STravis Go Anywhere, Camp Anywhere Build
Discussion in '2.5 Gen Builds (2014-2021)' started by STravis, Jun 28, 2020.
  1. Nov 2, 2022 at 8:15 PM
    #271
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
  2. Nov 2, 2022 at 8:22 PM
    #272
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    helidave[QUOTED] likes this.
  3. Nov 2, 2022 at 8:47 PM
    #273
    Wallygator
    What is your concern with low temps on the lithium? I was concerned about the battery being charged in extremely low temps. Don't know which battery you have but I called battle born and they said with their BMS I won't have to worry about low temps. The BMS prevents damage to the battery in any condition
    2mchfun and STravis[QUOTED][OP] like this.
  4. Nov 2, 2022 at 8:56 PM
    #274
    helidave
    flagstaff
    2015 DC 4x4
    The bms simply cuts off charging if the cells are below freezing, which does protect the battery. The problem is then it wont take a charge until it warms up. Some batteries come with internal heaters now so they can keep themselves warm enough to charge even if the outside temp is below freezing.
    STravis[OP] and Wallygator like this.
  5. Nov 2, 2022 at 9:01 PM
    #275
    Wallygator
    Pretty sure the battle Borns now do come with a heater. Mine unfortunately doesn't. The only solution I can think of would be as mentioned, some type of warming blanket or a heater. Hmmm, time for a diesel heater maybe.
    STravis[OP] likes this.
  6. Nov 2, 2022 at 9:03 PM
    #276
    STravis
    Travis
    Ruidoso, NM
    I've got a renogy 200ah lithium and it has a BMS that cuts charging and discharging at low temps but we have long spells of cold during the winter that would prevent the use of the battery. And if the BMS fails for any reason I don't want to ruin the battery.
    2mchfun and Wallygator[QUOTED] like this.
  7. Nov 2, 2022 at 9:04 PM
    #277
    STravis
    Travis
    Ruidoso, NM
    I've got a diesel heater and I thought about running the heater in frost mode to maintain the temp in the camper but surely there is a more efficient way.
    Wallygator[QUOTED] likes this.
  8. Nov 2, 2022 at 9:07 PM
    #278
    Wallygator
    A plug in battery blanket. Of course this would only work if you have ac available, but when not using the truck while parked at home, this would be very good at keeping the battery to temp. Maybe I should get one also?
  9. Nov 2, 2022 at 9:09 PM
    #279
    STravis
    Travis
    Ruidoso, NM
    I've seen some 12v options for heating pads also. I do have an inverter but that wouldn't be super efficient either.
    I think I will end up building an insulated box and run a 12v RV tank heater like the one mentioned in the video above.
  10. Nov 2, 2022 at 9:12 PM
    #280
    Wallygator
    Maybe could have an insulated box and place an LED light bulb in it? Should produce plenty of heat to keep the battery temp in range
    Mater and STravis[OP] like this.
  11. Nov 9, 2022 at 6:56 AM
    #281
    STravis
    Travis
    Ruidoso, NM
    Got some new lights for the truck. These Baja Designs XL lights are huge. I'll post some pictures where they end up later today.
  12. Nov 9, 2022 at 4:34 PM
    #282
    STravis
    Travis
    Ruidoso, NM
    I got the Baja designs xl sports all mounted and wired up today. One of the lights was wired backwards and popped my fuse so that slowed me down a bit.
    I also cut and bent a front cat shield/skid plate. Should be building a rear soon.
  13. Nov 10, 2022 at 8:34 AM
    #283
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Hey @STravis, Sorry to hear about the wiring issue, I'll send you a pm regarding this.
    Best,
    Brandon
    STravis[QUOTED][OP] likes this.
  14. Nov 10, 2022 at 8:45 AM
    #284
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Hey, kinda in the same situation as you. Don’t want to have to pull the batteries every time I go skiing. Planning on installing a couple of these
    GAOHOU Hive Electric Heater Plate Beehive,Silicone Heating Heater Mat/Pad,12V 12W Heating Baking Mats Save Honey Beekeeper Bee Keeping Equipment https://www.amazon.com/dp/B0794V5J5H
    Along with this
    Inkbird Dual Stage DV 12V Digital Temperature Controller Fahrenheit Thermostat Heating and Cooling for Homebrewing Brew Fermenter Fridge Incubator Greenhouse https://www.amazon.com/dp/B019I3YCFS
    relatively inexpensive and should do the trick. If my battery goes I’ll just swap it out a new one with heating built in
  15. Nov 10, 2022 at 10:17 AM
    #285
    Wallygator
    UPDATE: I bought a $10 led off Amazon (maybe I chose the wrong one??) and it never produced enough heat.
    Plus in one hour the voltage dropped from 14.3 to 13.5 volts. A massive loss in one hour.
    So it appears the light bulb is not the way to go.
    Mater likes this.
  16. Nov 10, 2022 at 12:14 PM
    #286
    STravis
    Travis
    Ruidoso, NM
    Bummer, but at least it was a quick mostly cheap experiment.
  17. Nov 10, 2022 at 5:39 PM
    #287
    STravis
    Travis
    Ruidoso, NM
    Got my rear cat skid designed and built today. I made bolt brackets that sit on top of the crossmember so you don't need a wrench on top in a hard to reach spot. I did the same with the front skid as well. I'm happy with the way everything came out.
    PXL_20221110_202653580.PORTRAIT.jpg PXL_20221110_202724213.PORTRAIT.jpg PXL_20221109_205947563.PORTRAIT.jpg PXL_20221110_222042219.PORTRAIT.jpg PXL_20221110_222034745.PORTRAIT.jpg
  18. Nov 10, 2022 at 5:52 PM
    #288
    STravis
    Travis
    Ruidoso, NM
  19. Nov 11, 2022 at 7:26 PM
    #289
    STravis
    Travis
    Ruidoso, NM
    I have been wanting a way to organize my center console lately and found these console safes on eBay for ~$80. I decided to give it a shot and ordered it. I have heard reports of some of them showing up with bent corners, but I wasn't worried about that. It showed up today and is in perfect shape. Not bad for the price. I'll install it tomorrow and see what happens.
  20. Nov 12, 2022 at 8:38 AM
    #290
    Wallygator
    Yeah I think my choice of a USB led light was the problem. Was looking for an off grid solution. Gonna use a normal led bulb in an old shop light, plug it in to ac, and see what happens.
    Starting to get anxiety over cold temps on the battery at this point. :boom:OCD kicking in for some reason.
  21. Nov 12, 2022 at 9:15 AM
    #291
    helidave
    flagstaff
    2015 DC 4x4
  22. Nov 14, 2022 at 2:14 PM
    #292
    STravis
    Travis
    Ruidoso, NM
    We decided to cut a few more things before we pulled the aluminum off of the table today.
  23. Nov 14, 2022 at 2:44 PM
    #293
    2mchfun
    Just curious about your new front bumper, any particular reason you didn't include more grill protection. I already understand airflow for cooling at low speeds, and maybe weight. Any other reason?
  24. Nov 14, 2022 at 2:56 PM
    #294
    STravis
    Travis
    Ruidoso, NM
    I kept the top of that main portion low to not cover up the body lines of the truck. And as far as the grill guard is concerned I left the majority open to be able to use the TSS if the trucks are equipped with it.
    2mchfun[QUOTED] likes this.
  25. Nov 14, 2022 at 4:23 PM
    #295
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    I am currently fabing up a fairing for my habitat. Is that what you are building in your latest post?
  26. Nov 14, 2022 at 4:31 PM
    #296
    STravis
    Travis
    Ruidoso, NM
    I'm building a short roof rack. It will have 3 crossbars and a wind fairing. Just looking for something to cover up the huge gap in front of the camper.
  27. Nov 15, 2022 at 10:05 AM
    #297
    TOYOTARIG
    TOYOTARIG New Member
    Ron
    Albuquerque, NM
    Dang it Travis! I just purchased a Prinsu rack to fill the huge gap between my cab and the Habitat. I would have much rather given the money to you. Day late dollar short. I am excited to see what your design looks like.
  28. Nov 15, 2022 at 11:37 AM
    #298
    STravis
    Travis
    Ruidoso, NM
    Haha sorry man. I've been going over how I want to do it in my head for a while so hopefully it turns out nice. Are you going to cut the rack in front of the the camper or leave it under?
    TOYOTARIG[QUOTED] likes this.
  29. Nov 15, 2022 at 4:04 PM
    #299
    TOYOTARIG
    Ron
    Albuquerque, NM
    Hopefully, there will be clearance under the camper. I would rather not have to cut a brand new rack, but if I must I will. How much flex between the cab and the bed do you think there is? I have tried to twist the truck to check clearances and my results are that the truck frame does not flex much.
  30. Nov 15, 2022 at 4:40 PM
    #300
    STravis
    Travis
    Ruidoso, NM
    These frames move a ton. Let somebody drive your truck on a rough road and watch it. I can put my hand out the window on my truck and feel the camper move all over the place.
    TOYOTARIG likes this.
