Switch Pros SP-9100 Install
Discussion in 'General Tundra Discussion' started by Bailey, Feb 6, 2018.
  1. Feb 6, 2019 at 3:39 AM
    #91
    coTony
    Tony
    Sun Lakes, AZ
    Which fuse are you tapped into for the White wire (LIGHTS/Input/T2) in your fuse box? What year is your Tundra?
    Rica25 likes this.
  2. May 30, 2019 at 7:47 PM
    #92
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    @Bailey thanks again for the write-up. Reading this has given me the confidence (er, delusion) to try this for myself.
    Rica25 likes this.
  3. Aug 26, 2019 at 8:32 PM
    #93
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    OK. Finally getting around to wiring this thing up. Such a Noob with 12v electrical for all the xtra stuff. Sorry about that just trying to figure all this out. Once it makes sense I second guess myself....
    Hopefully, this is a simple question for anyone that can answer.
    Im a little confused on the switch pro wiring. Are the Switch Pro leads actual power or just the remote switch for the accessory?
    I noticed the first 4 are limited to 20 amps and you can combine the last 4 leads in pairs for 35 amps to each switch. It wasn't making sense that 35 amps would be running through 14 gauge wire.
    If I'm understanding this a light bar setup would be like this.
    + lead from light to battery
    - Lead from light to ground
    > accessory wires for toggle switch wired to Switch Pro lead instead of to a toggle
    or is it
    + from light bar to Switch-Pro lead
    - from light bar to ground.
    > take accessory wires to toggle out of the equation
    Thanks for any advice....
  4. Aug 26, 2019 at 8:41 PM
    #94
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    This is correct. The switchpro leads provide the power. Most people add a ground bus bar next to the Switch-Pros.
    GodlessPro likes this.
  5. Aug 26, 2019 at 8:49 PM
    #95
    NoRcptn
    NorCal
    2017 Platinum
    Ok, that's way simpler to wire. Thank you.
    Rica25 likes this.
  6. Aug 26, 2019 at 9:19 PM
    #96
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    It's more intimidating than it is difficult.
    Rica25 likes this.
  7. Aug 28, 2019 at 7:49 AM
    #97
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    In the end, I have to admit I enlisted the help of @Porschetech29 . Man, so glad I did!
    Jman245, Rica25, Pinay and 6 others like this.
  8. Sep 3, 2019 at 5:46 AM
    #98
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Anyone running the high beam trigger to a lightbar or set of high power lights? Any issues, especially with the 18/19s? Thanks!
  9. Sep 10, 2019 at 6:42 AM
    #99
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    No, but great idea if it works.
  10. Sep 15, 2019 at 8:14 AM
    #100
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Looks good Sam and nice work Francis. @Porschetech29
    Looks like a lot of us followed @Bailey lead mounting on the fuse cover, I even mounted my switch in the same spot he did. Hey imitation is the most sincere form of flattery.
    Here’s mine, I added a bus bar for all my grounds.
  11. Sep 15, 2019 at 9:36 AM
    #101
    Rubberdown
    Man I would find someplace to hide all that wiring. I couldn’t stand it.
    fundratss and sdhq_offroad like this.
  12. Sep 15, 2019 at 9:42 AM
    #102
    jc153
    San Diego
    Hahaha yeah but it’s accessible if needed and I can remove the fuse cover without disconnecting anything.
  13. Dec 30, 2019 at 9:31 PM
    #103
    Rica25
    Ricardo
    Tulare
    where did you run the ACC to?
  14. Dec 30, 2019 at 10:15 PM
    #104
    Rica25
    Ricardo
    Tulare
    If tapping into the Ignition fuse have any of you guys came across a blown fuse yet for any reason on that tap?
  15. Dec 31, 2019 at 8:09 AM
    #105
    NoRcptn
    NorCal
    2017 Platinum
    I ran the ACC ( I actually ran all three wires- ACC, White and PINK) through the fire wall into the fuse panel under the driver kick panel. There are two open fuse slots that are controlled by ignition on my 17'. I used one of those fuse slots. I didn't want to wire tap or splice any wires. I did not end up tying the white or pink into auto dimming lights or anything else. I just capped them off and left them there for future use if I decide to.
    Rica25[QUOTED] likes this.
  16. Dec 31, 2019 at 8:47 AM
    #106
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve not blown a fuse in either of my trucks. Using add a fuse into the fuse box under the hood.
  17. Dec 31, 2019 at 9:25 AM
    #107
    Rica25
    Ricardo
    Tulare
    Cool thanks I was planning on those as well
  18. Mar 19, 2020 at 2:09 PM
    #108
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    Anyone knows the stock code for connecting the SP via BT to the App?
    If pressing the scan button in the app, it does not find anything. If trying to connect phone (via settings, BT) to the SwitchPros, it sees the device but asks for a code...
    Thanks in advance, B.
  19. Mar 21, 2020 at 4:36 AM
    #109
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    App freezes after connection (Android version), does not seem to be something that has been engeneered carefully...☹
    Rica25 likes this.
  20. Mar 21, 2020 at 5:27 AM
    #110
    NoRcptn
    NorCal
    2017 Platinum
    I didn't think there was a stock code? Mine (iPhone) showed up as SWTCHPRO)or something like that, then prompted me to create a password. Is it a used SwitchPro or new?
    If it's used and a password was entered you'll need that to unlock it. I have the Apple version and didn't have any issues. Although more cumbersome, you can program through the panel without a bluetooth connection.
    Give them a call or email, if they are answering at all during these crazy times. They were more than helpful when I reached out.
    shellshock and Rica25 like this.
  21. Mar 21, 2020 at 11:48 AM
    #111
    Beni36ti
    Beni36ti New Member
    2017 SR5 CrewMax
    Thanks for the reply, I will test with an IPhone and report back.
    No, new SP, this is not the issue thank good
    Rica25 likes this.
  22. Apr 17, 2020 at 7:05 AM
    #112
    Salty Taco
    Salty Taco New Member
    Michael
    2020 TRD Pro
    Wheels: Method Race 701 17” Tires: BFG KO2 315/70/17 Suspension: TRD Pro with shims, shackles, and bmc to fit tires Rock sliders: C4 Bumper: C4 Hybrid Winch: Comeup 9.5 Lights: Baja Design (XL80 combo, Sport SAE fog, S2 spot, S8 30” combo, amber rocks) Onboard air: ARB (mounted in engine with Victory 4x4) Locking rear: ARB Electrical: Switch Pro 9100 Bed Stiffners: Rago Bed Molle Panels: Rago 5th Wheel Mount: Rigd
    What is the gauge of the wire running from the negative terminal of your battery to the bus bar?
  23. Apr 17, 2020 at 11:12 AM
    #113
    rattail00
    rattail00 New Member
    Northwestern WA
    2017 Toyota Tundra SR5 Crewmax
    Which distribution block did you buy? Looking to buy the same one and set up similar.
  24. Apr 17, 2020 at 12:10 PM
    #114
    Bailey
    Bailey [OP] Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Blue Sea makes some good stuff
    rattail00[QUOTED] likes this.
  25. May 5, 2020 at 8:23 PM
    #115
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    I started my install today and mounted almost same as you did. I only got the switchpro installed and my light bars installed. Still need to wire up the locker and compressor and couple of deals before I clean up the wiring Aera and install a 3D printed cover. Here’s couple pics
    B02035C0-218A-47EB-9E20-AC70F4C39CEA.jpg 25E70034-3736-4E1F-9AA6-69B79CB6DAD7.jpg
    I really really don’t like seeing wiring that’s aftermarket just zipped tied or hanging around everywhere. So I’ll prob end up drilling and putting a grommet for the accessory wiring to minimize it. I’ll update when boss lady lets me finish installing everything haha
  26. May 5, 2020 at 8:26 PM
    #116
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    I ran mine to trigger two light bars with my high beams turned on. I have the morinoto Xb headlights installed as well. Works like a charm. It’s awesome. And I also have the light bars to strobe on a double tap of the switchpro.
  27. May 5, 2020 at 8:31 PM
    #117
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    since this is the go-to Switch-Pros thread (because @Bailey is a badass) I want to share a mount I stumbled upon over the weekend that goes in the business card holder part of the overhead console.
    1. Yes it looks like a robot face
    2. No you'll never unsee that
    3. It will be available on trailcommand.com in about a week
    Sunnier, Bailey[OP] and fundratss like this.
  28. Jul 14, 2020 at 3:51 PM
    #118
    Snikskytter9
    Snikskytter9 New Member
    Rich
    New Hampshire
    2017 Tundra SR5 TRD off road
    2” level Nitto Ridge Grapplers Switch Pros 9100 Alpine wireless CarPlay Pillar post lights / amber / white Grille mounted light bar TRD Pro grille Dipped/blacked out badges 20% front window tint RCI 12” rack DECKED bed system LED bed lighting OEM Tow mirrors Crappy awful magnum research side steps.
    Thanks for this post and everyone’s input. I’m a bit of an electrical layman and this thread seriously helped me succeed getting my Switch-Pro installed and running. As much as I dislike and reject the internet overall, this is one of those times I appreciate it. I appreciate this community more. Thanks agian everyone!
    farm&forest, Sunnier and NoRcptn like this.
  29. Dec 8, 2020 at 1:40 PM
    #119
    Brent D
    Brent D New Member
    Brent
    2017 Tundra
    Any Idea where @Porschetech29 found the Fuse block with a cover?
    Looks really good and somewhat protected
  30. Dec 8, 2020 at 1:52 PM
    #120
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Over time the cover will not stay on. Been running without the cover for over a year without I’m any issues. I’ve been using Blue Sea terminal blocks for the past 4 installs. Here is an example from an 80 series Landcruiser I did a couple of months ago
    C3C0D854-5518-4226-A6CD-94DADE536627.jpg FE834045-2469-41E0-97D2-7BFCCD198D44.jpg 93D5FCF4-892A-48E6-A78E-53B6232AA9DC.jpg
