Stock jack
Discussion in 'Wheels & Tires' started by Muddog, Aug 20, 2019.
  1. Aug 20, 2019 at 8:22 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks Dave
    Sunnier likes this.
  2. Aug 21, 2019 at 3:33 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Appreciate the help. Pulled the trigger on a 60" Hi lift Xtreme jack instead. :thumbsup:
    831Tun and Sunnier like this.
  3. Sep 28, 2020 at 8:48 AM
    ToyotaParts
    ToyotaParts New Member
    2010 blue double cab tundra
    Stock
    Anybody on here have they’re stock lift with accessories that they would like to sell Im just stock height and that’s all I need but I find it so hard to find a stock jack around me and online they’re extremely expensive.
  4. Sep 28, 2020 at 8:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Where you located?
    ToyotaParts[QUOTED] likes this.
  5. Sep 28, 2020 at 9:00 AM
    By the time you pay for shipping, you would be better off getting it locally from your dealer. Find it online and most dealers will match it.
  6. Sep 28, 2020 at 9:09 AM
    ToyotaParts
    Stock
    I’m located in Houston, Tx and you might be right thank you for the help.
  7. Feb 11, 2021 at 7:20 PM
    New_DoorDing
    New_DoorDing New Member
    2016 TRD Pro DoubleCab
    By slightly bending the base bracket by a few centimeters, the Husky 6-ton bottle jack fits perfectly snug. Zero play and rubber tie down goes on nice and snug. HOWEVER, the jack leaks very the hydraulic fluid very easily. It made a mess in my truck and I returned it. At 35 dollars, you get what you pay for. Instead I just bit the bullet and bought the Safe Jack Starter kit for 179 USD. I tested it out and what a huge difference from the stock jack. Extremely stable even on slightly uneven pavement. All you’ll need for the TRD Pro lift is the u-shape attachment. No extension necessary
    thearborbarber, Gabrielo93 and 831Tun like this.
  8. Feb 13, 2021 at 1:28 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Is the stock jack ok for a stock height truck?
  9. Feb 13, 2021 at 1:58 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Yep get you some 2" thick wood. I got 3 pieces in a storage box with moving blanket and jack stands. Also have a 35" spare under the truck.
  10. Feb 17, 2021 at 8:14 PM
    New_DoorDing
    It’s ok for stock height. It’s just very sketchy. You need an extremely flat surface in my opinion. Give it a try and see what you think about it before deciding on whether or not you want to buy something more stable
  11. Feb 17, 2021 at 9:30 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I’ve used it before with no issues on a flat, grassy area. It actually worked better than a bottle jack that ended up leaking.
  12. Feb 17, 2021 at 9:31 PM
    equin
    Ed
    DFW, TX
    Forgot to add I also placed it on top of a couple wooden boards to add stability in the grass.
  13. Feb 18, 2021 at 9:43 PM
    New_DoorDing
    I didn’t want to call BS on your first comment, but now that you clarified, that makes a lot more sense that you used the wooden boards to secure the stock jack better. To each his own.
    This 6-ton bottle jack only required less than 15 pumps to lift rear the tire from the axle. Pretty quick compared to how many times you have to turn the stock jack. Also, correct me if I’m wrong but the stock jack isn’t rated for 6-tons, yet both have same height.
  14. Feb 19, 2021 at 11:57 AM
    equin
    Ed
    DFW, TX
    Yeah, it probably wouldn’t be that stable without any boards underneath. I’ve never tried it without at least one board, though. I cut several boards myself to fit both the OEM jack and the bottle jack that failed. The bottom board is cut wider than the rest for both. I don’t stack more than 3 boards. I will say that the bottom board sunk into the dirt and grass when I jacked it up, but I expected that since it wasn’t hard pavement.
    I also got an Army surplus scissor jack for a Humvee that’s rated for 3 tons. It has a wide base, and I had to get an adaptor for it. It works well on pavement, but I haven’t had a chance to test it out on dirt yet.
    And about a month ago I got Harbor Freights aluminum 3-ton floor jack. There’s an outfit that makes and sells a skid for use in the dirt. I haven’t gotten the skid yet, but plan to. I’ll just need a stable bed mount for it when I do.
    Can’t ever have enough jacks!
    New_DoorDing likes this.
