Stock front bumper mod
Discussion in '1st Gen Tundras (2000-2006)' started by DA Tunbrah, Apr 19, 2019.
What do all of you first gen guys think of this stock bumper mod?
  1. What a waste of an afternoon
    5 vote(s)
    10.2%
  2. Time well spent
    44 vote(s)
    89.8%
  1. Aug 6, 2019 at 12:11 PM
    DA Tunbrah
    DA Tunbrah [OP] New Member
    Jeff
    2002 access cab limited
    About the bottom side of the bumper..
    Since that older picture (when the truck was still green) I ended up removing the crossmember (which holds the front of the skid plate) and cutting the frame rails at a 60 degree angle. I grabbed a 6”x 5/8” piece of strap and welded it right to the frame rails. I’d like to weld some d rings or cool tow hooks onto it to complete the look. I’ve got some fab work to do on the stock skid plate as far as shortening it and mounting it to the new piece of strap. I’ll definitely take pics and keep you guys updated. I’m by no means a professional and all of this work (including the paint and body) is being done without a garage, in the middle of the jungle, with a generator, under a tent haha.
    mtntop and TX-TRD1stGEN like this.
  2. Aug 6, 2019 at 1:16 PM
    DA Tunbrah
    Jeff
    Here’s a pic of the work in progress on the lower bumper and skid plate work
  3. Aug 6, 2019 at 1:31 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Nice!
    Did you shoot the paint yourself, or have it done?
  4. Aug 7, 2019 at 9:57 AM
    DA Tunbrah
    Jeff
    Shot myself under an ez corner tent in the jungle. Had to do a bunch of metal work as far as filling all the alignment holes and fender clip holes 1524CA1E-1CB0-4CBF-8A14-ACE674C347E1.jpg3C67909C-DDD2-47F3-8E79-1FC948DA694E.jpg
    G_unit3000, MDHinSD, bmf4069 and 4 others like this.
  5. Aug 7, 2019 at 10:00 AM
    DA Tunbrah
    Jeff
    Alignment holes from the body moldings. I chopped the front fenders and rear fenders out a bit and as of right now there’s an extra leaf in the back and a 2” coil over spacer in the front.
  6. Aug 11, 2019 at 10:18 AM
    mscribellito
    mscribellito New Member
    Michael
    2006 White Regular Cab Tundra
    That looks awesome!
  7. Aug 11, 2019 at 10:34 AM
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    Great mod, love it
  8. Aug 11, 2019 at 11:26 AM
    ou77kg
    ou77kg New Member
    Erik
    That 4e9 paint job hits all my retro soft spots
    G_unit3000 likes this.
  9. Aug 18, 2019 at 7:10 PM
    Makahawk
    Makahawk New Member
    Justin
    2005 Tundra DC TRD
    Wow, I’m really impressed! Where are you located? If you’re close enough I’m coming over and we’re doing this to my 05!
  10. Nov 4, 2019 at 7:16 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    I really like this idea with your stock bumper! Ive been thinking of ways to get mine up higher and all ive done so far is remove that lower plastic piece. I was thinking of ways to cut it but nothing seemed like it would look or work well. Then i stumble upon this idea of removing the top portion! I love it! Can you just give some more info on what was actually done to make this work. Like what and where did you cut, and what bolts were used and if new holes needed to be drilled? Thanks so much for any info you have, i want to start this project tomorrow!!!
  11. Nov 4, 2019 at 8:05 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'll add my contribution to the cut bumper thread. I cut my 06 plastic fantastic. The issue is that there's no structure there after removing the metal behind the bumper. At least it looks good. I cut my fenders and flares at the same time.
  12. Nov 4, 2019 at 10:27 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    That came out awesome! :thumbsup:
  13. Nov 5, 2019 at 6:27 PM
    oscardog86
    Southern California
    Did you weld that bumper in place?
  14. Nov 5, 2019 at 7:14 PM
    ESTundra937
    Eddie
    San Diego
    I can't stop admiring how badass this came out Karma Kannon. That's one sick DC you have there. Any tips on cutting the fenders? Before and after pics maybe? I gotta do this to mine. So fu*#n sick! :bowdown:
  15. Nov 5, 2019 at 7:28 PM
    KarmaKannon
    Utah
    Some junk
    Thanks
    I just used a marker and a cutting wheel on a 5" grinder. Nothing too crazy. I just scored the first pass and used that as a rut to cut the whole way through. I had fiberglass fenders before but I took them off to paint and bodywork them so I don't have before pictures besides when it was stock width with stock suspension. It looks cool but needs fiberglass back on there sometime soon.
    G_unit3000, Filthyphil and oscardog86 like this.
  16. Nov 5, 2019 at 7:35 PM
    ESTundra937
    Eddie
    San Diego
    Thanks for the info and pics. I'll have to give it a shot one of these weekends.
    KarmaKannon likes this.
  17. Mar 30, 2020 at 1:20 PM
    Curbside_mechanic484
    Curbside_mechanic484 New Member
    2002 Bessie SR5 4.7
    Big ass tires
    How did you fab the bumper to bolt on? I removed my bottom valance but kept the top for now. I’m not much of a fabricator. I’m gonna grind the sides to stop some rubbing but I really like the look of yours
  18. Nov 2, 2021 at 5:16 AM
    lowell66dart
    lowell66dart New Member
    lowell
    South Louisiana
    2001 Tundra 4WD
    Rough Country level, RAS rear springs, Magnaflow, custom front bumper
    I just jumped on this bandwagon yesterday. So far very easy. Gotta fab some mounting brackets today.
    Darkness likes this.
  19. Nov 2, 2021 at 5:32 AM
    #49
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Pics? We like pics.
  20. Nov 2, 2021 at 5:49 AM
    #50
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    I have a few. These bumpers are really thin. Your only protection is the large curved piece shown in the pic below. tool me about three hours to get this far but I'm old.
    G_unit3000 and Darkness like this.
  21. Nov 4, 2021 at 7:16 AM
    #51
    lowell66dart
    lowell
    South Louisiana
    2001 Tundra 4WD
    Made some progress. My goal was to not spend a bunch of money on this in case I went a different route later on. That being said I reused anything I could. I only bought paint. I will fab up something to replace the curved piece I removed. Probably a 3/16 piece of steel with a slight bend that will bolt up to the factory inserts on the frame. I made a template and then trimmed the factory bumper brackets.
    The pic of the bracket shows how I used the existing holes for mounting. A little time to fab up but not to difficult.
    G_unit3000 and KarmaKannon like this.
  22. Jan 21, 2023 at 1:57 PM
    #52
    Rigger
    Rigger New Member
    2014 Tundra Crewmax
    My son and I are studying and working on this modification. Ours is a 2000 Tundra. The chrome bumper, which is actually more of a bumper skin, is attached to truck via two stamped vertically-oriented gussets (one each frame end) that are factory spot-welded on. I assume you guys are cutting these things off. How then are you re-attaching the bumper skin?
  23. Jan 22, 2023 at 5:49 PM
    #53
    Mhagha
    Mhagha New Member
    Hey,
    Nice work guys.
    @DA Tunbrah and @Lowell666dart… did you just remove the chrome part of the front bumper? And what I am looking at is underneath the chrome bumper. It has a black bumper ? Or is this a new bumper you purchased and put on?
    I attached a picture of my front bumper. I would like black Bumpers but not for the price I’m finding them.
    Thanks
  24. Jan 24, 2023 at 8:37 AM
    #54
    Mhagha
    Mhagha New Member
    If you guys purchased this black front bumper…where did you buy it from?
    I was going to wrap my front bumper but it’s banged up.
  25. Jan 24, 2023 at 1:46 PM
    #55
  26. Jan 24, 2023 at 2:31 PM
    #56
    Mhagha
    Mhagha New Member
  27. Jan 25, 2023 at 7:54 AM
    #57
    Mhagha
    Mhagha New Member
    I just ordered from carparts. In case anyone wants to know…..I asked if they can discount and they did. Total Shipped was $282
    Thanks!
  28. Jan 25, 2023 at 7:55 AM
    #58
    Not bad. I paid close to $400 for the bumper, new brackets, new crash bar and new fog lights.
    Mhagha[QUOTED] likes this.
  29. Jan 25, 2023 at 8:32 AM
    #59
    Mhagha
    Mhagha New Member
    I just took a better look at your truck/s. I really like the crash bar and led looks nice!!
    Do you have link for that crash bar?
    Almost bought a new Tundra!! I like them but Ended getting a new Jeep wrangler Freedom edition
  30. Jan 25, 2023 at 8:43 AM
    #60
    Th crash bar I was referring to is the one behind the bumper that actually does the bumpers job. The bull bar on the front of the 2000 was ironically involved in a crash (deer strike) and destroyed. It was a Westin bull bar that I installed 16 years ago or so, not sure what the availability is today. LED light bar is an Amazon $39 special. Survived the crash and is still operable, but not installed.
