Switch Pros SP-9100 Install
Discussion in 'General Tundra Discussion' started by Bailey, Feb 6, 2018.
  1. Aug 17, 2018 at 1:12 PM
    #61
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Yeah, ive read through this thread a couple times. Currently reading instructions that came with it.20180817_151212.jpg
  2. Aug 17, 2018 at 2:17 PM
    #62
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    Would like to know which pic.. One might be a trigger wire...
  3. Aug 17, 2018 at 3:13 PM
    #63
    Bohica_sob
    Bohica_sob New Member
    2014 Tundra
  4. Oct 13, 2018 at 10:29 AM
    #64
    Texas Bandit
    Texas Bandit New Member
    Amí
    Edinburg Texas
    2007 White 5.7 Tundra DC Limited 4x4
    295/70R18 Nitto Ridge Grappler Method Race Wheel NV Bronze Rigid Industries Radiance Pods Morimoto Xtorch 36” Light Bar SDHQ Pillar Light Mounts
    Man I have been looking at this setup for a while and I never wanted to pull the trigger cause I only see pictures being installed on 3rd gen tundras didn’t think it would work for 2nd gen and didn’t even know where to put the switch panel. But this was a huge help looks awesome!!!
  5. Oct 13, 2018 at 2:31 PM
    #65
    Bailey
    Bailey [OP] Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Thanks :hattip:
  6. Oct 24, 2018 at 6:24 PM
    #66
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Where did you guys penetrate the firewall with the switch panel wire loom?
    831Tun and dcsleeper408 like this.
  7. Oct 24, 2018 at 7:27 PM
    #67
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I went through where the main harness goes through the firewall(cut a little slit and poked right through) You can try the smaller hole, but I didn't bother. Driver side, ends up coming out inside near the kick panel fuse box. Then just route it accordingly to where you will mount the switch panel.
    831Tun and GiantsFanDan like this.
  8. Oct 24, 2018 at 7:51 PM
    #68
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Same as Mark, driver side.
    GodlessPro and dcsleeper408 like this.
  9. Oct 24, 2018 at 8:29 PM
    #69
    Baja Mike
    South Bay, Ca.
    That's what I was thinking. I already ran a wire harness for my hood bulge light through there. But with the switch pros harness I wont need it.
    Do you guys have any under the hood pictures of how and where you mounted the computer/brain? I have the SDHQ mount and I plan on using it while using a terminal block like Bailey used.
    831Tun likes this.
  10. Oct 24, 2018 at 8:44 PM
    #70
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I have it mounted here.
    I’m planning to move it on to the fuse box cover after I redo my bedcage wires to a mil spec quick disconnect.
    I have plans to redo the plate as well so I can add a few more things on, but I’m sure you see where I’m going with it.
    Someone on here had a covered terminal block. I can’t seem to find it anymore. Sealed would be nice to have.
    GodlessPro and 831Tun like this.
  11. Oct 24, 2018 at 8:50 PM
    #71
    Baja Mike
    South Bay, Ca.
    Very nice. I ordered this block from Amazon: https://www.amazon.com/gp/product/B000MMH1GM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    dcsleeper408[QUOTED] likes this.
  12. Oct 24, 2018 at 9:00 PM
    #72
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  13. Oct 24, 2018 at 9:15 PM
    #73
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Sub’d For future. I just got a roof rack mounted with 13 rigid pods and it’s powered by an sp-9100. That’s just what the previous guy had so I bought it from him.
    Had no idea how complex this thing was so I’m looking forward to learning.
    831Tun likes this.
  14. Oct 24, 2018 at 9:23 PM
    #74
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Honestly the 9100 is super simple. Using a distribution block makes it easy to change things around. Say you want the rt side bank of lights on switch #2, later it's easy if you change your mind and want to move it to switch #4.
  15. Nov 1, 2018 at 5:57 PM
    #75
    Baja Mike
    South Bay, Ca.
    So I finally got it hooked up and energized. Yay!!
    Word of advice for anyone wanting to do this, invest in some quality wire crimpers!
    43AB5B2A-CE39-4624-9DF6-232586699879.jpg 9DCA821D-68A4-4A13-A7E6-3339CFACF9FA.jpg
    The wire loom coming out of the hood is for the Baja Designs bar. A 3/4” rubber grommet fits in the hole perfectly and the hood is hollow so running the wires wasn’t difficult. Just need to fish it through with some stiffer wire.
    I still have the lower bar wire loom to run to the terminal block and the accessory lights to hook up and just clean up the wiring. I might go back and re-crimp things when I get some real crimpers.
    I downloaded the app and got the background color adjusted. Now one final question for you switch pro Pros...
    How do I designate which switch to light up which light? Currently I have switch 5 for the 40” bar. I want it on switch 1. How do I do that?
  16. Nov 1, 2018 at 6:19 PM
    #76
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Switch 1 is the Brown wire from the SP
    2 is red
    3 orange
    4 yellow
    5 green
    6 blue
    7 violet
    8 grey
    dcsleeper408 likes this.
  17. Nov 1, 2018 at 6:25 PM
    #77
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    BTW switch 1 is limited to 240 watts. So, be sure your bar can't/ doesn't pull more than 240 watts. If it does and you still HAVE to have it on switch 1 you can use a relay but that kinda defeats the purpose of the SP.
  18. Nov 1, 2018 at 6:30 PM
    #78
    Baja Mike
    South Bay, Ca.
    I have it wired to sw5 because it can take 30 amps.
    Specs on the light:
    Specifications:
    Lumens: 25,312 Utilizing 32 Cree LEDs
    Wattage/Amps: 224W / 16.23A
    Dimensions: 40” x 3” x 1.6”
    Looks like I can just wire it to Switch 1 like you said.
    Now what is the Trigger wire for?
    dcsleeper408 and 831Tun[QUOTED] like this.
  19. Nov 1, 2018 at 6:39 PM
    #79
    ZPMAN
    Minnesota
    TRON, jc153, SoCal619 and 1 other person like this.
  20. Nov 1, 2018 at 6:59 PM
    #80
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, you could wire it to SW 1 and still have a slight margin for error.
  21. Jan 3, 2019 at 2:33 PM
    #81
    coTony
    Tony
    Sun Lakes, AZ
    What is that bracket used for? I must have missed something. Going back to read
  22. Jan 3, 2019 at 2:55 PM
    #82
    Bailey
    CO
    It's a bracket for people that don't want to install the switch pros directly to the fuse box cover
  23. Jan 3, 2019 at 5:35 PM
    #83
    ZPMAN
    Minnesota
    coTony[QUOTED] likes this.
  24. Feb 4, 2019 at 8:17 PM
    #84
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Thread revival! @Bailey I love your terminal block setup and will be doing the same with the addition of a negative bus since failure to properly ground my lights killed my 8100... Now that I have a fancy new 9100 I plan to rewire everything and make it even cleaner.
    First question, why is your ground wire (black) run through the terminal block and then to the battery? Is that necessary or can it be run straight to the negative terminal on the battery?
    Second, looking back at the picture showing 2 add-a-fuse into the fuse box, what relay or fuse is being tapped with the (white) wire for lights? Did you do this as well or run it into the cab?
    I'm sure there will be more questions to come but you guys have answered most of my questions throughout this thread. Now I just need to locate a solid cover for that blue seas terminal block :thumbsup:
    Rica25, 831Tun, jc153 and 1 other person like this.
  25. Feb 4, 2019 at 9:22 PM
    #85
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    [QUOTE="TRON, post: 1002773, member: 2398" ]Thread revival! @Bailey I love your terminal block setup and will be doing the same with the addition of a negative bus since failure to properly ground my lights killed my 8100... Now that I have a fancy new 9100 I plan to rewire everything and make it even cleaner.
    I'm sure there will be more questions to come but you guys have answered most of my questions throughout this thread. Now I just need to locate a solid cover for that blue seas terminal block :thumbsup:[/QUOTE]
    I had to make my own cover for my Blue Sea terminal block. It was actually quite easy, much like working with wood. I used some acrylic and a special glue that I got from the local plastic shop.
  26. Feb 5, 2019 at 8:58 AM
    #86
    Bailey
    CO
    - It's not necessary to run the Negative wire through the terminal block but I did for easy removal. I can completely disconnect the wires and remove the fuse panel cover if needed. Going directly to the battery would have one more thing to disconnect
    - Tapped into the Parking Lights for the White Wire.
    TRON[QUOTED] likes this.
  27. Feb 5, 2019 at 8:59 AM
    #87
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Right on thanks man! :cheers:
    Bailey[QUOTED][OP] likes this.
  28. Feb 5, 2019 at 9:20 AM
    #88
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    @Bailey great write up and install! Yours looks super clean and well thought out.
    I did something similar with my 8100, still have a little cleaning up to do and maybe few small changes. I hate wiring with a passion.
    Rica25 and 831Tun like this.
  29. Feb 5, 2019 at 9:29 AM
    #89
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice and clean for someone who hates wiring.:thumbsup:
  30. Feb 5, 2019 at 1:25 PM
    #90
    Bailey
    CO
    Thanks :hattip:
    14burrito[QUOTED] likes this.
