Suspension for 37's
Discussion in 'Suspension' started by takaya49, Mar 23, 2020.
  1. Apr 1, 2020 at 9:48 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    37s? Never heard of her..
  2. Apr 2, 2020 at 11:52 AM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Some people call it a Cab Mount Chop..
    Mountun Goat likes this.
  3. Sep 1, 2020 at 1:57 PM
    Smoph
    Smoph New Member
    Tyler
    2015 Tundra w/6" RC Vertex Lift
    Those are the Pro Comp Fenders. They run like $1500-1600 unpainted. Super bad ass though!
  4. Sep 26, 2020 at 7:44 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    This guy lives 2 hrs from me in La Paz. He's running a Long Travel setup by ProComp and it's not as expensive as Camburg, Total Chaos, LSK, etc., granted it's not as strong as the others mentioned but it's a complete build so you don't have to mix and match front and rear, cut or weld, all you gotta do is add some shocks. The whole suspension can be had for $5000-$5,500 if you go all ProComp. Flares not included.
    If you're not thinking of blasting through whoops at 80mph then this setup just might work for you.
  5. Sep 26, 2020 at 8:02 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I heard pro comp is discontinuing that LT kit tho.
  6. Sep 26, 2020 at 8:04 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    37x12.5x18 on+18 offset and 1.5’ spacers up front. I’m at just under 4” lift. Bmc and spc uppers.
    I just can’t get over how 37s look factory to me now that I’ve run em for a while. These trucks with any lift and oe wheel size look weird to me now.
    37s are the new 33. @Spvrtan is the new 37”. :D
  7. Dec 28, 2020 at 12:55 PM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    How much lift is in the front/rear? How do you prevent the tire going through your wheel well when hitting bumps? I fell like it’s not enough room for the wheel to travel up? I could be wrong? Also do I NEED swap out the leafs in the rear and lift the back?
  8. Dec 28, 2020 at 2:41 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    sillydadztrksR4momz likes this.
  9. Dec 28, 2020 at 8:18 PM
    Eleventeen
    Eleventeen New Member
    Louis
    2016 Black CM Tundra
    does the offset really help with fitting those 37's? i have +12 offset with king 2.5's all around and TC UCAs up front and Deaver pack in the back. I could see clearing in the rear but the front doesn't look like it would clear.
    Pnoy_toy and MJoeP like this.
  10. Dec 28, 2020 at 11:13 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    It does help slightly. For the BDS lift the offset (or backspacing) keeps the tire from rubbing the BDS spindles. The back of the tire contacts the body mount hence the BMC (body mount chop).
    Here's BDS' required backspacing for tire size
    Tire & Wheel Combinations
    35 x 12.50 w/18x9 and 5-1/2" back spacing
    35 x 12.50 w/20x9 and 5-1/2" back spacing
    37 x 12.50 w/20x9 and 6-1/4" back spacing
  11. Dec 29, 2020 at 4:17 AM
    Pnoy_toy
    Pnoy_toy New Member
    I have similar setup up for my front suspension and was wondering the same...so I went and ordered 37’s anyways, and pray them fit
  12. Feb 3, 2021 at 5:22 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    Did you have to regear?
  13. Apr 11, 2021 at 4:23 PM
    tnine
    tnine New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
    Im also curious if you had to regear as well. I have 295/70/18 on right now and I want to move to 37x12.5. I have the 4.3 diffs from the tow option in my 2016. I still have plenty of torque, but I have to drive in tow/haul mode all the time to stop the truck from shifting up prematurely with the larger tires.
    XPTUNDRA likes this.
  14. Feb 3, 2022 at 2:32 AM
    AKMelendez
    AKMelendez New Member
    Adrian
    2017 All Black Tundra
    7” BDS Lift All chrome delete 35s on 20s
  15. Feb 3, 2022 at 12:43 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Yes, body mount chop was done and BMC covers welded in place.
    Plates (and a pretty good pic of them installed):
    https://socalsupertrucks.com/body-mount-plate-kit-07-20-toyota-tundra/
    Pic is of the wheel well where the inside edge of the rear of the tire would rub (or will rub without the BMC done).
  16. Aug 28, 2023 at 2:14 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Tundra Limited 4x4 CM QS / 2000 Tundra Limited 4x2 AC Black
    What wheel size and offset? Are those 37x12.50?
  17. Apr 25, 2024 at 11:27 AM
    Quicksandtundy
    Quicksandtundy New Member
    Travis
    Quicksand Tundra
    Does anyone know what fender flares these are?!
