Tech12volts / Taylors Audio review...
Discussion in 'Audio & Video' started by Tchase, Sep 2, 2020.
  1. Sep 2, 2020 at 8:33 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    i did a complete jl audio and kenwood hu because i still like the option to play my old dvd/blueray and cd's. lol. and what the OP said about being sent 'everything' he meant it. screws, barrel connectors, everything needed.
    if you invest in the system i'd recommend also installing sound deadener. they use sound shield which i did for all four doors and the rear panel.
    Kenwood dnx996xr headunit
    1 JL audio 12w1 sub
    2 JL audio c1 650 components
    1 JL audio rd 900/5 amp with sub knob
    2 oem sail panels
    trd sub enclosure
    amp rack
    Tchase[OP] and betotundra like this.
  2. Sep 3, 2020 at 4:59 AM
    spittoon
    spittoon New Member
    South Jersey
    2020 Tundra TRD Pro MGM CM
    Toyo OC ATIIIs, AMP Powersteps, Diamondback SE, Line-X, Tech12 JBL package, SPS Graphene coating, Front Runner Load racks w/rod carriers.
    Hey guys,
    I'm bout ready to pull the trigger on one JRT's systems as well. Just awaiting delivery on my 2020 TRD Pro CM. As far as installation, how was it? I'm seriously debating whether i feel comfortable enough ripping out seats, taking off door panels, cutting holes through firewalls, etc. I do have a pretty good skillset and am pretty handy as I've built an old CJ7 from the ground up, so i do know my way around a toolbox, but it's just the, "am i really gonna rip this brand new thing apart right now?" feeling...
    And to echo previous posters, yea, James has been awesome with my back and forth emails as busy as I'm sure he is.
  3. Sep 3, 2020 at 5:04 AM
    Tchase
    Tchase [OP] MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Easiest stereo install I have ever done. The firewall is simple because it’s on the passenger side and it’s just a rubber grommet.
    The interior panels consider it practice for all the other mods you will do...
    The hardest part for me was deciding where and how to mount the rear tweets.
  4. Sep 3, 2020 at 5:13 AM
    FUBAR
    FUBAR New Member
    2019 Tundra TRD crewmax
    It is a pretty straightforward installation. I had never installed a system before and it took me around 10 hours for everything. Watch youtube videos for door panel removal and make sure you have all your tools ready to go before you start. Harbor Freight sells a trim panel kit and it works great. The rest is covered in his instructions. You can also spread it out over a couple days by installing the speakers in the doors one day and then doing the sub and amp another day. You can also prep things up the night before like putting the sub in the box and wiring up the adapter to the amp.
    Tchase[OP] likes this.
  5. Sep 3, 2020 at 9:25 AM
    sensei
    i could have done it myself but my brother used to own a 12 volt business so he helped me. he was much faster and cleaner. he had me focus on deadener and speaker install while he did the amp and hu but like others have said it's straight forward esp if you've done some car work before. youtube videos are great to help you understand how to remove stuff without jacking up your ride. but also as a former shop owner he had great things to say about the kit so if you're worried, get the kit and consider taking it to a local shop to have them install. good luck. this way you also support local business in the pandemic. they could prob use it. post pics :)
  6. Sep 3, 2020 at 12:29 PM
    Intermittent_Fisting
    Intermittent_Fisting New Member
    Brooks
    2017 Tundra TRD Pro
    That looks pretty awesome! Any idea what the depth of the box for the sub is? I’ve been looking around the net for days trying to find out if the JL12TW3 PowerWedge box would fit behind my back seat. It’s 7” at the bottom and 4.5” depth at the top. Thanks!
  7. Sep 3, 2020 at 1:11 PM
    Tchase
    Buckley WA
    In work
    Just an FYI if you have a DC the box has to go under the seat. If you hav CM it can go behind.
    mask me how I know...
  8. Sep 8, 2020 at 9:59 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    RdKing raises his hand every time someone asks about JRT @ Taylor's Audio aka. Tech12Volts.
    Their advice, equipment and research & development process is INCREDIBLE !
    Just stop by my shop anytime your in the neighborhood ......... Ill take you for A Tunes Test Drive.
    Your going to hit the buy button So Be Prepared
    RdKing.
    MillMatter likes this.
  9. Sep 15, 2020 at 5:47 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Nice looking install, Please post pics of your RTA curve when you have a chance, I would love to see how well the system responds once tuned.
    wolfeman007 likes this.
  10. Oct 22, 2020 at 7:43 AM
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    This has to be the only reason the CM is better than the DC. I just started down the stereo rabbit hole. Got the truck I've always wanted and it's a pure dream but absolutely lacks in delivering kick drum sound to any fiber of my being. Am I wasting time looking for a sub enclosure to go behind the back seats of a DC? I always have my rear seats up and use the crap out of the trays/underseat storage. I can't imagine losing that to fit a sub.
  11. Oct 22, 2020 at 12:53 PM
    Tchase
    Buckley WA
    In work
    I'm sure you could find/make one that would fit like a tube with 8"s but it won't deliver the thump of the one 12"
    The 12" under the back seat drivers side has enough base to make your balls jingle, yes you loose the space under the seat, but if you do the seat mod you gain some back behind the seat.
    As for the "only"reason I would argue that if you want a long bed it's certainly not the only reason.
