Sunroof Stuck Open
Discussion in 'California' started by lex2go, Aug 3, 2019.
  1. May 3, 2021 at 12:03 PM
    WodenTX
    WodenTX New Member
    Duke
    Saint Johns, FL
    2015 Black 1794
    This is exactly me right now too. I got my new motor in and while it works perfectly (slide back & forth / tilt up & down). When I close the sunroof there is a small gap to the rear of the window where the tilt up is raised a bit. If I bump the tilt up/down button I am able to position it to a closed position so it is closed but its no longer an automatic process.
    I too pulled the motor and manually closed the window(sunroof) then reinstalled the new motor and it is what it is I guess.
  2. May 3, 2021 at 4:29 PM
    poster72
    poster72 New Member
    Yeah, mine doesn't seem lined up quite perfectly, but calling it good. Just be sure you got the point where its actually closed (no free play in the roof when pushed on from below). it does an odd cycle when it tilts and closes and all, just have to watch it to see where closed actually is
  3. Jul 26, 2021 at 4:22 PM
    Mortman2021
    Mortman2021 New Member
    Robert
    Hello everyone. This may have been posted already but I wanted to share my solution to the sunroof motor issue. When I took the motor apart, one of the brushes was stuck open. I was able to work it loose, but be very careful not to crush the brushes. Getting it back together also takes a lot of care not to damage the brushes.
  4. Jul 27, 2021 at 9:38 AM
    poster72
    poster72 New Member
    Hey Mortman, not sure i understand what you mean by brushes stuck open, any chance you have a pic?
  5. Jul 27, 2021 at 9:48 AM
    Mortman2021
    Robert
    The brushes in the motor are on springs to allow them to continually rest on the rotor, even as they wear down. The brushes seem to get stuck in an open position, away from the rotor and that's what keeps the motor from working. I didn't take pictures, I'm sorry.
  6. Aug 21, 2021 at 9:57 AM
    rndomer
    rndomer New Member
    2012 Tundra crewmax
  7. Aug 21, 2021 at 10:12 AM
    rndomer
    rndomer New Member
    2012 Tundra crewmax
    Just fixed my my 2012 Tundra sunroof that was stuck open using the post from twolaneblacktop and the pictures from gasman675. Thanks to both of you! Saved me a lot of money. Getting the motor/drive re-seated between the brushes was tricky. I ended up releasing one end of each spring (per twolaneblacktop) so the brushes would stay pulled back and out of the way. With the drive barely past the brushes I had enough room using small tweezers to push loose ends of spring back behind the housing which put tension back on the brushes. Sunroof operates in all directions but did get a little out of sync on the full closing of the tilt. Just have to tap the rocker switch to cinch it closed- no biggie.
  8. Oct 14, 2021 at 8:17 AM
    rrrobot
    rrrobot New Member
    Ryan
    Ashland, OR
    2013 Tundra
    in progress
    I appreciate all the help here. FWIW I wasn't able to repair mine, but I ordered a replacement motor online and it was a very easy swap. I found it for less than $450 shipped at cheapestfactoryparts.com. It sounded a little sketchy but they were great. Legitimate parts dealer out of Ohio. I couldn't have been happier with them. It's a lot for a small part, but better than getting ripped off at the dealer for twice as much.
  9. Oct 29, 2021 at 2:11 AM
    Par2381
    Par2381 Member
    I've been to three dealerships and they all claim the head liner has to come down to switch the motor. The truck is under warranty but I don't want them messing with the headliner. Where is the fuse?
    fortiz619 likes this.
  10. Mar 4, 2022 at 4:33 PM
    fortiz619
    fortiz619 Mall crawler
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Old thread but I’m guessing the motor is under the headliner on my 2017? sunroof stuck open and it’s pouring in SoCal , I took apart the upper console whre the switch is located and there is no motor, makes me wonder if someones been in here before messy with adhesive
  11. Mar 5, 2022 at 2:49 PM
    fortiz619
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Did u fix yours?
  12. Mar 11, 2022 at 1:28 AM
    Par2381
    Par2381 Member
    Nope. Check post #18 on motor removal. You should be able to clean up the motor to be able to close the sunroof.
  13. May 15, 2022 at 1:47 PM
    gcadmes
    gcadmes New Member
    2014 Limited
    I removed the sunroof motor from my 2014 tundra, just so I could manually close my sunroof. Unable to...It wouldn't budge. Two strong guys pulling simultaneously, still wouldn't budge. I'm thinking the belt might be off the track.
    I also disassembled the motor, and it was clean as a whistle. Nothing to wipe clean. I literally never used the sunroof... maybe once or twice in the 8 years I've owned the truck, and may be why it still looked brand new.
    What was strange was how the white grease looked. It looked brand new, almost like someone recently greased the rails and the gear that pulls the belt through. I did just drop $680 on a trip to the dealership for some maintenance and repairs. Coincidence? Maybe.
    Has anyone else not been able to pull the sunroof closed after removing the motor?
  14. Aug 31, 2022 at 11:02 AM
    EEtundra
    EEtundra New Member
    2014 tundra limited
    Wanted to follow up on this thread in case it is helpful for anyone. My experience was similar to several on the thread-I had tilted my sunroof up then it wouldn’t close. Switch activation would result in clicks but no movement. I used the various instructions on the thread to access and remove the motor. For my 2014 limited, in addition to the two screws under the sunglasses holder I had to also remove two screws located under the square plastic panel that houses the two sunroof switches. That panel comes off by using a thin screwdriver to depress two tabs on both the left and right side of the panel. Like some others on this thread, my issue was a brush that was sticking in the brush holder and not making good contact with the rotor. I’m guessing this is the case with several of you that experience a similar situation and have relatively few operations of the sunroof. I would also say-don’t try to move the sunroof once you get your motor out. Just run through these motor inspections/repair and put the motor back in. When I did that, the motor worked fine and the sunroof was in sync and didn’t require any type of calibration. Hope this helps.
    sneakpete likes this.
  15. Sep 10, 2022 at 10:50 AM
    sneakpete
    sneakpete New Member
    2014 Sequioa Limited
    I am new on this site. 2014 Sequoia Limited with 106k miles . This was a $$$$ saver for me. One of the brushes in my sunroof motor was also stuck and not making contact with the rotor. Cleaned it to make sure the brush moved back and forth with the appropriate spring action. Reassembled motor and it works perfectly now. Many thanks, next project is the automatic rear hatch switch works about 2 outta 10 times that I try it, both at the switch in the cab and the switch at the tail gate, PH
  16. Mar 23, 2023 at 6:00 PM
    Pmcseq
    Pmcseq New Member
    2008 Sequoia
    What did you clean the brushes with?
  17. Mar 24, 2023 at 6:27 AM
    sneakpete
    I used some electrical contact spray, I think its mostly ether, because it dries very quickly and leaves no residue. Most important thing is that the brush makes contact with the stator (the spring action moves the brush up and down without getting stuck away from the stator), PH
  18. Mar 24, 2023 at 6:33 AM
    Pmcseq
    Pmcseq New Member
    2008 Sequoia
    Thanks, I am going to get some WD-40 Specialist Contact Cleaner and try that. My brushes dont move by themselves at all. I have to manually push them back and forth, but it is an 08' Sequoia....
  19. Mar 24, 2023 at 4:46 PM
    #49
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    sunroofs are cool and all but fuck sunroofs amirite
  20. Mar 24, 2023 at 4:56 PM
    #50
    Pmcseq
    Pmcseq New Member
    2008 Sequoia
    I agree, especially when they’re stuck tilted up. I can’t push it closed even with the motor out.
  21. Jun 28, 2023 at 10:26 AM
    #51
    2015-1794
    2015-1794 New Member
    Original Owner
    Clean and free up the motor brush's as shown in Post #18. My 2014-1794 stopped in the tilted up position. You could hear the motor clicking when the down switch was pressed. One of the 2 brushes was stuck and wouldn't move freely. release the spring, gently slide the carbon brush backwards out of the bracket. Q-tip and alcohol the inside of the plastic brush retainer bracket, clean the sides of the carbon brush, slide it back in and test that it moves freely.
    2 Torx screws, 2 - 10mm bolts, 3 Phillips screws, that's it, EASY way to save $500+ on parts.
    Just follow post #18 pic's.
    I used dental floss (and a second set of hands) to hold the spring loaded brushes back while I slid the commutator back in. Sun roof works as normal.
    I was concerned about the sync issue some folks have had so I made sure not to mess with the glass and worm-gear position. Just take the motor apart and put it back the way you found it, you shouldn't have an issue.
    It's not hard AT ALL.
    Bob likes this.
  22. May 30, 2024 at 8:44 AM
    #52
    CaLan87
    CaLan87 New Member
    Cody
    2016 Tundra 1794
    Thank you @TwoLaneBlacktop for the walk thru and @Gasman675 for the pictures. Got to work this morning and tried to close the sunroof only to hear the "click click" with nothing moving. The forecast has heavy thunderstorms tonight at about an hour after I get off work so I was kind of freaking out. Did it all at work in about 30 minutes from start to finish and now works like a champ. Really appreciate yall putting this info out here for us. 2016, 1794 w/ 101k miles on it and first time happening.
  23. Jun 9, 2024 at 4:56 PM
    #53
    Theschack
    Theschack New Member
    Eric
    2014 tundra crewmax
    Fixed like gasman675. Took it off and cleaned it with pencil eraser and electronic spray cleaner. I also had one of the actuators stuck open from gunk which had accumulated. Put it all back together and worked perfectly. If it doesn’t work you would be able to close it by taking off the silver cover and manually turning the device as in my pictures. Also included are pictures of the clips on the whole console. Slide it backwards to unclip the front and the back clips just pop out. Took about 60 minutes to complete with a good cleaning. Now that I know what I’m doing could repeat it in 15 min. Works like a charm now.
    upload_2024-6-9_18-53-43.jpgupload_2024-6-9_18-53-43.jpgupload_2024-6-9_18-53-43.jpgupload_2024-6-9_18-53-43.jpgupload_2024-6-9_18-53-43.jpg
    2mchfun likes this.
  24. Jul 27, 2024 at 10:02 PM
    #54
    Kocheesh65
    Kocheesh65 New Member
    Tom
    2017 1694 Tundra
    Thanks for all the great information and pictures. My 2017 1694 had the same issue. Removing the motor revealed one of the bushings (?) stuck. Cleaned and got it to move freely and spring able to apply pressure and it worked again. But needed several button pushes to get the moon roof to finally close…motor is not running completely smooth but was good enough to close.
