SPC UCAs Too Close to Tire?
Discussion in 'Suspension' started by AggiePhil, Dec 24, 2023.
  1. Dec 25, 2023 at 12:35 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    This was my 18” aluminum wheels with 1.25” spidertrax spacers.
    and here’s what it looks in comparison with and without 1.25” spacers.
    2mchfun and AggiePhil[OP] like this.
  2. Dec 25, 2023 at 1:12 PM
    AggiePhil
    AggiePhil [OP] Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Yeah, using 1.25” wheel spacers would change the offset value by 32mm. So 60mm offset OEM wheels would effectively become 28mm offset wheels.
    Not sure yet if I’d rather do this or use an aftermarket wheel. I’m going to have to buy new ones either way. Really leaning toward the steelie spares due to the rugged look and low price. But with the added cost of spacers, that second part is kind of negated.
    If I do decide to go with spacers, I’d probably get Boras since they’re black. Not sure I’d want the Spidertrax blue poking through, especially if I go with steelies and no center caps.
    2mchfun and pvn.beluga like this.
  3. Dec 25, 2023 at 3:47 PM
    2mchfun
    Steelies are awesome, super strong & durable, deter theft, etc. Pretty sure you can get the Bora in 1" vs. 1.25" on the Spidertrax. That said, I wouldn't ever use or recommend others use spacers. Obviously, much depends on how you use or will use the truck. Now you have me started thinking maybe I can get to steelies without spacers and enough tire width to get out to the edge of my flares with Total Chaos uniball UCA's or some other combo. Glad I don't have time to go down this rabbit hole right now! Ha!
    BTW steelies or some aftermarket rims could require different lug nuts, so beware and plan accordingly. In some cases, changing the lug bolts to a slightly longer version is the best way to achieve good thread engagement. Those longer versions are available and can be sourced from a place in Japan. Can't recall the exact info right now, but it's here on the site and I have some pictures of it, so if all else fails just PM me and I will be able to assist further. Good luck!
  4. Dec 25, 2023 at 5:02 PM
    2mchfun
  5. Dec 26, 2023 at 2:50 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    There's still some good sales on certain Method Wheels. And if you plan on going with a 12.50" wide tire at some point, you're going to want a wider rim than the 8" stocks. Some tire shops won't even mount them on the stock wheels.
  6. Dec 26, 2023 at 2:59 PM
    AggiePhil
    College Station, TX
    I actually want as narrow of a tire as possible. Both for function and for aesthetics. Remember, I don’t like the “poked look.”
    Regarding Method wheels (and all others, for that matter), I’m having a bit of trouble finding 18” wheels with an offset in the 35mm range. Most seem to be 17”. What am I missing?
  7. Dec 26, 2023 at 3:10 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Yeah, I'm not sure with that offset at 18". I just bought some with a +25 offset, to replace the Pro wheels I have in the near(ish)future.
    Kind of in the same dilemma as you. Not necessarily looking for a bunch of poke.
    AggiePhil[QUOTED][OP] likes this.
  8. Dec 26, 2023 at 3:15 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    I've had 295/70/18 on two Tundra's with stock wheels. It's very close to the UCA, but didn't rub on either. One truck had Bilstein/Dirt King UCA, my current truck the stock UCA. And they don't poke. Just about flush with the fenders.
  9. Dec 26, 2023 at 4:08 PM
    2mchfun
    FWIW, Kenda makes an odd narrow but tall 18" tire. Don't remember the exact dimensions of it at the moment though. Seems like it was around 35.5 x 10.25 or in that ballpark when I was comparing options. It was definitely an odd size.
    AggiePhil[OP] and BillyB like this.
  10. Dec 26, 2023 at 4:15 PM
    AggiePhil
    College Station, TX
    Yeah, I think the SPC UCAs are what’s screwing me up. If I still had the stock UCAs, I think there’d be more clearance.
    BillyB[QUOTED] likes this.
  11. Dec 26, 2023 at 4:46 PM
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    But your gonna put the zerks on and grease them ASAP, right? My UBJs came with Zerks that weren't installed in the package. I installed them and had a hard time putting the grease in. Turns out when the zerk is too tight it wont take grease. Oops. I ran around for 2 weeks without grease in them aside from the factory packing grease. They started squeaking after some mild off roading and I figured out they were dry the whole time.
    pvn.beluga likes this.
  12. Dec 27, 2023 at 9:36 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    I would highly recommend this even if you aren't planning to use your SPC for a long time. Those ball joints need the initial pumps of moly.
  13. Dec 27, 2023 at 10:05 AM
    AggiePhil
    College Station, TX
    Thank you. Still trying to decide what to do about clearance. Maybe there’s a master thread or spreadsheet here listing specs of all the different 5x150 wheels (or at least the major ones).
  14. Dec 27, 2023 at 10:07 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    I can tell you that Method has models with +25 in 18". That's about all I can tell you, though.
    And SCS, too
