd in the truck bed or in the cab.
  6. Mar 21, 2018 at 7:37 PM
    #126
    Sanjostuntrider
    Sanjostuntrider New Member
    Sweet Tundra Bud , Gave me a few more ideas for mine... Thankx
  7. Mar 21, 2018 at 10:52 PM
    #127
    SoCalDave
    SoCalDave [OP] New Member
    Dave
    2016 DC 4x4
    Thanks Ray!
    We'll be releasing our accessory tray shortly after which will provide a nice base for all of the components to mount next to the dual batteries. It should be large enough to mount an isolator, breakers/fuses, ground buss bar/post and a fused relay box/SPOD/Switchpros/Bussmann RTMR. More pics and details to follow!
    dcsleeper408 likes this.
  8. Mar 21, 2018 at 10:54 PM
    #128
    SoCalDave
    Dave
    2016 DC 4x4
    Sounds good bro!
  9. Mar 27, 2018 at 10:05 AM
    #129
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    just about to hit the order button on this and the ARB mount. thanks for getting these together.
  10. Mar 27, 2018 at 10:29 AM
    #130
    TUNDRAFROMTACOMA
    TUNDRAFROMTACOMA New Member
    Mark
    2018 Cement SR5 Tundra
    I just lifted my truck and added bigger tires. I’m having rubbing issues in reverse. can u advise me on the mods you did to your front wheel wells? I noticed in the beginning of this thread there is a picture but any advice is appreciated.
  11. Mar 27, 2018 at 11:06 AM
    #131
    G10dra
    G10dra Not a New Member
    I am new to this forum and just scrolling through everyone's builds threads and I must say I've yet to come across a double cab look this good.:thumbsup:
    SoCalDave[OP] and dcsleeper408 like this.
  12. Mar 27, 2018 at 8:10 PM
    #132
    SoCalDave
    Dave
    2016 DC 4x4
    Awesome bro! Post pics when you get it up and running!
  13. Mar 27, 2018 at 8:25 PM
    #133
    SoCalDave
    Dave
    2016 DC 4x4
    BMC, front bumper trim, alignment to maximize caster. It will also depend on your offset of your wheels.
  14. Mar 27, 2018 at 8:46 PM
    #134
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Love the set up!..thank you for sharing, definitely following along for the ride....
  15. Mar 30, 2018 at 6:29 PM
    #135
    J.M.
    J.M. New Member
    Northeast Texas
    2018 BBP 1794 Tundra
    ARB Twin Air Compressor w/ XFAKTR Mount AMP Research Power Running Boards, Bed Step, Bed Step 2 30% Tint Front w/ 5% Tint on the back Fold-A-Cover Bed Cover w/Caddy, Line-X Spray in Bed Liner Husky Floor Mats Front/Rear Console Organizer TRD Anti-Sway Bar American Flag, 4ID, and Duck's Unlimited Decals
    Just got this installed. I wish it came with a simple on/off switch at the compressor. The electrical was the worst part. I am not an electrical kind of person. My hats off to everyone who looked at that space and said "Self, I think that I could squeeze that ARB air compressor in there." :hattip:
  16. Mar 31, 2018 at 9:16 AM
    #136
    SoCalDave
    Dave
    2016 DC 4x4
    Looks good! Yeah, running electrical is not always fun. If you wanted to, there are extra compressor mounting holes on the XFAKTR logo side that can be used to mount a switch or accessories.
    Swamp_Dawg and Bates5450 like this.
  17. Apr 1, 2018 at 5:51 AM
    #137
    J.M.
    J.M. New Member
    Northeast Texas
    Thanks.
    I had to run the power lines to the battery. It was barely enough wire to get there. Then the rocker switch it came with, I did not want to run to the cab. Maybe I wired it wrong, but I had to attache the thing red/yellow wire to the battery too. It was labeled ignition switch. I am not sure if I messed that up or not. I have bad luck with wiring instructions usually being poor for lack of in-depth knowledge. The instructions didnt have wiring instructions for just the compressor. I was hoping to find a way to mount a water proof switch under the hood. Something like this, that is designed to be under the hood of a truck. If anyone has any suggestions please let me know. Thanks!PLTPL-SW26-Pilot-Automotive-Performance-Safety-Cover-Toggle-Switch.jpg
  18. Apr 1, 2018 at 2:38 PM
    #138
    SoCalDave
    Dave
    2016 DC 4x4
    Sit back and relax...
    dannysmith604, smslavin, J.M. and 2 others like this.
  19. Apr 6, 2018 at 11:54 AM
    #139
    SoCalDave
    Dave
    2016 DC 4x4
    Sneak peek on our complete dual battery kit with the accessory tray.
    itsdchz, dcsleeper408 and smslavin like this.
  20. Apr 6, 2018 at 12:21 PM
    #140
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    would you mind sharing specifics on that hose setup? looks like the way to go. :thumbsup:
    i jumped for the pre-order on the battery kit when i ordered the compressor mount. is the accessory tray going to be an add-on?
  21. Apr 6, 2018 at 8:44 PM
    #141
    SoCalDave
    Dave
    2016 DC 4x4
    Yeah man, it's works great. Once the regulator is set, attach the hoses and let it go. I used three 10 ft hoses, one 6 ft hose with clip ons, a manifold and a shut off valve.
    Accessory tray
    We're sending it to YotaBeast as two separate pieces. They'll probably do as bundle or by itself I'm guessing...
  22. Apr 17, 2018 at 8:50 PM
    #142
    SoCalDave
    Dave
    2016 DC 4x4
    XFAKTR Dual Odyssey Battery Mount and Accessory Tray
    After a few delays, our Dual Battery Mount and Accessory Tray is in production and is two weeks out! I apologize for any inconvenience to those who have pre-ordered. The Accessory tray provides a large two level surface for all the electronic goodies. It sits a little over 2 inches above the Relay/Fuse box so that buss bars and other items can be mounted on the bottom side as well at the top. It's hinged to swing open if you need access to the fuse box below.
    Check it out: https://xfaktr.com/#odysseyDualBat
  23. Apr 17, 2018 at 9:19 PM
    #143
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    It’s nice and all but $450?!? Little steep...
    jc153 and wasabi4 like this.
  24. Apr 18, 2018 at 6:54 AM
    #144
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    stoked. looking forward this and i'm glad i held off for awhile on the dual battery setup.
    looks like it extends over the fuse box, yes? not a big deal, i'll have to reach out to the yotabeast guys and get the accessory tray added to my pre-order. i'll have to move my switch pros head unit and fuse block as they are currently on the fuse box cover.
    SoCalDave[QUOTED][OP] likes this.
  25. Apr 18, 2018 at 8:49 PM
    #145
    SoCalDave
    Dave
    2016 DC 4x4
    Awesome!
    Yes, goes over the fuse box. Should have plenty of space for the switch pros and other accessories.
    smslavin[QUOTED] likes this.
  26. May 8, 2018 at 12:48 PM
    #146
    DividedSky
    Jeff
    Grab a Margarita at Rose's Cantina.
  27. Jun 24, 2018 at 4:02 PM
    #147
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I like your build and truck looks badass, what is your total ground clearance with 37s? Might be a stupid question but 37s on any size wheel provide the same lift height correct?
  28. Jun 26, 2018 at 4:43 PM
    #148
    boloson
    boloson New Member
    Would that accessory tray fit an arb twin compressor?
  29. Jul 5, 2018 at 2:29 PM
    #149
    JayPee
    JayPee New Member
    Chandler, Az or San Gabriel, Ca
    2017 Toyota Tundra Sr5 TRD 4x4
    in my dreams
    @SoCalDave are you guys up and running and still selling the mounts?
  30. Jul 24, 2018 at 11:06 PM
    #150
    Swamp_Dawg
    Swamp_Dawg New Member
    Greg
    2012 Silver Tundra TRD
    Four Wheel Pop Up Camper, Aluminess Ft Bumper, Warn VRS-12000 winch, KC 20” light bar, Bushwacker fenders
    Hi Dave, I’ve tried to reach out to XFAKTR and Yotabeast about the ARB Twin mounts. Do you have a connection with them? I’d like to order one as soon as I can so I can get mine mounted. Thanks.
