SSO Slimline Bumper - Install and First Impressions
Discussion in 'Recovery & Gear' started by Cemented, Apr 6, 2018.
  1. Sep 9, 2022 at 8:44 AM
    #301
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Yes, I had to move mine from the top in order to get the bumper to fit. Mine was the Smittybilt X20 10K.
  2. Sep 9, 2022 at 9:09 AM
    #302
    BlueRidgeTon
    BlueRidgeTon New Member
    WNC
    2021 Cavalry Blue SR5 Crewmax
    Toytec/Eibach 2.5 lift kit. JBA UCA's. Toytec Shackles. Icon vector 5s BFG KO2's 285/75/17
    Ok good to know.
  3. Sep 9, 2022 at 10:58 AM
    #303
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Here is an image of how I relocated mine. You can see the rest of my install on the first page of my build.
    Beesta likes this.
  4. Sep 9, 2022 at 4:57 PM
    #304
    BlueRidgeTon
    WNC
    I was looking at your build and I like the way that you were able to mount the solenoid. I'm guessing that bracket came with the smittybilt? I got a warn evo 12s I'm not sure if it would have a similar bracket.
  5. Oct 13, 2022 at 2:12 PM
    #305
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    What are the relocation mounting options for the smittybilt X20 10k winch? I am looking at getting the Gen3 for my SSO bumper and was looking for suggestion on mounting the control box.
    I see what @InfernoPRO did. Did those brackets come with?
  6. Oct 13, 2022 at 5:12 PM
    #306
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I might get some time to put my write up together tonight, but I haven't finished my final mount location. It's custom, but pretty simple for my situation (or anyone that is running a power tray of some kind over their fuse box).
    Inferno's setup is a Warn - they have a different mounting "plate" than the Smitty does.
    Edit: I see now from the picture it looks like it’s maybe an older SmittyBilt. My mistake. But the Gen3 doesn’t have the same sort of mounting bracket.
  7. Oct 13, 2022 at 9:37 PM
    #307
    RainMan_PNW
    Casey
    Clark County, WA
    @colenation
    Just posted my write-up in my build thread.
    (Direct link to the post)
    I’ll add to that same post some pictures of the final stainless mount when I get it done either tomorrow or this weekend.
    colenation likes this.
  8. Oct 24, 2022 at 11:25 AM
    #308
    InfernoPRO
    Scott
    Sacramento
    The brackets did come with the X20, but like was mentioned the new Gen 3 might not come with these.
  9. Nov 23, 2022 at 9:41 AM
    #309
    colenation
    Cole
    Alabama
    Just got notification that the SSO bumper I order in August is on the way:yes:. Will post pics when she’s mounted.
    To bad it’s also $200 cheaper now :annoyed:with there current sale, but oh well
    RainMan_PNW and ErikTRDTUNDRA like this.
  10. Jan 7, 2023 at 6:27 PM
    #310
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
    I joined the club recently! Diode Dynamics 30” lightbar and warn EVO winch.
    8E758A83-89E5-49CA-8F3A-0760E06DF244.jpg 9E35BF34-716F-40E8-8C3A-DC25C0685779.jpg
  11. Jan 7, 2023 at 6:32 PM
    #311
    colenation
    Cole
    Alabama
    I forgot to post on this thread with my installed pics:
    went with the Heise light bar. Found it for $80 from some website.
  12. Feb 6, 2023 at 10:48 AM
    #312
    D60
    D60 New Member
    I helped install an SSO slimline in a '15 Tundra yesterday with a Smittybilt X2O 10k. This may have already been mentioned elsewhere in the thread (I didn't read every page) but the provided winch anchor bolts from Smittybilt are M10 with a 16mm / 5/8" head. The slots in the bumper are also 5/8" wide. This means nearly 100% of your load is on whatever washers you elect to use.
    In hindsight there was a bag of hardware from SSO (not Smittybilt) which we didn't use. They all looked like M12 but perhaps SSO included some M10 hardware with a larger head and we didn't realize it?
    Shown here the winch bolts can nearly pass thru the slots and would I'm sure with a few light taps from a rubber mallet20230206_114133.jpg
  13. Feb 6, 2023 at 11:26 AM
    #313
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t recall that issue at all with my X2O gen3 12k winch. The bolt pattern on all those winches is universal. I remember the holes just lining up - no slots at all.
  14. Feb 6, 2023 at 11:29 AM
    #314
    colenation
    Cole
    Alabama
    I agree with @RainMan_PNW. I don’t recall having any issues with those and specifically remember the predrilled mounting holes being round and not oblong/oval.
  15. Feb 6, 2023 at 12:29 PM
    #315
    D60
    D60 New Member
    Interesting...apparently a fairly recent revision. This was one of my few complaints with the product, I feel the slotting was too generous.
    My other complaint was that the front winch bolts require patience, dexterity, excellent vision and more patience to install. I'm sure that has been mentioned in the thread repeatedly. We nearly thru-drilled the lower sloped plate so we could just run a socket up from the exterior of the bumper.
  16. Feb 6, 2023 at 7:08 PM
    #316
    RainMan_PNW
    Casey
    Clark County, WA
    I also recall doing all of the winch mounting while I had the bumper on my work bench.
    Hitting the nuts trapped inside the winch feet was a treat, but I don’t remember any of that being nearly as much of a pain as getting the brackets mounted and aligned for holding the side bumper pieces on.
  17. May 20, 2023 at 5:43 AM
    #317
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Clean work, love how the cut is so precise. Good job.
  18. May 20, 2023 at 9:03 AM
    #318
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Hey thanks.
    Isn't big deal, just follow the lines.
    Beesta[QUOTED] likes this.
  19. May 20, 2023 at 3:20 PM
    #319
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Hello Tundra folks: few questions pls
    - access hole, any advantages ??
    - light-bar quality and price what do you all prefer.
    Thanks
  20. May 20, 2023 at 4:01 PM
    #320
    colenation
    Cole
    Alabama
    So I got the access holes for two reasons:
    - liked the looks
    - also can easily reach in and engage/disengage free spool (smittybilt x20 gen3)
    Light-bar for me was the Heise 30”.
    - works well (IMO) and does what I need it too. I also found a site that had them for $80, so why not.
    - for the Alabama woods, a $600+ BD didn’t seem worth it.
    just my 0.02:)
    WVI, RainMan_PNW and Piki like this.
  21. May 20, 2023 at 4:44 PM
    #321
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Thank you Cole
  22. May 20, 2023 at 6:51 PM
    #322
    RainMan_PNW
    Casey
    Clark County, WA
    Like Cole, I went with the access holes because I wasn’t installing the $2k Warn winch that has an electronic clutch, so I needed a way to reach in to engage/disengage the clutch to freespool the line out (same Smitty X20 gen 3).
    I went with the Baja S8 light bar. Bullet proof, and easy to change the lenses in the future. I got a really good deal on it too (still way more than Cole paid for the Heise though)
  23. May 21, 2023 at 3:38 AM
    #323
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    So without the access hole how easy can the winch be reached from the back of the bumper ? I was just trying to avoid more bug/debris to be collected in the access hole. Thanks
  24. May 21, 2023 at 4:03 AM
    #324
    Piki
    Piki New Member
    You haven’t any access from back. It’s very tight back there. If you planning use your winch you better off with the access holes. I’m planning to take my light bar off to see evan more what’s going on during winching.
  25. May 21, 2023 at 4:47 AM
    #325
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Thank you much.
    Last one, has any of you tried a diff light other than they suggest ? Like SS30 from dynamic diode ?
  26. May 21, 2023 at 5:05 AM
    #326
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Loudoun county VA? I’m there too. I replaced my SSO with a C4 bumper last summer. It’s still sitting in my garage if you want to swing by & take a look at it. 100 bucks & it’s yours. It could use a wire brush for light rust removal. It has the access holes & BD S8 light bar cutout.
    RainMan_PNW and Beesta[QUOTED] like this.
  27. May 21, 2023 at 5:39 AM
    #327
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Aw man, yeah I’ll check it out bro. Let me know. Thanks
    Uhhhh.... likes this.
  28. May 21, 2023 at 5:42 AM
    #328
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Sweet, send me your info and I can swing by and check it out. Thank you so much
    Uhhhh....[QUOTED] likes this.
  29. May 21, 2023 at 9:34 AM
    #329
    Uhhhh....
    Dave
    7” BDS, 37s
    PM’d you :thumbsup:
  30. Oct 27, 2023 at 2:34 PM
    #330
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    Looks like SSO ran into some financial trouble, got absorbed by another company, and no longer does Tundra bumpers?
    Dang it.
