Sugar in the Gas Tank (Or filler Neck)
Discussion in '2nd Gen Tundras (2007-2013)' started by XSPDriver, Aug 13, 2019.
  1. Aug 14, 2019 at 7:52 PM
    #121
    Pinch those in. May be a small flat head to squeeze it in (that’s what she said)
    TruckyTruck, Ely010606 and Black Wolf like this.
  2. Aug 14, 2019 at 7:53 PM
    #122
    This^^^ ...Thanks Rexx!
    T-Rex266[QUOTED] likes this.
  3. Aug 14, 2019 at 7:54 PM
    #123
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  4. Aug 14, 2019 at 7:55 PM
    #124
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    You got good advice OP. Take the truck to a knowledgeable mechanic and have the fuel tank and components disassembled, drained and properly cleaned. If you don’t want to risk any damage, don’t run it. Once you run it you risk running contaminants throughout the entire injection system. Like marriage, or any relationship for that matter, it’ll get really expensive if you don’t do it right the first time.
    Tundyfundy, Fiestee23 and RitcheyRch like this.
  5. Aug 14, 2019 at 8:05 PM
    #125
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Careful with the “that’s what she said” jokes the GF is gonna end up blowing up his truck next time if she ever reads this forum lol
  6. Aug 14, 2019 at 8:28 PM
    #126
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    A love hate relationship. :devil:
    Tundyfundy and Black Wolf like this.
  7. Aug 14, 2019 at 8:31 PM
    #127
    I'm thinking AA might be a good start...
    Tundyfundy and ZappBrannigan like this.
  8. Aug 15, 2019 at 5:06 AM
    #128
    Dr_Al
    Dr_Al New Member
    Al
    If it was me I would of got a pneumatic vacuum and sucked out what I could see and called it good. The "sugar in a gas tank" hurting the engine or fuel tank/ lines is just a myth. Any in the gas tank would just sit there until the day the crusher flattens it. If you want to dissolve the sugar just take your garden hose and flush your tank out, lol.
  9. Aug 15, 2019 at 6:34 AM
    #129
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    By “pneumatic vacuum” do you mean handing her a straw?
  10. Aug 15, 2019 at 7:00 AM
    #130
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    She must be smoking hot!:worthless:
    Tundyfundy and RitcheyRch like this.
  11. Aug 15, 2019 at 7:06 AM
    #131
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Theres some jokes in that one for sure, but ill refrain from walking the ban hammer line. :laugh:
    ZappBrannigan[QUOTED] likes this.
  12. Aug 15, 2019 at 7:09 AM
    #132
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Now that joke just really.....
    ....sucks.
    :anonymous:
  13. Aug 15, 2019 at 7:14 AM
    #133
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Was gonna say this. Get her to fix what you can't and start planning your escape. She's toxic and you're blinded by it.
  14. Aug 15, 2019 at 8:03 AM
    #134
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Cannot give advice about relationships I’m not good at it but I am good with sugar seen this a couple times at work good thing well could had been worst she used raw sugar so those are crystals better than granulated sugar so it’s probably stuck in the tube and she didn’t use a lot I seen a 2 pound bag in a tank lol you didn’t start the truck great but it would not had been sucked thru the fuel pump strainer anyways sugar does not dissolve in fuel you need to run hot water thru the tank so I would drop the tank drain the fuel and fill it with hot water then put a hose on the exhaust of another car and run the carbon monoxide in your tank to dry it out then install everything back together get it back on the road locking Fuel cap helps prevent sugar but not broken windows good luck ✌️
    Boerseun likes this.
  15. Aug 15, 2019 at 12:32 PM
    #135
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Just make sure your garage door is open when you do this ^^^
    773_eddie[QUOTED] likes this.
  16. Aug 15, 2019 at 12:34 PM
    #136
    HappyGilmore
    Trent
    Lakewood CA
    She would probably try to close it on him.
  17. Aug 15, 2019 at 1:14 PM
    #137
    P-Factor
    P-Factor New Member
    All things considered, it could have been worse...
  18. Aug 15, 2019 at 1:18 PM
    #138
    TXMiamiFan
    Jose
    Would
  19. Aug 15, 2019 at 1:42 PM
    #139
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    vacuum and drive it..LOL
  20. Aug 20, 2019 at 9:56 AM
    #140
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    And a get a crazy female cousin that doesn't mind fighting for you to whoop that a.....
    kgb4187[QUOTED] and Tundyfundy like this.
  21. Aug 20, 2019 at 9:57 AM
    #141
    DalTee
    DalTee New Member
    Dal
    crazy chicks whip it on you, and don't mind taking the "pain". he's not in love he's in lust.
  22. Aug 20, 2019 at 10:53 AM
    #142
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Any updates on this?
  23. Aug 20, 2019 at 5:30 PM
    #143
    Tacogrande
    Jeremy
    Only if he didn't drink too much Gatorade with antifreeze
    ZappBrannigan likes this.
  24. Aug 20, 2019 at 5:38 PM
    #144
    AZTundra
    Paul
    Phoenix, AZ
    Is she single now? :anonymous:
    ZappBrannigan, Tundyfundy and hagrid like this.
  25. Aug 20, 2019 at 6:17 PM
    #145
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    All I can say if she does it once, she will probably do it again or worse. (Just like a cheater always a cheater) next time she might burn it down with you in it.
    Just a thought...
  26. Aug 20, 2019 at 6:19 PM
    #146
    AZTundra
    Paul
    Phoenix, AZ
    Might be too late. OP hasn't been seen on here since 8/14. :bananadead:
  27. Aug 20, 2019 at 6:20 PM
    #147
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This guy gets it.
    Tundyfundy and AZTundra[QUOTED] like this.
  28. Aug 20, 2019 at 9:38 PM
    #148
    kgb4187
    kgb4187 New Member
    She broke his laptop so he can't get online anymore.
    Tundyfundy, AZTundra and G10dra like this.
  29. Aug 22, 2019 at 9:20 AM
    #149
    Alaska
    Alaska New Member
    2017 Tundra TRD 4x4 ~Quicksand~
    Baja Designs Squadron WC fogs
    Bump... any update on this? Did you get the tank off? Any sugar make it down there?
  30. Aug 22, 2019 at 9:31 AM
    #150
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Pretty sure OP is a skin suit for the crazy girlfriend. RIP OP.
