The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    27.6%
  2. Alpine ILX-F509
    3 vote(s)
    2.4%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.6%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.6%
  7. No - I was late to the party
    52 vote(s)
    40.9%
  8. No - I didn't need a new head unit
    19 vote(s)
    15.0%
Multiple votes are allowed.
  1. Aug 26, 2023 at 2:16 PM
    #121
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Yup, that'll get ziptied away!
  2. Aug 26, 2023 at 5:22 PM
    #122
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    better yet. De pin it.
  3. Aug 26, 2023 at 5:31 PM
    #123
    Azblue
    The Dirty T ( ^_^)_且
    I got my dash kit today. Some flimsy ass mounts, but whatever. I also started hooking up some of the harness. Still have 1 last part coming and will soon mount the HU to the dash kit and finalize the wiring as much as I can before tearing the truck apart. For somebody that has done installs for decades, I'm feeling pretty dumb with the extra steps in newer vehicles. I think I've got most of it, but will definately be posting more questions for the last couple of things I'm not sure of. Stay tuned for more stupid questions from me in the next few days.
  4. Aug 26, 2023 at 5:35 PM
    #124
    AZTundra
    Paul
    Phoenix, AZ
    2 questions for you guys. I started to assemble everything at the table and think I'm good to go, but curious about the green wire with white line coming from the Alp1 harness not labeled and the green wire with white line from the Alpine camera harness that says speed sensor and is not connected to anything. Do these need to be connected together? And lastly, the blue wire on the antenna adapter I assume can be cut off and covered as it will not be used?
    I still need to wire in the bypass module and connect the wiring for the alpine dash cam, but I'm getting there.
  5. Aug 26, 2023 at 5:45 PM
    #125
    Azblue
    Those are some of the upcoming questions I just mentioned in the previous post.
    TaquitoBandito likes this.
  6. Aug 26, 2023 at 5:46 PM
    #126
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yup connect those together.
    as for the antenna power lead of the adapter…just verify there isn’t one in the truck side of the harness. If there isn’t one, just yank the pin out of the back of the metra antenna adapter
  7. Aug 26, 2023 at 5:58 PM
    #127
    AZTundra
    Paul
    Phoenix, AZ
    Thanks a bunch!
    I still need to order one of those hdmi adapters from Amazon as well. Maybe I'll get it installed before the holiday.
    Hardest part so far was messing with the dash kit when trying to adjust the screen height and depth. I must have mounted and unmounted it maybe 5-6 times. Couldn't get the angle right to access the screws and I wanted the height as low as it would go, but also closest to the dash. Finally got it and then the power bar and cover wouldn't fit so I ended up taking apart the side brackets of the dash kit with the screen installed and changed the depth to finish that up before then sliding it back closer to the dash side and remounting the brackets if that makes any sense. Anyways, happy with how it turned out in the end.
  8. Aug 26, 2023 at 6:02 PM
    #128
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yup, same method as myself.
  9. Aug 26, 2023 at 6:20 PM
    #129
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I got mine perfect on the second try :anonymous:
  10. Aug 26, 2023 at 6:28 PM
    #130
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  11. Aug 26, 2023 at 6:32 PM
    #131
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m only talking about the height of the screen… not the other 12 times I’ve redone things on this stereo lol
  12. Aug 26, 2023 at 6:39 PM
    #132
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Taking mine back out tomorrow to add a bypass since the first one was a the wrong one.
  13. Aug 26, 2023 at 6:40 PM
    #133
    Azblue
    Wrong part or installed incorrectly?
  14. Aug 26, 2023 at 6:42 PM
    #134
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Wrong part. I had to rig up a toggle to get it to let me in the settings so I could turn on the front and rear cams. I pulled it out and the other arrived today so tomorrow I’ll get back into setting and see what else I can do.
    Probably would have been installed wrong but I called Tom for the assist. :rofl:
  15. Aug 26, 2023 at 6:45 PM
    #135
    Azblue
    What did you have and what's the new one?
  16. Aug 26, 2023 at 6:46 PM
    #136
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Had the TR4. Got the TR1 today.
  17. Aug 26, 2023 at 6:49 PM
    #137
    Azblue
    Cool, I got the Axcess TRIG1 that should be here Monday, hopefully it'll work.
  18. Aug 26, 2023 at 6:56 PM
    #138
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    You are probably GTG. The new set up even neutered for now is bad ass.
  19. Aug 26, 2023 at 6:58 PM
    #139
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    I will be doing this when I complete the final steps of my installation
  20. Aug 26, 2023 at 7:00 PM
    #140
    ToyoMafia
    Magic carpet.
    Correct
  21. Aug 26, 2023 at 7:02 PM
    #141
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Would you mind posting pics when you get it wired up? I have that one coming in as well.
  22. Aug 26, 2023 at 7:03 PM
    #142
    ToyoMafia
    Magic carpet.
    Glad I asked you.
  23. Aug 26, 2023 at 7:09 PM
    #143
    Azblue
    Will do, though I still have questions on it that I need to ask the more knowledgeable when I do.
    Plus I had forgotten how being slightly colorblind really sucks when installing audio shit. :confused:
  24. Aug 26, 2023 at 7:27 PM
    #144
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Grey to grey. Light grey to light grey.
    Seriously, I’ll have mine apart tomorrow if you want some pics.
  25. Aug 26, 2023 at 7:40 PM
    #145
    Azblue
    Has anyone used this to connect the GPS and if so, did it work or did you end up using the one that came with the Alpine?
  26. Aug 26, 2023 at 7:44 PM
    #146
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That one won’t work on the F5xx head units. The Alpine port is different than the 2 that are included. It’s easiest to just use the Alpine GPS antenna and stick it to the underside of the dash
  27. Aug 26, 2023 at 7:46 PM
    #147
    Azblue
    I figured as much. hopefully the one for the XM in that will work though.
  28. Aug 26, 2023 at 7:47 PM
    #148
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That one does indeed work
  29. Aug 26, 2023 at 7:48 PM
    #149
    Azblue
    Good. I'll use that one and probably stick the Alpine GPS up under the center dash speaker.
  30. Aug 26, 2023 at 8:04 PM
    #150
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    We'll all figure it out together lol
