The Cream Pie - A 2005 4wd/LS/5-Speed/SAS Conversion
Discussion in '1st Gen Builds (2000-2006)' started by the_white_shadow, Aug 8, 2019.
  1. Jan 20, 2022 at 5:05 PM
    #181
    the_white_shadow
    the_white_shadow [OP] New Member
    I finally have had some time to start working on the Tundra again now that im back from offshore. Updates should come more regularly.
    First things first, I rolled it out and gave it a good bath to wash off 2-years of grinding dust. It will definitely need a clay bar.
    hOx9haRBCLaSon-MsQJPi0O5KtSfW6uwkIVT_apw_ca644b16a6ecb2920f18e43303279e7b710a7a53.jpg
    Rolled it back inside and put it on the lift where it will remain for a while.
    TfIgv601rCTiis8NC9t9tH-3h1n1vnokCt39GLNc_2a76621c52e45eb1be9f3ccd927dd13852757c25.jpg
    Yanked the front end and drivetrain to finish up the front frame.
    ipuuusG6xTO5wLoJfqB1RdgyDRuiyVg8TIp1EEUs_7517c9f0661c9a7d4451cbc55012cb9bc433dd09.jpg
    Quickly figured out why the 6.0l was making a noise when i pressed the clutch in. Its getting all new clutch components when it goes back in.
    sWCo3iHFGIsPCIyUJ2_T1YcbywhCKYvcwkUu-LtB_6a6f69f36a0c52903ab552f2fc84433f5b429e45.jpg
    Mocked up the hydro assist ram
    fN0lxH_VLwbnowqWw7RleOol5r_EiSPL32dWErNl_cbbe163616738683fcb4fe22ca72fe77a20e5cc7.jpg
    B0axeWqN6B8VMDnjNM2QJXifrUxTMUW4l8g3IrfE_16d7ee4b3250db5799d44f00bdefd3356bccebaf.jpg
    K5ol2lBllCfJF9sWxlOY1MWyyH9OktFEGjMN1T4B_7549d546d46dfebb7fe1a4445a32399df9ab3ec6.jpg
  2. Jan 20, 2022 at 5:09 PM
    #182
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
  3. Jan 20, 2022 at 5:13 PM
    #183
    the_white_shadow
    Next i cut out some frame plates by hand to help reinforce the frame. I will be boxing in and and fully welding the flimsy ass riveted frame.
    As8s4yyKxQDUcrnqOXLffyBySdi4OEG_kf8Gp7hI_f3f01c602b9e00450726a2f79f60f46b4983b523.jpg
    XIsV_y9m4LhywUjgWSdbMMBxI0gjIdPbCGnMaTVn_6498ae5e59444cea9884d82858e82ba5fb3b8c08.jpg
    tWrWW9VEisU2AC4yqhVYW8GkcmeSZ1NyZyP5PbSh_164bc88b21774b37b98eda8c1bdeaa3125599eae.jpg
    hfuHuGRKqm84seM-6hq-l32m0lf0lC8oK7EIXHeQ_5d55ea0fc51318258763831fe3dde20519d0017c.jpg
    Painted it with some steel-it. Its weldable paint for when i add the shock towers later on.
    GHGtwdeC9CYy4uOl80L3hCyeyI3W-EUisd5p2xg8_081fbf682e5d7dbed9d0b451666e1d702ada4626.jpg
    I then started on the engine work. Swapped in the BTR Truck Norris camshaft. Im waiting on new lifters/ARP head studs / gaskets to come in to complete the rebuild. Then it will be put back in the truck.
    Only 3x exhaust bolts were broken off in the heads.
    0YBvpziXedpSFwUQnFBX12Npd-PFT4lQx33jCFKh_9f815b427f40d7606426421c2afe14d733a59ddc.jpg
    Iz0E54I8AW_K7thm_jJ7r4g4nEIuMVDQa7nO6rdk_11bb4e7c0f4218d5e15baed845d6d69f445ee0d2.jpg
    Added 10hp
    BQ5k5imfWQvoPY6lqJeasaPZbDtpftb0Bh__MjNr_9eba84ce39384e36fcd4b9ce37558c9cb3d7cbb5.jpg
    I also ordered a 2nd gen tundra fuel pump assembly as the pump for the 5.7l puts out plenty of psi/gph for the LS. I think the og 1st gen one would have worked as well, but it would have been at the limit. We will see if I can make the 2nd gen assembly fit the 1st gen tundra tank. It looks like it will work.
    More to come soon.
  4. Jan 20, 2022 at 5:19 PM
    #184
    the_white_shadow
    Also did a little crawling in the dirt squirrel over the weekend.
    TOYiyZ_WdTg12Qm5b-ZJuB1D0YfW58lSmC63VpNk_f6587e74412e6c1025ed667fb31c905294eaccf5.jpg
    hpPvb4SzoJqx-1bsdw1-WbuIGNCyF6mkjUHsPsl9_adefe3271f055eb7cae7874befa5f4fe9c698206.jpg
    7EAzpXWctxtwU7jJmHHr5dwzIBz7FTeRsoaAajwh_0d88430f218ee5a76e4debea2e5c1de1ed5dc5e6.jpg
    RXXqOykk_cP4ayXtX84WbI-CFwAYOcmtvCauqOcT_cbf5b822856759881539d4551b06b558c6a53809.jpg
  5. Jan 20, 2022 at 5:28 PM
    #185
    easleycrawler
    Travis
    Must be nice to have that kind of rock to play on.
    Darkness likes this.
  6. Jan 20, 2022 at 5:34 PM
    #186
    the_white_shadow
    We are definitely spoiled with it only being 4.5 hours away.
  7. Feb 1, 2022 at 9:28 AM
    #187
    the_white_shadow
    More updates from the last two weeks: Finished boxing in the Tundra's frame all the way back behind the gas tank on both sides. That was a lot of fun. Also all crossmembers are now welded in instead of riveted. Its amazing how much less flex the frame now has.
    SxYJdt53HKKU8oeNr9j55_NTEjy8oKLvV5deQtVV_6964f927df7712b5fbb87e9c2120e110d553a6d9.jpg
    5dseXouKLazz9jUmQ0Sf0C_HkfbGs6Oyp1CsII7Y_20fb32b9a885fa46c5449bc9023fbc67fe3f8b31.jpg
    S-QSIMunPLad2MIsCE_6giaikhYC8pKxFSF-Onma_26ea31f62d86293ebf077c5888005271d832d9b8.jpg
    New 5.7L Tundra fuel pump assembly (right) next to the old 4.0L one. As you can see the sumps and top mounting flanges are identical. The fuel float arms are different and one is obviously shorter. The tundra 5.7L pump puts out 125psi and more GPH than the older pump. Should be much better for the LS (especially if i go supercharger in the future). Even the plug works.
    M_v_2obaF3j2xCIDf5LoauZJBQGxk2103NDxLMC-_ad948c1f281077f18c36cdbfe2953ae387cc0e5b.jpg
    here is my combination of the two. Old top and sump lid with new pump in the bottom. I lengthened the pump wiring and snapped it all together. The fuel level arm fits in the tank without issue.
    C89uzhLLmBd7hyPWMMcRkw0ZvYGUTx-H4755FYqb_857758648d9243ec040b86781c24e2487e9bdd35.jpg
    Radium Engineering makes some slick adapters for the toyota fittings to convert over to AN. Im running -6AN to the corvette filter/regulator then one line to the fuel rail on the intake.
    vbcV8ppZtCWlnxF9-T8w-G-H32PsrkG4YSya6sGQ_216bf816e3166eed5876b512f15f80d2cae11cd1.jpg
  8. Feb 1, 2022 at 9:38 AM
    #188
    the_white_shadow
    The LQ4is rebuilt-ish and resealed and back in the truck, along with a newly resurfaced flywheel, new clutch/TOB/pressure plate/etc. NV4500 also back in.
    Converted the hydraulic TOB over to -3AN and ran the line to the stock Tundra master cylinder on the firewall. Russell makes a fitting.
    nwUGtMe4en6Le2vGPDl_ndDjbf9hFbqKpalhwr5I_0210be493685118afb0ff60d5d1af126c0d08865.jpg
    Engine back in with new PSC P-pump on an old set of Goat Built accessory brackets i had on the shelf from the crawler. New el cheapo ebay throttle body, NNBS intake and injectors, fancy thiccc red plug wires, gold paint.
    JEIoM5eJ4a2Nyq_8NzDP0iAumVky1C97dXul8nX1_dbd5e2f6667b8981db3c14c8bdcf0f6b5fe37f1c.jpg
    The NP261 t-case had the infamous pump rub problem that i didnt know it had until i was changing out the front output shaft. Here you can see one of the 3 holes it made in the factory magnesium cover.
    yVlFFjG5z-YXVWI02p1-c6SJtCVT-Ue7WNBhndAD_12f75061f0fd0d8ec1a2c1407bba456fcfcea279.jpg
    The shift fork was also ground down pretty good and there was aluminum everywhere inside the case. The top isnt supposed to have a point on it.
    WJJw_uqXY4_8VAw2QAaL3T_C2B1b4AtA8vlma8yQ_b441420cdbfadb55c6e414f4037ef900e66f9236.jpg
    So i bought a new case half and a rebuild kit and went to town last night rebuilding the case. First time for one like this and it went pretty smooth. Waiting on the new shift rail to come in and i can get it all back together and in the truck.
    47GkmdsT6NnM-egqJ9EvMzD1j1xqGQILtHyguODG_daac179f39a7c4cc1f562937e2fc6145430a667a.jpg
    Old bearings and shit oil pump before tear down.
    k6kSteh_pnipiQ7YSnwx7hTHAcnnMXWVI-ehPVzw_958380c9514e3feb4b5fd0b684d2e3ad1e9c8bad.jpg
    I also did a little wiring of the starter circuit and got the truck to turn over using the Tundra key. Now my next step is integrating the Holley Terminator X harness into the tundra wiring so i can reuse things like the fuel pump wires, ignition + wiring, turn signals, fuel level, AC, etc. I want it to all work as normal with the tundra's key turning it all on and starting the truck. Hope to maybe hear it run in the next couple of weeks.
  9. Feb 1, 2022 at 12:44 PM
    #189
    easleycrawler
    Travis
    I spy a bumpside f100 in one of those pics. I've got a 69 myself.
    Darkness, Mountun Goat and 5N0W808 like this.
  10. Feb 1, 2022 at 12:49 PM
    #190
    the_white_shadow
    Beautiful bump side. Mine is also a 69.
    xYpOGzxeoK4nDlvV6Zm-m4UrkfptAB_5IzPRdwqx_95122787a9f8c8747e7928cf39ff25a79a0c33a0.jpg
  11. Feb 1, 2022 at 1:23 PM
    #191
    easleycrawler
    Travis
    Crown vic front? What motor does it have?
  12. Feb 1, 2022 at 1:25 PM
    #192
    the_white_shadow
    Yep. CV front. Mustang S550 IRS. Viking coilovers all the way around. 2JZ to an Ar5 5-speed.
  13. Feb 1, 2022 at 1:31 PM
    #193
    easleycrawler
    Travis
    Ummm, wow. Hell yeah.
    Darkness and Mountun Goat like this.
  14. Feb 1, 2022 at 1:35 PM
    #194
    easleycrawler
    Travis
    Mine is crown vic front, explorer 8.8 axle flipped rear and a 390 under the hood.
    Who did you get the coilovers from?
    Mountun Goat likes this.
  15. Feb 1, 2022 at 1:36 PM
    #195
    the_white_shadow
    Its A LOT of fun and the engine choice makes people happy or extremely mad. Here is a pic with messy wiring.
    KcKMaJvvjdi-uDGxZNrlkpz3v4EQYRubFNCamJlw_f161c9b970fc936081694022436da2c33ffb4508.jpg
  16. Feb 1, 2022 at 1:36 PM
    #196
    the_white_shadow
    I got them from https://andrewstuningandperformance.com/
    easleycrawler[QUOTED] likes this.
  17. Feb 1, 2022 at 1:39 PM
    #197
    easleycrawler
    Travis
    I love it. Hell I ain't a ford guy, but I love old trucks, only Toyota brand loyal.
  18. Feb 1, 2022 at 1:41 PM
    #198
    easleycrawler
    Travis
  19. Feb 1, 2022 at 1:43 PM
    #199
    the_white_shadow
    It was just a roller when i got it so i have no heartburn over cutting it all to hell.
  20. Feb 1, 2022 at 1:46 PM
    #200
    easleycrawler
    Travis
    I would have never guessed it had a 2jz under the hood. I knew it was turboed because of the hole in the fender, I figured it was LS swapped. Pretty quick?
  21. Feb 1, 2022 at 1:49 PM
    #201
    the_white_shadow
    It scoots but im having clutch slipping problems at anything north of 5k rpms. Its a bastard of a combo with a r154 2JZ bellhousing on the chevy colorado AR5 and i cant get the throwout bearing spacing correct. Im on my 2nd clutch in less then 500 miles. If i cant figure it out, im going t56 6-speed and biting the pillow from Grannas Racing. Its pricey. Until then ill pretend to be fast and enjoy it.
  22. Feb 7, 2022 at 11:59 AM
    #202
    the_white_shadow
    Had a nice weekend working on the Tundra. Rebuilt the 261 t-case and got it installed in the truck. Next up, i started on running the exhaust. I cut up the chevy 3" factory exhaust and ran it down each side with the drivers side going around the t-case. This will open up room for the front driveshaft. Once i ran out of usable pipe, i switched into wiring mode. I found a complete electrical wiring diagram for the 2005 tundra. It helped me identify the key wires to tap into with the Holley Terminator X harness. This way, i can use the key to turn on the ecu, run the fuel pump, and start the truck as per usual. I wanted a factory style install.
    I used this IE1 connector (the right side) to tap into the ignition wiring. Pin 5 and 13 are ignition sources with the key on. I used the EWD to identify the rest in this connector. In the future i will use it to run the AC compressor as well.
    hrhtMZZBPIadcBnthq9pWon2ckjgHk8xOhfMfNA0_1a09eb2d8a52e12a3b76d35b05354ef2d244b676.jpg
    Holley Terminator X ecu mounted in the glovebox. I cut a hole in the back to route the wires through.
    1wEayIUkyPjtex0do4iwnnvVbyVLpJlRJq_d54iU_5dd5ef9d68d038d40b1ebfdfee456f074ea4c320.jpg
    Wiring install under the hood. I used the original Tundra hole in the firewall with a new plate and grommet. I tried to make it as tidy as possible. Only additional wiring i have to put in the engine bay are for electric fans and the AC compressor.
    1NWJYfeMd1jnBCheEsfMy-ZQz43fnV05ylarQDzm_076effd9b445dceca4433976508a24d38a2f5aa3.jpg
    prMeeP6bDbIGbmZR5Sc4auuYQv3qSTEGg6lfkdq7_c4311bdc26b7e69acce82156b7a4f7ac70490a84.jpg
    Started on the gauge cluster mods as well. I gutted the factory cluster and added molded pod for my Holley Pro dash to recess into. Some of the wiring you see behind the panel will be used in the dash, ie turn signals, high lights, fuel gauge wiring, etc. The dash has inputs/outputs to display these functions. Once again, the goal here is to look factory-ish.
    JJ8QMAVHq7RhkKXF8tVE2thgal1Bz6rk_9eoI9CV_3339f325a1fc9b6c679f15d5743d772a672c1fe9.jpg
    g3xizQjW7QNBu7KjINrLEYX8qS8WEvKrx3Re6Rc5_6633ca766a1e85684a70031a9c37cc125ca671dc.jpg
    I also couldnt resist starting the truck and checking out things. Open exhaust is loud, but man does that judo chop of the Truck Norris can sound awesome at idle.
    https://youtu.be/uTfnQbbSQ7s
    More to happen soon. Still waiting on Fox to send my coilovers and rear smoothie shocks. May start rebuilding and finish welding the front axle this week.
    Sirfive, Bikeric, eccracer104 and 6 others like this.
  23. Feb 14, 2022 at 11:06 AM
    #203
    the_white_shadow
    A little progress this week. I finished the mount for the digital dash. Just need to wire it up now and see how she looks. 25KQzkMyU9MnqeNXBY2txpD_WGb9lR7aVn6TfJTd_7b3feebd32259989be4f81e44a353d6f1e445e60.jpg
  24. Feb 14, 2022 at 11:16 AM
    #204
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    All sick rides dude nice work :headbang:
    the_white_shadow[OP] likes this.
  25. Feb 14, 2022 at 11:47 AM
    #205
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  26. Feb 14, 2022 at 11:57 AM
    #206
    easleycrawler
    Travis
    You don't have any good condition 1st gen tacomas sitting around do you?
  27. Feb 14, 2022 at 11:58 AM
    #207
    the_white_shadow
    Negative. Sold my 03 last month
  28. Feb 15, 2022 at 6:39 AM
    #208
    the_white_shadow
    Finished pretty much all of the interior wiring and integration last night with the Holley dash wiring. Its such a cool piece. Wish i could have fit the bigger 12.3 screen in there.
    6lPwMJOxAjXx6mbICG-G6GiLANfxhq5LCzm7SZQJ_0a90c31e79b075cf97874ba97d3224a239c61f1d.jpg
    All kinds of dash layouts to choose from, or i could upload my own background.
    vI8l21MvZbt39P5VdndVUWzLL-DgR8f5HNlJc62h_a14bde64eb2e821f15095e4a82fe98442de64b6a.jpg
    Im going to verify all of my inputs/outputs are working through the dash (ie turn signals, fuel sender, high beam indicator) then i will put the dash back together and move on to the exhaust.
  29. Feb 15, 2022 at 7:32 AM
    #209
    the_white_shadow
    Are the photos too big? They look huge on my end.
  30. Feb 15, 2022 at 8:05 AM
    #210
    tstogner88
    tstogner88 New Member
    Tyler
    2016 Silver Sky Crewmax
    pictures look fine on my end
