Stock Air Box Mod (SABM) Review Thread
Discussion in 'Product Reviews' started by csuviper, Aug 16, 2015.
  1. May 7, 2022 at 7:08 PM
    #61
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I ran across this thread after searching for CAI information and whether it's worth the money. I added a K&N drop in filter a few months back to replace the stock filter. I was averaging 10.4 MPG with my truck when I had the stock filter, and now with the K&N average around 9.8 or so and that is with the computer in the truck giving me that average. I don't baby the truck but I also don't drive it like I stole it either. I kinda feel that by taking in more air with a cold air intake then that should help add some fuel miles per gallon. Just wondering if the cost was actually worth that?
  2. May 7, 2022 at 7:56 PM
    #62
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Your profile says lift and tires
    What size lift and what size tires and have you used a speedo calibrator like a hypertech to adjust your odo/speedo for the size difference of your tires? If not, that will affect your calculated mileage (because your truck thinks it is driving less miles than it really is) more than anything. Add to that poor aerodynamics from a lift and you’re heading for low mpg.
    you won’t see any substantial gains from a cold air intake or the SABM mod - the Tundra already has a pretty functional cold air intake system in the way the factory air intake is designed
  3. May 7, 2022 at 8:34 PM
    #63
    freerider8
    Fairview PA
    I have not calibrated my speedometer with anything, I believe the lift is 3 inch and the tires are 35's. I bought this truck this way. I wasn't expecting great fuel mileage when I made the jump to this truck. I was just looking at different mods that I could do and have been wondering if the CAI was even worth the cost at all. Of course all the information that you read try and make you think that the factory installed intake is robbing the vehicle of air, but I am sure that they have to do certain things because of emissions and trying to squeeze all they can out of fuel mileage when building the vehicles.
    Thanks for the response.
  4. May 7, 2022 at 9:03 PM
    #64
    RainMan_PNW
    Casey
    Clark County, WA
    35’s compared to factory tires are in the ballpark of 7% less revolutions per mile (so your speedo is reporting ~7% less than actual speed and ODO is reporting ~7% less miles traveled than actual).
    Add to that the additional weight that 35’s will have and you’re gonna see low numbers. The factory air system intake is pretty damn good in these trucks. If you’re seeing a drop using the K&N, you could look at going back to OEM - that’s an inexpensive experiment to try. You might also be getting some fouling if you over-oiled the KN at all, though the factory carbon secondary filter ought to catch that (it’s plastic welded into the air box lid)
    BlueRibbon4x4 likes this.
  5. Aug 24, 2022 at 2:11 PM
    #65
    KSTNTUNDA
    KSTNTUNDA New Member
    Nashville
    2020 LIMITED TRD OFF ROAD
    I installed an aFe filter and airflow accelerator.
    Any suggestions to replace the tube between the air box and the engine without buying the entire kit (TRD, S&B, aFe Super Stock, Etc.)?
    Rica25 likes this.
  6. Aug 24, 2022 at 2:56 PM
    #66
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Will this work on a Stillen CAI? :monocle:
    Rica25 likes this.
  7. Aug 24, 2022 at 3:51 PM
    #67
    Saltyhero13
    Saltyhero13 Throbbing Member
    The Stillen with the forward facing intake duct is like having a SABM. You can still do a SABM but unless you have a supercharger its not likely you have an airflow restriction.
  8. Aug 24, 2022 at 3:54 PM
    #68
    Funnyguy713
    Houston TX
    I need to get a Harrop Supercharger
    fuzzamungus likes this.
  9. Aug 24, 2022 at 3:55 PM
    #69
    Saltyhero13
    reywcms likes this.
  10. Aug 24, 2022 at 3:59 PM
    #70
    Funnyguy713
    Houston TX
    Saltyhero13[QUOTED] likes this.
  11. Mar 7, 2023 at 1:44 PM
    #71
    RobertD
    Robert
    DFW, Texas
    Well.... my slow ass finally got around to doing this mod after having the parts for way to long :rofl:
    I did the DIY version and it took me about 3 hours from start to finish. Did this a few days ago and haven't put a ton of miles on the truck yet, but my initial impressions are good. The truck feels smoother in its acceleration and it does feel like I have more power off the bat. Between this and my throttle controller, its a blast to drive. I have the stock air box and stock exhaust, but I do have an AFE dry filter installed.
  12. Apr 25, 2023 at 11:17 AM
    #72
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
  13. Apr 25, 2023 at 12:32 PM
    #73
    RobertD
    Robert
    DFW, Texas
    Um... I ordered the 31-10247 not sure what the difference is since the other one is also a dry filter and says it fits the 5.7L Tundra too. If you scroll thru the pics, they show what your stock filter should look like and the one for the 31-10247 matched what I had.
    AverageJoe[QUOTED] likes this.
  14. Nov 2, 2023 at 6:48 PM
    #74
    Any inputs since you have been running the sabm for a while now?
  15. Nov 2, 2023 at 7:04 PM
    #75
    RobertD
    Robert
    DFW, Texas
    So the SABM with the AFE drop in was nice. Added some growl and the truck felt a little more responsive and it felt like the engine was breathing better. All around it felt like it ran smoother with the SABM. I also did the DIY intake tube (basically the TRD tube but you source the boots) and that also gave some noticeable sound improvement when you step on it. Engine doesn't sound too different when cruising but you can definitely hear it now. I've increased tire size so its hard to say if there are any mpg gains, but I haven't taken a hit and I enjoy driving it a bit more. Definitely think the 2 are worth doing.
    BlueRibbon4x4 and texasrho83 like this.
  16. Nov 3, 2023 at 5:23 AM
    #76
    Nice. I have the old kit that I took out of my 2013 but I don't think it will work on mine due to the air box being different. I know they revised the kit a while back to make it longer, but I don't know if anything else changed.
  17. Nov 3, 2023 at 5:26 AM
    #77
    RobertD
    Robert
    DFW, Texas
    I did the DIY version, once the fitting was mounted to the airbox and fender well. I just had to trim the tube to length, easy to accommodate different spacing.
  18. Nov 3, 2023 at 5:31 AM
    #78
    I'll mess with it this weekend and see if it fits. It won't hurt since I already have it lol.
    RobertD[QUOTED] likes this.
  19. Dec 9, 2023 at 4:34 PM
    #79
    JesterUno
    JesterUno New Member
    Daytona Florida
    Stock 2016 2wd Off Road TRD
    None. Yet.
    It's not a cold air intake system so why not just drill the hole in the box and leave out all the extra b.s. Is it really that much cooler pulling from the air from the fender when it 100 degrees outside in Florida? Nope.
    2cents.
  20. Dec 9, 2023 at 4:56 PM
    #80
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    100 air outside vs 150-200 engine bay makes a difference
    Tundra234 likes this.
  21. Dec 9, 2023 at 7:08 PM
    #81
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Turn your extra hole on and off. Since it’s no longer used, programing the ACIS valve on the supercharged trucks to operate this would be neat.
    reywcms likes this.
  22. Dec 9, 2023 at 7:22 PM
    #82
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    We’re actually building custom box with a valve open/close on the old man’s rig. Should be interesting
  23. May 18, 2024 at 7:56 AM
    #83
    2001sr5 _yota
    2001sr5 _yota New Member
    Dev
    01 tundra 2r5
    3in cat back. Rest stock
    So I’m confused with how this works … it sucks air through the wheel base or something?
  24. May 18, 2024 at 8:18 AM
    #84
    RobertD
    Robert
    DFW, Texas
    That's where the stock opening is. This just allows more air to enter the airbox.
  25. Mar 7, 2025 at 1:43 PM
    #85
    RobertD
    Robert
    DFW, Texas
  26. Apr 16, 2025 at 11:29 AM
    #86
    Cthulhu
    So after a few months of having the SABM, I've decided to remove it. Although it sounds fantastic, since i upgraded to 5.29's which pretty much restored my power, I am returning a lot of the mods I did to increase power to OEM; if there's a chance any of the "power" mods are detrimental to longevity of the truck, I'd rather err on the side of caution, because I want to be buried in this truck. Besides, not sure how much power is really gained on a NA 5.7; only really saw evidence of it benefitting FI engines.
    So, if anyone wants my used SABM kit that I made, I'll be happy to send it to you for $50 delivered to CONUS, PayPal only please. Will include (2) clamps for the short intake tube, the short intake tube (already cut for the distance between the air box bottom and the inner fender well), the air box bottom with the hole drilled out and the intake tube plate already mounted to it (what's cool about me offering this included is that you can keep your OEM air box bottom if you don't like the SABM, and all you have to do is reinstall your original box, and plug the hole in the inner fender well), and I'm even throwing in the hole saw, which I only used once to drill the holes. Only thing you would need to do is clean up the old caulk, reapply new caulk when installing (to eliminate any whistling that has occurred on some installations of the SABM, right @RainMan_PNW :D?), drill the hole in the inner fender well, and provide four fine thread stainless steel sheet metal screws for the intake tube plate that mounts to the inner fender well.
    Here is a link to the listing; please communicate with me on that thread. Thanks in advance for any interest! :thumbsup:
    https://www.tundras.com/threads/fs-...delivered-to-conus-paypal-only-please.157496/
    HulkSmurf14 likes this.
